OpenVPN might discard multicast, but the iPhone is using the Windows PPTP VPN. Unless OpenVPN also interferes with that? I'll have to test some other router settings at home and also shut down OpenVPN to be sure.
LOL, I'll be damned if the broken media URL problem isn't gone now. I have no idea why, but I'm not complaining. Maybe it was happening when using an older version of the plugin. But I was always only using the PP renderer.
For the last thing, that's the weird part. Yes my PC does has a virtual 10.x.x.x address. And it doesn't matter if I connect to the server on the 10.x.x.x interface or the 192.168.x.x interface (both work because of OpenVPN's routing). It is always detected as WAN. Not sure if it's useful, but here's the server startup log and both interface connection logs. It does seem to detect all the interfaces during startup.
fb2k server startup
foo_upnp: FINEST: header USN: uuid:93eed0e0-72ba-bde6-0261-93702c1243db::urn:schemas-upnp-org:service:ContentDirectory:1
foo_upnp: FINEST: header NT: urn:schemas-upnp-org:service:ContentDirectory:1
foo_upnp: FINEST: header Host: 239.255.255.250:1900
foo_upnp: FINEST: header LOCATION: [url=http://192.168.5.15:56923/DeviceDescription.xml]http://192.168.5.15:56923/DeviceDescription.xml[/url]
foo_upnp: FINEST: header NTS: ssdp:alive
foo_upnp: FINEST: header CACHE-CONTROL: max-age=1800
foo_upnp: FINEST: header Server: UPnP/1.0, DLNADOC/1.50, Platinum/0.5.1
foo_upnp: FINEST: header USN: uuid:93eed0e0-72ba-bde6-0261-93702c1243db::urn:schemas-upnp-org:service:ConnectionManager:1
foo_upnp: FINEST: header NT: urn:schemas-upnp-org:service:ConnectionManager:1
foo_upnp: FINEST: header NT: uuid:93eed0e0-72ba-bde6-0261-93702c1243db
foo_upnp: FINEST: header USN: uuid:93eed0e0-72ba-bde6-0261-93702c1243db::upnp:rootdevice
foo_upnp: FINEST: header NT: upnp:rootdevice
foo_upnp: FINEST: header USN: uuid:93eed0e0-72ba-bde6-0261-93702c1243db::urn:schemas-upnp-org:device:MediaServer:1
foo_upnp: FINEST: header NT: urn:schemas-upnp-org:device:MediaServer:1
foo_upnp: FINEST: header USN: uuid:93eed0e0-72ba-bde6-0261-93702c1243db::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
foo_upnp: FINEST: header NT: urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
foo_upnp: FINEST: header LOCATION: [url=http://192.168.5.185:56923/DeviceDescription.xml]http://192.168.5.185:56923/DeviceDescription.xml[/url]
foo_upnp: FINEST: header LOCATION: [url=http://10.64.75.1:56923/DeviceDescription.xml]http://10.64.75.1:56923/DeviceDescription.xml[/url]
foo_upnp: FINEST: http request: NOTIFY * HTTP/1.1
foo_upnp: FINEST: header - Host: 239.255.255.250:1900
foo_upnp: FINEST: header - LOCATION: [url=http://10.64.75.1:56923/DeviceDescription.xml]http://10.64.75.1:56923/DeviceDescription.xml[/url]
foo_upnp: FINEST: header - NTS: ssdp:alive
foo_upnp: FINEST: header - CACHE-CONTROL: max-age=1800
foo_upnp: FINEST: header - Server: UPnP/1.0, DLNADOC/1.50, Platinum/0.5.1
foo_upnp: FINEST: header - USN: uuid:93eed0e0-72ba-bde6-0261-93702c1243db::upnp:rootdevice
foo_upnp: FINEST: header - USN: uuid:93eed0e0-72ba-bde6-0261-93702c1243db::urn:schemas-upnp-org:device:MediaServer:1
foo_upnp: FINEST: header - USN: uuid:93eed0e0-72ba-bde6-0261-93702c1243db::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
foo_upnp: FINEST: header - USN: uuid:93eed0e0-72ba-bde6-0261-93702c1243db::urn:schemas-upnp-org:service:ContentDirectory:1
foo_upnp: FINEST: header - USN: uuid:93eed0e0-72ba-bde6-0261-93702c1243db::urn:schemas-upnp-org:service:ConnectionManager:1
10.x.x.x
foo_upnp: FINE: creating thread
foo_upnp: FINE: thread in =======================
foo_upnp: FINEST: http request: GET /DeviceDescription.xml HTTP/1.1
foo_upnp: FINEST: header - Authorization: Basic XXXXXXXX
foo_upnp: FINEST: header - User-Agent: Platinum/0.5.1, DLNADOC/1.50 / foobar2000
foo_upnp: FINEST: header Host: 10.64.75.1:56923
foo_upnp: INFO: received WAN request: [url=http://10.64.75.1:56923/DeviceDescription.xml]http://10.64.75.1:56923/DeviceDescription.xml[/url] (User-Agent: Platinum/0.5.1, DLNADOC/1.50 / foobar2000)
foo_upnp: INFO: ProcessGetDescription: user-agent: Platinum/0.5.1, DLNADOC/1.50 / foobar2000
foo_upnp: FINEST: header Server: Platinum/0.5.1
foo_upnp: FINEST: header Content-Length: 2875
foo_upnp: FINEST: header Content-Type: text/xml; charset="utf-8"
foo_upnp: FINEST: header Connection: keep-alive
foo_upnp: FINE: NPT_CHECK failed, result=-20014 (NPT_ERROR_TIMEOUT) [(stream.ReadLine(line, NPT_HTTP_PROTOCOL_MAX_LINE_LENGTH))]
foo_upnp: FINEST: http request: GET /X_MS_MediaReceiverRegistrar/93eed0e0-72ba-bde6-0261-93702c1243db/scpd.xml HTTP/1.1
foo_upnp: FINEST: header Content-Length: 2768
foo_upnp: FINEST: http request: GET /ContentDirectory/93eed0e0-72ba-bde6-0261-93702c1243db/scpd.xml HTTP/1.1
foo_upnp: FINEST: header Content-Length: 6818
foo_upnp: FINEST: http request: GET /ConnectionManager/93eed0e0-72ba-bde6-0261-93702c1243db/scpd.xml HTTP/1.1
foo_upnp: FINEST: header Content-Length: 4410
192.168.x.x
foo_upnp: FINEST: header Host: 192.168.5.185:56923
foo_upnp: INFO: received WAN request: [url=http://192.168.5.185:56923/DeviceDescription.xml]http://192.168.5.185:56923/DeviceDescription.xml[/url] (User-Agent: Platinum/0.5.1, DLNADOC/1.50 / foobar2000)
