Topic: WSH Panel Mod (Read 823223 times) previous topic - next topic
WSH Panel Mod
Reply #827
if this is your definition of working better, i really wouldn't like to see what the old script does....
Scripting Engine Initialization Failed (GUID: D93FDE28-5275-4CA8-BB70-F5919C25C5AF, CODE: 0x80020101)
Check the console for more detailed information (Always caused by unexcepted script error).
Error: WSH Panel Mod (GUID: D93FDE28-5275-4CA8-BB70-F5919C25C5AF): Microsoft JScript runtime error:
'g_textcolor' is undefined
Ln: 67, Col: 5
<source text only available in compile time>
and this isn't the place to post scripts. this thread is for component help, bug reports and feature suggestions. scripts should be posted here....
http://www.hydrogenaudio.org/forums/index....showtopic=77883
but you might want to do some more testing first.
WSH Panel Mod
Reply #828
Ln: 67, Col: 5
i know i know
since i'm a DUI fanboy i didnt include it for CUI
http://foobar-silk.googlecode.com/files/nf...0.1--script.txt here is the link for the fix
enjoy!
next time i'll post it in the other topic!
WSH Panel Mod
Reply #829
@T.P Wang:
bug report (or help required if i use it in the bad way):
i'm coding a playlist manager in WSH panel mod 1.3.2, and it seems that fb.RemovePlaylist(idx); doesn't work for idx = 0
fb.RemovePlaylist(0); give me a script error ... and i have at least one playlist created when i use it
id to delete=0
Error: WSH Panel Mod (GUID: 26A7BCC7-EE59-4150-A3EA-E1FFD07EE3F6): Erreur d'exécution Microsoft JScript:
Argument ou appel de procédure incorrect
Ln: 322, Col: 21
any idea, could you try by yourself and fixing this problem please ?
Thanx by advance
WSH Panel Mod
Reply #830
I'm not sure, but I think you should use idx+1
WSH Panel Mod
Reply #832
ok, I was enumerating them with index+1 in comserver script so I thought that maybe in WSH they are numbered as in foobar (starting with 1), but then you used 0 probably because you knew that playlist indexing starts with 0
nevermind I guess it's WSH bug then because I can remove playlist(idx=0) with comserver succesfully
WSH Panel Mod
Reply #833
in my script, i use a variable and not 0 ! 0 was to explain the bug
T.P. please, help !!!
WSH Panel Mod
Reply #834
I confirm this bug! (I never tried to delete the first playlist, so I never noticed before...)
WSH Panel Mod
Reply #835
WSH Panel Mod 1.3.3 Uploaded:
v1.3.3
- ADD: Read only window.IsTransparent property.
- CHG: Add new parameter "no_load" to utils.GetAlbumArtAsync().
- FIX: Stub images won't be loaded since WSH Panel Mod 1.3.2.
- FIX: fb.RemovePlaylist(idx) doesn't work when idx == 0.
WSH Panel Mod
Reply #836
Do you plan to add the enhancements made by DarkJedii to the "official" build?
WSH Panel Mod
Reply #837
THanks for the update TPWang!
@Falstaff: could you share your playlist manager panel? I am eager to see what we can do other than playlist tabs and playlist dropdown.
WSH Panel Mod
Reply #838
Thanx a lot for the quick fix, it's ok now
I think that T.P won't because the modification brought by DarJedii seems to be in conflict with the termes of the SDK License...
@carmenm:
it will be share with the release of my next config (release before the end of the skin contest open on Deviant Art, group Foo-Nation)
WSH Panel Mod
Reply #839
I found another bug:
This is a quote from interfaces.txt:
    // [Optional] multivalue_fields is a semicolon-separated list contains fields name which need to be treated as multivalue.
    // Usage: meta.UpdateFileInfoSimple("ARTIST", "Enigma", "GENRE", "Downtempo;Ambient", "GENRE");
    //     GENRE will be treated as a multivalue field. So GENRE[0] = "Downtempo", GENRE[1] = "Ambient
    void UpdateFileInfoSimple(field1, value1 [, filed2, value2 [,...] ] [, multivalue_fields]);
But it doesn't seem to work like that...
If I do
cmetadb.UpdateFileInfoSimple("COMMENT", "test 1;test 2", "COMMENT");
I get an error ("Subscript out of range")
If I do
cmetadb.UpdateFileInfoSimple("COMMENT", "test 1;test 2", "");
I get the same error
If I do
cmetadb.UpdateFileInfoSimple("COMMENT", "test 1;test 2");
COMMENT becomes "test 1" (first value); "test 2" (second value)
So this last case does what the first case should do, but how to store one value containing "test 1;test2"?
WSH Panel Mod
Reply #840
@T.P Wang
It seems on_playback_stop is not called at the end of file.
function on_playback_stop(reason) {
    fb.trace( "reason is " + reason );
This code won't output anything when a file is played.
WSH Panel Mod
Reply #841
You mean, when playback is continuing with the next file? Then playback is not stopped and the behaviour is correct.
WSH Panel Mod
Reply #842
^sorry but you are wrong. the function works fine for me. it should output 2 as the reason....
edited because i'm a numpty.
WSH Panel Mod
Reply #843
No, you are wrong
on_plaback_stop() with the stop reason "starting_another" is only called, when you start the playback of a track, while currently another track is being played. It is not called, when the playback advances from one track (at the end of file) to the next inside a playlist.
WSH Panel Mod
Reply #844
oh, that's a bit embarrassing. apologies.
WSH Panel Mod
Reply #845
Anyway, on_playback_stop should be called at the eof because the end is reached, and such a reason is specified.
WSH Panel Mod
Reply #846
It will be called, but eof here means, that no file for playing is available anymore, for example, when you reach the end of a playlist with default playback order. It doesn't mean end of each file.
WSH Panel Mod
Reply #847
Okay, this makes sense. I am writing a script to play the specified number of tracks, and the workaround is to use on_playback_new_track callback.
WSH Panel Mod
Reply #848
Is there an implementation of SetTimer() to draw smoother seekbars etc?
