Hi. I use foobar2000 very long time and really enjoy it. Recently I decide to try to stream my music collection to my Sony Bravia KDL W5500 using your plugin and have no luck. You can find logs here. Thanx.
Can you be a bit more specific about the what the problem is, and repost a log with INFO level ?
The problem is TV cannot see foobar2000 - it doesn't appear in Music sources. Logs
foo_upnp: 241.547: NPT_File::Load(240)/2256: INFO: Opening D:\bin\foobar2000\foo_upnp_ml_tree.xml
foo_upnp: 241.547: NPT_File::Load(250)/2256: INFO: Opened D:\bin\foobar2000\foo_upnp_ml_tree.xml
foo_upnp: 241.547: standard_media_tree_root_node_t::load_ml_filters(482)/2256: INFO: loaded Media Library filters from D:\bin\foobar2000\foo_upnp_ml_tree.xml
foo_upnp: 241.547: LoadBrowseTreeTask::DoRun(84)/3028: INFO: loaded 0 nodes in 0.000s
foo_upnp: 241.547: PLT_UPnP::AddDevice(343)/2256: INFO: Starting Device...
foo_upnp: 241.547: PLT_HttpServer::Start(109)/2256: INFO: HttpServer listening on 0.0.0.0:56923
foo_upnp: 242.94: LoadBrowseTreeTask::DoRun(84)/2680: INFO: loaded 1 nodes in 0.547s
foo_upnp: 242.703: FbMediaServer::ProcessHttpRequest(255)/1584: INFO: received LAN request: http://192.168.1.20:56923/DeviceDescription.xml (User-Agent: UPnP/1.0)
foo_upnp: 242.703: FbMediaServer::ProcessGetDescription(320)/1584: INFO: ProcessGetDescription: user-agent: UPnP/1.0
foo_upnp: 243.312: FbMediaServer::ProcessHttpRequest(255)/3496: INFO: received LAN request: http://192.168.1.20:56923/ContentDirectory/efdb4543-2456-abc0-fb49-39072b7dd95a/control.xml (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 243.312: FbMediaServer::OnAction(197)/3496: INFO: received action 'GetSortCapabilities', args = { }
foo_upnp: 243.312: FbMediaServer::OnAction(214)/3496: INFO: action 'GetSortCapabilities' response: args = { SortCaps= }
foo_upnp: 243.516: FbMediaServer::ProcessHttpRequest(255)/1652: INFO: received LAN request: http://192.168.1.20:56923/ConnectionManager/efdb4543-2456-abc0-fb49-39072b7dd95a/control.xml (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 243.516: FbMediaServer::OnAction(197)/1652: INFO: received action 'GetProtocolInfo', args = { }
foo_upnp: 243.516: FbMediaServer::OnAction(214)/1652: INFO: action 'GetProtocolInfo' response: args = { Source=http-get:*:*:*, Sink= }
foo_upnp: 243.562: FbMediaServer::ProcessHttpRequest(255)/1824: INFO: received LAN request: http://192.168.1.20:56923/DeviceDescription.xml (User-Agent: UPnP/1.0)
foo_upnp: 243.562: FbMediaServer::ProcessGetDescription(320)/1824: INFO: ProcessGetDescription: user-agent: UPnP/1.0
foo_upnp: 244.109: FbMediaServer::ProcessHttpRequest(255)/1232: INFO: received LAN request: http://192.168.1.20:56923/ContentDirectory/efdb4543-2456-abc0-fb49-39072b7dd95a/control.xml (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 244.109: FbMediaServer::OnAction(197)/1232: INFO: received action 'GetSortCapabilities', args = { }
foo_upnp: 244.109: FbMediaServer::OnAction(214)/1232: INFO: action 'GetSortCapabilities' response: args = { SortCaps= }
foo_upnp: 244.312: FbMediaServer::ProcessHttpRequest(255)/3292: INFO: received LAN request: http://192.168.1.20:56923/ConnectionManager/efdb4543-2456-abc0-fb49-39072b7dd95a/control.xml (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 244.312: FbMediaServer::OnAction(197)/3292: INFO: received action 'GetProtocolInfo', args = { }
foo_upnp: 244.312: FbMediaServer::OnAction(214)/3292: INFO: action 'GetProtocolInfo' response: args = { Source=http-get:*:*:*, Sink= }
TV can handle mp3 and LPCM for sure. I have tried HMS and it works, but not provide what I want.
Hope this information will help.
