Topic: Can flac.exe resample a FLAC file? (Read 4160 times) previous topic - next topic
  • JJZolx
Recently, it seems that SqueezeCenter (for the Squeezebox) changed its method of doing resampling of 24/96 FLAC files by using SOX to downsample to 24/48 FLAC so that the files can be played on the Squeezebox.  This (if I read it right) also has the effect of now using SOX to play FLAC files with CUE sheets.  Not the best solution, since SOX appears to consume a lot more CPU cycles.
Is flac.exe not capable of resampling FLACs from 24/96 to 24/48?
  • Last Edit: 13 January, 2009, 03:49:31 PM by JJZolx
  • tuffy
It's not.  Any resampling will have to be performed by an external application of some sort.
  • JJZolx
Has this capability ever been considered?  Or is it technically infeasible or otherwise undesirable for some reason?
  • tuffy
Though it might be presumptuous to assume Mr. Coalson's motives, I believe it's undesirable to include that option because resampling an audio stream is not a lossless process in general, and thus falls outside FLAC's scope as a lossless audio format.  So, the reference tools leave that job to someone else.
  • jcoalson
yep, resampling is not lossless and good resampling is hard, so I would rather leave that to another tool.
