Topic: placing a new facet under horizontal facets (Read 3123 times) previous topic - next topic
Is it possible to place a new facet underneath my other facets that run horizontally?  Can only seem to put another one in horizontally.
Not at this time
oh well, do you know a way of a getting a panel that will show the items that have been selected in the facets?  I'm basically trying to make an interface that is similar to winamps.  So if i clicked on an album in the album facet it would show the tracks in that album.
You could use the playlist. And set the selection change (found at: Ctrl+P ->Media Library->Facets)  to "send to Facet Playlist".
However, you're not going to be able to exactly replicate the exact functions of Winamp's Media library.
elevatorladylevitateme
I imagine the idea is to get two lists of tracks- one library view, the other a playlist view- after all playlists aren't library viewers.
skogenshamnd: You might be best off just having 3 facets next to each other. It won't look like winamp, but won't be far off in terms of behaviour. You'd need to change the selection change behaviour to none though. One thing is double clicking a track won't send the whole album to a playlist, only that track.
