Topic: Batch wav file trimmer (Read 4387 times) previous topic - next topic
I have a folder of over 1000 wav files of sound recorded from scientific equipment. Each file is 1-3 seconds. The recording automatically started at the start of the event, however every file has at least 0.5 seconds of silence at the end. (however its not a fixed duration in all the files)
I am looking for a program that that can trim this silence from the end of the files automatically.
WavTrim looked promising, however when I load the files in I would get the message: "File too small to be processed (0.94s)!" so that wont work.
Does anyone know of anything similar?
I have got access to a Mac yes, but it appears can't do batch jobs. I got around 1500 files. Thats my problem, i have found software, but nothing that can do it batch.
I do not have the experience myself, but you might take a look at sox. It has a "silence" effect that is designed to remove silence from the beginning, middle, or end of the audio. sox is a command line tool and thus suited for batch processing.
I own SampleManager and it does process multiple files, although I admit to have never done a batch of 1500. Out of curiosity I decided to do a test with 256 files, 2 s in length and shorten them to 1. It took about 6 seconds to process them all.
The "trim beginning below" and "trim end below" options in SM allow to set a threshold (e.g. -90dBFS) to define the trim points. That could be a useful feature for your application. There's a SM demo available if you'd like to try it first.
What do you expect from the "batch" feature ?
