Topic: Curaçao by Br3tt (Read 343252 times) previous topic - next topic
Curaçao by Br3tt
Reply #500
How did you get the extra tag info like "drum & bass" there? I wanted to have something similar with my custom %sub_genre% tag but could not find out how to do it. Also the middle field (msawdos // headsaw recordings) is that the standard %Genre% tag that is used here or did you find a way to change that and use 2 tags in the same field?
Sorry I can't answer your question.
Curaçao by Br3tt
Reply #501
it took me hours to figure that out but was damn satisfying when i did, just kept messing about with parameters to see what they did. its in the ELPlaylist settings under Group Header, i tweaked this under Album Infos:
// Album infos
$font(uni 05_53,6,bold)
$puts(txt.header.color,210-210-220)
$puts(pos0,$add($get(art_size),$add($get(padding_left),5)))
$puts(lg0,30)
$select($len(%el_item_count%),
 $puts(nbtrk,'00'%el_item_count%),
 $puts(nbtrk,'0'%el_item_count%),
 $puts(nbtrk,%el_item_count%))
$drawroundrect($get(pos0),$sub(%el_height%,18),$get(lg0),12,2,2,$get(box_color)-000,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,80),)
$gradientrect($add($get(pos0),1),$sub(%el_height%,17),$sub($get(lg0),1),11,$get(box_color)-020,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,40),)
$drawtextex($get(nbtrk),$get(pos0),$sub(%el_height%,17),$get(lg0),%el_row_height%,00-00-00,hcenter vtop)
$drawtextex($get(nbtrk),$get(pos0),$sub(%el_height%,18),$get(lg0),%el_row_height%,$get(txt.header.color),hcenter vtop)
[b]$puts(pos1,$add($add($get(pos0),$get(lg0)),4))
$if($stricmp('FOO_LASTFM',$left(%path%,10)),
  $puts(lg1,-4)
  $puts(lg1,148)[/b]
$if($stricmp('FOO_LASTFM',$left(%path%,10)),,
  $drawroundrect($get(pos1),$sub(%el_height%,18),$get(lg1),12,2,2,$get(box_color)-000,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,80),)
  $gradientrect($add($get(pos1),1),$sub(%el_height%,17),$sub($get(lg1),1),11,$get(box_color)-020,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,40),)
  $drawtextex($if(%genre%,$upper(%genre%),'N/A'),$get(pos1),$sub(%el_height%,17),$get(lg1),%el_row_height%,00-00-00,hcenter vtop)
  $drawtextex($if(%genre%,$upper(%genre%),'N/A'),$get(pos1),$sub(%el_height%,18),$get(lg1),%el_row_height%,$get(txt.header.color),hcenter vtop)
[b]$puts(pos2,$add($add($get(pos1),$get(lg1)),4))
  $puts(lg2,-4)
  $puts(lg2,39)[/b]
$drawroundrect($get(pos2),$sub(%el_height%,18),$get(lg2),12,2,2,$get(box_color)-000,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,80),)
$gradientrect($add($get(pos2),1),$sub(%el_height%,17),$sub($get(lg2),1),11,$get(box_color)-020,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,40),)
$drawtextex($upper($ext(%filename_ext%)),$get(pos2),$sub(%el_height%,17),$get(lg2),%el_row_height%,00-00-00,hcenter vtop)
$drawtextex($upper($ext(%filename_ext%)),$get(pos2),$sub(%el_height%,18),$get(lg2),%el_row_height%,$get(txt.header.color),hcenter vtop)
[b]$puts(pos3,$add($add($get(pos2),$get(lg2)),4))
  $puts(lg3,-4)
  $puts(lg3,66)[/b]
$drawroundrect($get(pos3),$sub(%el_height%,18),$get(lg3),12,2,2,$get(box_color)-000,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,80),)
$gradientrect($add($get(pos3),1),$sub(%el_height%,17),$sub($get(lg3),1),11,$get(box_color)-020,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,40),)
$drawtextex(%__bitrate%' KBPS',$get(pos3),$sub(%el_height%,17),$get(lg3),%el_row_height%,00-00-00,hcenter vtop)
$drawtextex(%__bitrate%' KBPS',$get(pos3),$sub(%el_height%,18),$get(lg3),%el_row_height%,$get(txt.header.color),hcenter vtop)
//$if(%replaygain_album_gain%,
//$puts(pos4,$add($add($get(pos3),$get(lg3)),4))
//$puts(alb.gain,$if(%replaygain_album_gain%,%replaygain_album_gain%$if($stricmp('fla',$left($upper($ext(%filename_ext%)),3)),,),'0 dB'))
//$puts(lg4,$add($gettextwidth($get(alb.gain)),10))
//$drawroundrect($get(pos4),$sub(%el_height%,18),$get(lg4),12,2,2,$get(box_color)-000,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,80),)
//$gradientrect($add($get(pos4),1),$sub(%el_height%,17),$sub($get(lg4),1),11,$get(box_color)-020,$get(box_color)-$add(%__BOX_ALPHA_GROUP__%,40),)
//$drawtextex($get(alb.gain),$get(pos4),$sub(%el_height%,17),$get(lg4),%el_row_height%,00-00-00,hcenter vtop)
//$drawtextex($get(alb.gain),$get(pos4),$sub(%el_height%,18),$get(lg4),%el_row_height%,$get(txt.header.color),hcenter vtop)
//$puts(pos4,$add($add($get(pos1),$get(lg1)),4))
//$puts(lg4,64)
  [b]$puts(pos4,$add($add($get(pos3),$get(lg3)),4))
  $puts(lg4,-4)[/b]
its mainly to do with the parameters i've put in bold, i cant remember exactly what does what as it was very late lastnight when i finally figured it out. im sure if you compare it to your code you should be able to see what i have done.
as for the tags, i shifted them around so i have %genre% where it is and the other field is %comment% as i put the cat no. & record label in the comments box for all my files ("eg. MSAW005 // Mindsaw Recordings"). hope this helps, & does anyone have any ideas with my previous question?
Curaçao by Br3tt
Reply #502
Thanks, for the code. It's just what I wanted.
Curaçao by Br3tt
Reply #503
in response to my own previous question about adding the remix credit to the track list iv managed to suss it out after many hours of messing & far to many cups of tea  .
it now looks like this:
Curaçao by Br3tt
Reply #505
Hello Br3tt,
first of all - thanks for your work and this nice plugin
I´m an german user and my english is not so well - sorry.
But now my problem.
I use curacao an the fonts are not right.  I must inform you, that I use vista and the dpi is scaled up to 192 dpi.
The product looked like this.
Is it possible to make it looking like usual. When I scale the dpi down ist looked allright. But I use an Sony 40" screen in my livingroom and I can´t read ist when the font ist only normal dpi. (the older or what do say in english....?? an eyeglasses don´t help at this case....)
Sorry- but I can´t fill in the image. Is it possible to send it to your mail-adress - thanks
thank you very much for your time you spend with reading and thinking!
Jörg
Curaçao by Br3tt
Reply #506
Thanks for the great work.
But if I have an sampler the playlist looks really mixed up, because it's grouped by artist and not by album. How can I change this?
EDIT: problem solved^^
Curaçao by Br3tt
Reply #508
Can we use the Wang WSH compiled without SSE?
Also is there a foo_menu_addons compiled without SSE too?
I have an old Celeron that doesn't support SSE.
THANKs
Curaçao by Br3tt
Reply #510
Hi Br3tt,
I had looked for hours but I didn't find an answer.
How will I get the BG Image in the Playlist Panel as sharp and without this litlle colour haze like in Kameleon?
Thanks in advance
Curaçao by Br3tt
Reply #511
Hi Br3tt,
Thanks in advance
Curaçao and Kameleon are very different, i can't point you all the lines to fix in Curaçao to obtain the same render as K. sorry, btw you have to find in the code where i use $gradientrect(...) which give this reflection effect in C, on replace it by $drawblurrect(...,250-250-250-30,7), good luck
Curaçao by Br3tt
Reply #513
Old and new
[a href="http://img9.imageshack.us/img9/1450/curgx4.jpg" target="_blank"]
But those who helped I think were deactivating background filling in ELP Pannel and in Main Panel and drawing BG Image by $drawimage.
I saw a lot of code like Green/Red/Blue Overlay and drawing scanlines.pngs but I don't know what these are doing, I didn't see a difference by deactivating them.
Curaçao by Br3tt
Reply #514
Old and new
cover reflection is bad now, you have deleted a line to keep
Curaçao by Br3tt
Reply #518
ooops.
Sorry DasFox, but afaik there is no wsh or menu addon without sse.
I thought there was WSH by Wang that compiled it with SSE and I'm running it for Ibizia working...
cpuz says I only have MMX so I don't see how the wsh is working then
Curaçao by Br3tt
Reply #521
I have managed to configure Curacao and it's fantastic.
However I have encountered a visual problem. My layout still has the original Foobar2000 header and status bar visible.
How do I remove them?
Curaçao by Br3tt
Reply #522
upper toobar: Preferences > Columns UI > Main-tab > untic show toolbars
lower statusbar: Preferences > Colums UI > status bar-tab > untic show status bar
tip: I got my "show toolbar" assigned to a hotkey in case i do need the toolbar I have quick acces.
Curaçao by Br3tt
Reply #523
Click on VIEW
Untick SHOW STATUS BAR  and SHOW TOOLBARS
Or click the little arrows on the far left top and bottom /\
Curaçao by Br3tt
Reply #524
Maybe a really dumb question:
What do the stars mean in the layout? I thought they indicate the number of plays. But when I played a track 3 times and another twice, the one I played twice has a star and the one I played 3 times not.
Thanks in advance.
