Topic: Kameleon by Br3tt (Read 221777 times) previous topic - next topic
  • AxaliaN
Kameleon by Br3tt
Yay finally! Gonna test it now! <3 Br3tt!
Edit: I keep getting a warning from Shpeck when I start Foobar:
Original Winamp or some other Winamp emulator has been detected. This can result in wrongly reported data, nonfunctional plugins and other conflicts, be warned.
  • Last Edit: 15 February, 2009, 05:16:59 AM by AxaliaN
  • Falstaff
Kameleon by Br3tt
KAMELEON v1.0b released. some fixes ... (lastest foo_skip plugin too)
the bug cover display (bad scale in the CD Case) is maybe fixed because i can't reproduce it, but i've made a little change...
  • Last Edit: 15 February, 2009, 05:22:46 AM by Falstaff
  • AlStorm
Kameleon by Br3tt
Here a bug!
My config:
It's OK if I set: kameleon_artistart_filename: artist.jpg
Hmmm... you show me the Cover pic bug and talk about artistart filename ???!!
so the problem is about covers :
kameleon_coverart_path      : default (=music folder) / specified path (i.e: C:/covers/) (be careful, specified path must close with a '/')
kameleon_coverart_filename   : i.e: folder.jpg / folder.* / %album%.jpg / etc ...
if nothing setted in Foo_exvar, it search for folder.jpg images in the music folder, is it your case ? does it happen with all covers CD or only some of them ?
I understand it!
It is necessary to remove any extra spaces before and after the %artist%.jpg!
After that, the picture shows a well
  • Falstaff
Kameleon by Br3tt
LOL, of course
  • rawgue_
Kameleon by Br3tt
Very beatiful work, but i'd like to see you tackle a lighter/easier on the eye config instead. I admit it's very nice, but i can't see myself using that for my actual config. edit: through more white in there too for a change too : )
  • Last Edit: 15 February, 2009, 05:33:26 AM by rawgue_
  • AxaliaN
Kameleon by Br3tt
Reply #30
I use Discogs for my artist art, and then use %DISCOGS_ARTIST_ID%_1.jpg for my artist image. However, It doesnt show up
I have kameleon_artistart_path set to E:/foobar2000/images/Artist/, and kameleon_artistart_filename to %DISCOGS_ARTIST_ID%_1.jpg.
This should work I guess?
  • Falstaff
Kameleon by Br3tt
foo-exvar do not handle variables like %var%, except %artist%, %album%, %album artist% be cause i have tweaked the code in K to handle them.
so all other %% can't work without some coding ... Same for all titleformat functions (like $replace(...) for example), they are not supported by foo_exvar.
i'll add this info in the INSTALLATION NOTES. (done)
  • Last Edit: 15 February, 2009, 05:56:06 AM by Falstaff
  • Falstaff
Kameleon by Br3tt
the more white it can be is to use a full white wallpaper as background :
  • Mr. Pacman
Kameleon by Br3tt
Reply #33
Man! This is a miracle! Br3tt thank you soooo much!!!
  • Falstaff
Kameleon by Br3tt
Reply #34
You're welcome Mr. Pac
  • rawgue_
Kameleon by Br3tt
Reply #35
What i mean is that maybe you should try something different. Too much stuff, bells and whistles. I suppose you'll say 1) i do it for my personal needs or 2) If you don't like it don't use.  But the thing is that not many "waste" so much time to give configs to the community so maybe you could experiment with something else. Maybe a Pimp my Foobar kind of thing. I'll be the first to submit : D http://img8.imageshack.us/img8/3366/clipboard01gx0.jpg
Don't mean to sound like an ungrateful asshole, keep doing what you like most : )
  • Last Edit: 15 February, 2009, 06:17:47 AM by rawgue_
  • meDveD.spb
Kameleon by Br3tt
Reply #36
these components are new versions:
foo_run
foo_lastfm_radio
foo_uie_lyrics
why the required components are not foo_audioscrobbler?
foo_lastfm_radio meaningless without foo_audioscrobbler
and please, delete foo_playback_custom (automatic editing tags and corrupted hash files of torrents and dc++)
  • gaabrysz
Kameleon by Br3tt
Reply #37
Hey Guys.
Thank You Br3tt for this theme:) it's great but it's slow as hell on my pc.
Any help??
Hmm... Now it's working ok for cuple of minutes and then it slows down. You can see that when you try to switch between different panels ect..
  • Last Edit: 15 February, 2009, 09:03:44 AM by gaabrysz
  • qwertz
Kameleon by Br3tt
Reply #38
Really great work Falstaff
I specially like how easy it is, to adapt the config, to my needs, that's quite an achievement with Panel Stack Splitter.
  • Last Edit: 15 February, 2009, 08:33:09 AM by qwertz
  • cloudol
Kameleon by Br3tt
Reply #39
snapix font cannt support chinese and japanese
  • ojdo
Kameleon by Br3tt
Reply #40
Happens still here, but also not reproducable. (v0.9.6.3 beta 1 with kameleon 1.0b fully installed)
  • blackey
Kameleon by Br3tt
Reply #41
First of all - another great config  Thanks for great work
Nevertheless I've got a few problems with Kameleon
1. CPU usage - over 60% sometimes (c2d@3.2Ghz so I don't think that hardware is the case). I've noticed it jumps so high only in two moments - when lyrics or now playing panel is active (even worse when both)
2. Playlist switcher should be in the left panel (wishlist:P), I'm using it a lot and it's somehow weird now
3. Chronoflow - viewing by playlists? (It's probably more for developer of chronoflow;))
  • bismuth
Kameleon by Br3tt
Reply #42
Thanks for the great config!
I have a question:
I want to set the cover file name like this:
If there is a file named %album%.jpg, then use that one, if not, use the file folder.jpg
Is it possible?
& I also receive this warning when start foobar: "Original Winamp or some other Winamp emulator has been detected. This can result in wrongly reported data, nonfunctional plugins and other conflicts, be warned." How to fix it?
Thanks in advanced
  • Last Edit: 15 February, 2009, 09:44:56 AM by bismuth
  • exxecutor
Kameleon by Br3tt
Reply #43
Thank you very much, Brett! Kameleon is really amazing.  Visually stunning, everything worked out in great detail. The new left, right and "now playing" panels are a big improvement (I didn't think that was even possible) over your last configs.
Now some constructive criticism:
In my opinion, Album List and Playlist Switcher could be implemented in a better way. Currently they open in a panel roughly 600x300 big. Ideally, this should be something like 300x600 because both AL and PS can have many rows and don't need too much space horizontally.
I suggest that the panel for AL and PS has the same size as the left panel and appears directly above it. This would be a nice combination of Ibiza (position) and Curacao/Kameleon (functionality). The buttons to show AL/PS could be moved to the right of the play/pause, etc buttons.
For my needs that would be perfect because when I browse playlists or AL, I am anyway more interested in what happens in ELPlaylist than the visuals of the left panel.
Kameleon by Br3tt
Reply #44
Maybe you have kmplayer started
  • Falstaff
Kameleon by Br3tt
Reply #45
read post #28 above (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69485&view=findpost&p=615358)
be sure that there is no gap in the variables values
  • qwertz
Kameleon by Br3tt
Reply #46
I just found a little bug with foo_input_mslive.dll. Kameleon freezes when I open a mms stream, it worked fine with curacao. Probably some of the new code in ELPlaylist?
  • ojdo
Kameleon by Br3tt
Reply #47
Sure, I read the whole thread before reporting. I have not even set a custom variable for the album art. About 50% of the time (it decides always when I start foobar) it works, 50% it doesn't. When I find a common property (probable of the resized cover image, I suppose) I will report.
Artistart issue: I just read the drawback of foo_exvar, that it is not capable of reflecting my artist art naming scheme for your theme:
Folder: $replace(%path%,%directoryname%\%filename_ext%,)
Filename: folder.jpg
Is there any chance you might include this (I hope often used) convention to store the artist image in the folder hierarchy one level above the album art?
  • Divajjn
Kameleon by Br3tt
Reply #48
hi, amazing config br3tt . as always  .....when i start a track, background image is automaticly set to the cover image of the band, is it possible to set a bg image that is displayed even when i play a track
  • kkamion
Kameleon by Br3tt
Reply #49
Click on the alien cat above playlist
