Topic: some titleformatting questions (Read 2676 times) previous topic - next topic
1-can I display in the item details window all the text from tag, which is not some other tag? for example: i've tagged %album_artist% like `Alkaline Trio & Hot Water Music`, can I display `split with Hot Water Music` when Alkaline Trio track from this album is playing? So I would remove the part from %album_artist% which is equal to artist. (It would be pretty useful, cause I've tagged all split mp3 like mentioned above)
2-How I can get playlist item numbers in column playlist? there was some tag for this..
3-Can I get percentage in album list, eg to show how much of my total library is in genre `electronic`? Yes it would be [item count in subcategory] / [total item count] * 100, but I don't know how to get those variables.
thanks in advance!
what is the "the item details window" exactly? The Selection Properties pane? if so, then no.
%list_index%
No. It's not possible.
elevatorladylevitateme
1. $replace(longer string,bit you don't want,)
1 - Split... (well the dots aren't working even here, you'll have to use contents and find the topic)
that is in your case, but splittings with ";" (not even ",") are accesible through $meta(some field,number) and number starts with 0
2 - answered
3 - You can do it with Playlist Tree
