Topic: foo_playcount_sql (Read 97817 times) previous topic - next topic
foo_playcount_sql
Reply #175
Foobar2000 1.0.1:
DB To be created at: C:\Program Files\foobar2000\PlayCount.sdf
Error: foo_playcount_sql: Error: HR 0x80040154 File .\PlayStat_DB.cpp Line 273
Does not seem to work.
Same thing here, I have installed Microsoft SQL Server Compact 3.5 Service Pack 1, using Windows 7 x86.
Using foobar2000 v115
foo_playcount_sql
Reply #176
Hi.
foobar2000 seems to crash when opening Properties for a track.
No crash report.
Happens only for some files, don't know the connection.
I have installed following:
Microsoft Visual C++ 2008 SP1 Redistributable Package (x86)
Microsoft SQL Server Compact 3.5 Service Pack 2
It can be reproduced with a bare minimum install of foobar2000 + foo_playcount_sql.
However, it only happens with my current PlayCount.sdf.
Works if I remove the PlayCount.sdf-file, it still reads the info somewhere, maybe from RAM?
Microsoft Windows 8 Consumer Preview.
Version 6.2 (Build 8250)
Core (2012-02-04 13:05:48 UTC)
    foobar2000 core 1.1.11
foo_input_std.dll (2012-02-04 13:05:10 UTC)
    Standard Input Array 1.0
foo_playcount_sql.dll (2009-06-18 22:12:48 UTC)
    Playback statistics SQL 1.5.4.236
foo_ui_std.dll (2012-02-04 13:04:08 UTC)
    Default User Interface 0.9.5
It might be something in Windows 8 that's causing it.
Please ask if you want some more info or if you want any file that can help you find the issue.
