Topic: why --vbr-new produce different file size ? (Read 7660 times) previous topic - next topic
  • CharlyZ
Hello,
I've encoded the same song twice, one with the --vbr-new switch and the other without it.
The song was ripped with EAC and encoded with LAME 3.98.2
ie : one song with :
-V 2 %s %d
and the same song with :
-V 2 --vbr-new %s %d
Then i looked up the size :
Song with --vbr-new : 7 212 327 bytes
Song without --vbr-new : 7 212 317 bytes
The LAME wiki page says that the --vbr-new switch is the default VBR mode and is no longer needed so 'im wondering why the two files are not the same.
Does someone know ?
  • lvqcl
"--vbr-new " is exactly 10 bytes long. So, check "COMMENT" tag in these mp3s.
  • greynol
  • Global Moderator
Ten bytes could simply be a difference in metadata (" --vbr-new" is ten characters long).  Did you compare the audio portion?
  • CharlyZ
The comment field say "Track 5". I let EAC tag my mp3.
I use winamp 2.95 to check tag.
You are surely right about this. So somewhere in the metadata, EAC has written the command line used to encode ?
  • greynol
  • Global Moderator
That's correct.  EAC adds a few extended tags: TENC (EncodedBy), TSSE (EncoderSettings) and TLEN (Length).
  • CharlyZ
How can i see those tag like TENC, TSSE ?
  • greynol
  • Global Moderator
mp3tag/foobar2000/hex editor
  • CharlyZ
Thank you, it's clear for me now
Are you sure?  I've encoded several CDs in 3.98.2 recently, and only TLEN and TSSE are written.  TSSE is always written as "LAME 32bits version 3.98.2 (http://www.mp3dev.org/)" which seems more like what should be written as TENC.  I would like LAME to automatically write my input parameters in the ID3, but it doesn't seem to.
  • greynol
  • Global Moderator
Yes, I'm sure.  It seems like you missed the posts that show the OP is using EAC to tag the files instead of Lame.
This discussion has nothing to do with having Lame write tags.
  • Last Edit: 03 December, 2008, 02:14:51 AM by greynol
Doh!  Stupid me, you're right, I read EAC as LAME for some reason.
