Topic: Kameleon by Br3tt (Read 325319 times) previous topic - next topic
Kameleon by Br3tt
Reply #51
be sure that there is no gap in the variables values
Sure, I read the whole thread before reporting. I have not even set a custom variable for the album art. About 50% of the time (it decides always when I start foobar) it works, 50% it doesn't. When I find a common property (probable of the resized cover image, I suppose) I will report.
ok, wait for more info about pics ...
Artistart issue: I just read the drawback of foo_exvar, that it is not capable of reflecting my artist art naming scheme for your theme:
Folder: $replace(%path%,%directoryname%\%filename_ext%,)
Filename: folder.jpg
Is there any chance you might include this (I hope often used) convention to store the artist image in the folder hierarchy one level above the album art?
yep, i'll try to add support for common functions like $replace and for some variables like those mentionned  ... i may need your help to test this new fcl
Kameleon by Br3tt
Reply #52
I just found a little bug with foo_input_mslive.dll. Kameleon freezes when I open a mms stream, it worked fine with curacao. Probably some of the new code in ELPlaylist?
i don't use foo_input_mslive ... will try ... btw i use foo_msnalt.dll and have no problem
Kameleon by Br3tt
Reply #53
first of all, awesome skin, brett! it's one of best skin ever made for any music player, and by this one, you moved standards of making an awesome skin.
my question : why doesn't my foobar shows artist image? i already read tutorial and did everything as it should been done, and read this whole article, but no go.
i created "ArtistArt" folder where are all my artist photos, in kameleon_artistart_path, my values are :  D:/MZLV/glazba/ArtistArt/, and in kameleon_artistart_filename, my values are : %artist%.jpg. I tried to change to artist.jpg, but still nothing. How does my artist art path should look like? Cheers
Kameleon by Br3tt
Reply #54
Just a small question - the style settings for Album List are inside ColumnsUI settings. Everytime I import one of your fcl's, the settings are reset to white bg/black Tahoma font (defaults).
Is it a problem with ColumnsUI/Album List, or is it your config is set with defaults for Album List?
Thank you, nice config.
Kameleon by Br3tt
Reply #55
Hey Br3tt what can we do about the performance issue ?? The config is great but every few minutes it uses loads of cpu power and the config becomes unresponisve. Any help??
Kameleon by Br3tt
Reply #56
here, CPU is around 2 or 4 % with all panels (Vis, Spe ...) visible ! so K cannot be responsible ...
BUT if you use Chronflow, on track change, CPU can grows to 70% or 80% or over before going down to normal values (2% or 4%),
SO, it is a Chronflow issue already known by Chronflow users. To optimize this, be sure that you have READ and set the Chronflow performance panel as discribed on my site
If you have a low/old CPU, just do not use Chronflow panel ...
Kameleon by Br3tt
Reply #57
must work, my personnal needs for artist path are similar to yours, be sure you have the good path, not space add too much?
my settings are :
just replace the path value by your.
Be sure that your artists photo are named %artist%.jpg like you say it to me (ex: Pink floyd.jpg)
Kameleon by Br3tt
Reply #58
try this fcl file to see if it works now... *waits for feedback*
sorry, $replace(...) inside foo_exvar not supported
I use Discogs for my artist art, and then use %DISCOGS_ARTIST_ID%_1.jpg for my artist image. However, It doesnt show up
I have kameleon_artistart_path set to E:/foobar2000/images/Artist/, and kameleon_artistart_filename to %DISCOGS_ARTIST_ID%_1.jpg.
This should work I guess?
try this fcl file : http://br3tt.free.fr/files/K/kameleon_1.0b3.fcl, %DISCOGS_ARTIST_ID% support added ... *waits for feedback*
Kameleon by Br3tt
Reply #59
Fantastic config!
Artist picture doesn't work here also!
kameleon_artistart_path    J:/mp3/artists/
kameleon_artistart_filename    %performer%*.*
I tried %performer%.* and %Performer%*.* and %PERFORMER%*.* and so on, but nothing.
I need help!
Kameleon by Br3tt
Reply #60
Awesome setup, Br3tt. thx for the hard work.
Just i quick pointer, updating to the latest lyrics show panel decreases my CPU usage from 17% to ~4%.
http://www.hydrogenaudio.org/forums/index....showtopic=55692
Get it there.
Also I'm getting the same issue with the wrong sized album art in the left sidebar.
Kameleon by Br3tt
Reply #61
Thanks, but isn't foo_msnalt.dll a now playing component?
Fantastic config!
I need help!
Maybe I'm totally off, but isn't in the windows path always a backslash, so it would be "J:\mp3\artists\". At least that is how it works for me.
I wondered about that in the readme, but then I already had copy pasted the paths and it worked.
Kameleon by Br3tt
Reply #62
Fantastic config!
I need help!
as already said and mentionned in the instyallations notes on my site, foo_exvar do not handle %% variables, excepted those i have coded (%album%, %artist%, %album artist% ... read the doc!)
btw, i can include %performer% for the next build ==> done, try this fcl file : http://br3tt.free.fr/files/K/kameleon_1.0b3.fcl i've added %performer% and %band% too , gimme feedback
Kameleon by Br3tt
Reply #63
my settings are :
thanx for help, but im 100% positive there's no any space between, before or after the titled path for filename or path.
anyway, check this, i can't see any failure why it wouldn't work but it still doesn't work :S
http://img293.imageshack.us/img293/7557/hmmdx8.jpg
Kameleon by Br3tt
Reply #64
Get it there.
Solved my high CPU usage too  (it wasn't chronoflow case at all)
Now only one thing remains on my "than it will be perfect" list.. playlist switcher in the left panel (is it even possible?)
Kameleon by Br3tt
Reply #65
Get it there.
what was your CPU usage problem please, that can maybe help others ... Thanx
Kameleon by Br3tt
Reply #66
You are missing a backslash at the end of the path. there is an explicit warning about that inside instructions.
Kameleon by Br3tt
Reply #67
my settings are :
Kameleon by Br3tt
Reply #68
Get it there.
It was solved by updating Lyrics Show Panel to the latest version as explained in the post he quoted. Actually there are a lot of components which aren't up to date in the package. I don't think all of them have performance updates since then but some might and others might solve other issues. If you could provide a component list like for Ibiza that would make it much easier to update the components that Kameleon uses
Edit: As a matter of fact it improved performance on my system by a lot too.
Kameleon by Br3tt
Reply #69
Get it there.
lyrics show panel -> updating it helped  (link's above) in my case in dropped from 30-40 to 2-10% CPU usage
Kameleon by Br3tt
Reply #70
you have forgotten a "/" at the end of the path !!!
fix it and retry
hmm, still no luck.
i forgot it probably when i was transfering artist art to simplier path, but before then, i still had '/' thing at the end of the path, and it weren't work.
damn.
Kameleon by Br3tt
Reply #71
fix it and retry
hmm, still no luck.
damn.
sorry, but this work here, take care of all again, can't say better, sorry...
Kameleon by Br3tt
Reply #72
Br3tt, I have the bug with bad scaling of cover image to
And, maybe, you should add tutorial how to show or not cover image in the background? (I can`t find where it change)
Great config as usual, thank you very much !!!
Kameleon by Br3tt
Reply #73
1. for the scale problem in the CD case, please, show me a screenshot of your foo_exvar settings panel + an example of path where your cover is stored (and filename used), and send me the image cover used
==> WITHOUT ALL OF THAT, it's difficult to help because all work fine for me.
thanx by advance, you or another people that have this problem
2. viewing the Curacao tutorial page can help you, the way to always use the default wallpaper bg is discribed in a video
http://br3tt.free.fr/tutorials/C/index.htm ==> the second video ... for Kameleon, enter splitter settings (right click on the playlist header for example), select the panel named '-> Force Wallpaper', then UNCHECK 'hide panel on startup' option, if you have read more carefully my installations notes, i explain how to to that, not only for this panel/boolean option, but just generally, it is the same way to activate or not all panels/boolean that begin by '-> '
Kameleon by Br3tt
Reply #74
fix it and retry
hmm, still no luck.
damn.
i delete whole foobar, including app data from my documents, then installed on whole another disk, do everything as it's been said - AND IT WORKED!
woohoo
thanks for help man, and congrats on the best skin ever made for foobar
