Topic: Copy "item detail" of Columns UI (Read 2105 times) previous topic - next topic
Do it possible to do to select the text in "item detail" of Columns UI to copy the content in the clipboard?
To display its content, Item details uses foobar's Title formatting syntax.
Right-click on the Item details panel and choose 'Options' to see the patterns you are using in your configuration; then tell either Text Tools or Utilities to copy that patterns to the clipboard, Item details itself does not support that.
