Topic: Curaçao by Br3tt (Read 343512 times) previous topic - next topic
Curaçao by Br3tt
Reply #125
how come this happening to me everytime i start foobar .... where the A,B,C,D etc should be ther's just a white box ? .. any ideas .... it worked just fine with the previous version of Curaçao
Curaçao by Br3tt
Reply #126
Hey, how can we reset the playcounter?
Right click on track -> Properties-> Tab MetaDate -> edit Tag <PLAY_COUNTER>
Does anyone know the name of Milkdrop 's preset which is used in this image?
Curaçao by Br3tt
Reply #127
Falstaff,
This is your best layout yet!  Thank you very much.
There are two things that are problematic.  I see that one has been brought up before.  When using the letters along the top to move within the playlist, the "T" button goes to the first "T" in the 'album artist', which for me is "The All-American Rejects".  The problem is this artist is actually in the "A" section.  I still can't figure out where this needs to be changed.  I have tried all sorts of things within the settings.
The second thing deals with the playback stats and lyrics.  It would be good to make a note for all that these are being automatically added as tags to the actual track.  This is something that I personally do not want to have done, rather I would have them stored in the custom database (for playback) or files (for lyrics).  I know those changes can be made by me, but with everything from the downloads those options were set for automatic tagging.  Just wanted to point it out.
Thanks again...love the config!  Beautiful work.
Curaçao by Br3tt
Reply #128
Hi Falstaff,
is there some way of hiding the playlist, so that one gets only the album art/track info/lyrics  on the left panel, and only the background albumart on the right side panel? I think it would be fine, some playlist show/hide command, to have a more graphical/less graphical interface.
Ys
Rozzo
Curaçao by Br3tt
Reply #129
Hi Falstaff,
Ys
Rozzo
Look at the top right corner of now playing panel...there is a button with a magnifier symbol...press it!
Curaçao by Br3tt
Reply #130
[/quote]
[/quote]
Woow, yes, that's the thing!!! Thansk!!!
Ys
Rozzo
Curaçao by Br3tt
Reply #131
Falstaff
when trying to load the 'curacao_1.1a.fcl' file I get this message:
'Need newer foo_ui_columns'.
Weird because I use the version from your website.
Curaçao by Br3tt
Reply #133
hah I've just wanted to ask the same question
i would tell you if only i known how to see the name of the active vis ?!
anybody knows (special key to display its name ?)
Curaçao by Br3tt
Reply #134
...i would tell you if only i known how to see the name of the active vis ?!
F1 gives you the full menu, F4 gives you the preset title
It's better if you double click the AVS panel to make Milkdrop run full screen
Curaçao by Br3tt
Reply #136
Geiss - Blur Mix 3
thanx for the tip Mike!
It's included in the 8,606 (  ) presets I posted a couple of pages back, or if you just want this one then create a text file called Geiss - Blur Mix 3.milk and dump this lot in it
MILKDROP_PRESET_VERSION=201
PSVERSION=2
PSVERSION_WARP=2
PSVERSION_COMP=2
[preset00]
fRating=2.000000
fGammaAdj=1.0
fDecay=1.0
fVideoEchoZoom=2.0
fVideoEchoAlpha=0.0
nVideoEchoOrientation=0
nWaveMode=6
bAdditiveWaves=0
bWaveDots=0
bWaveThick=0
bModWaveAlphaByVolume=0
bMaximizeWaveColor=1
bTexWrap=1
bDarkenCenter=0
bRedBlueStereo=0
bBrighten=0
bDarken=0
bSolarize=0
bInvert=0
fWaveAlpha=100.0
fWaveScale=3.266313
fWaveSmoothing=0.207000
fWaveParam=0.0
fModWaveAlphaStart=0.750000
fModWaveAlphaEnd=0.950000
fWarpAnimSpeed=1.0
fWarpScale=1.331000
fZoomExponent=1.0
fShader=0.0
zoom=0.999710
rot=0.0
cx=0.5
cy=0.5
dx=-0.005000
dy=0.0
warp=0.000001
sx=1.0
sy=1.0
wave_r=1.0
wave_g=0.999999
wave_b=1.0
wave_x=0.5
wave_y=0.5
ob_size=0.010000
ob_r=0.0
ob_g=0.0
ob_b=0.0
ob_a=0.0
ib_size=0.010000
ib_r=0.25
ib_g=0.25
ib_b=0.25
ib_a=0.0
nMotionVectorsX=64.0
nMotionVectorsY=48.0
mv_dx=0.0
mv_dy=0.0
mv_l=0.0
mv_r=0.350000
mv_g=0.350000
mv_b=0.350000
mv_a=0.0
b1n=0.0
b2n=0.0
b3n=0.0
b1x=1.0
b2x=1.0
b3x=1.0
b1ed=0.25
wavecode_0_enabled=0
wavecode_0_samples=512
wavecode_0_sep=0
wavecode_0_bSpectrum=0
wavecode_0_bUseDots=0
wavecode_0_bDrawThick=0
wavecode_0_bAdditive=0
wavecode_0_scaling=1.0
wavecode_0_smoothing=0.5
wavecode_0_r=1.0
wavecode_0_g=1.0
wavecode_0_b=1.0
wavecode_0_a=1.0
wavecode_1_enabled=0
wavecode_1_samples=512
wavecode_1_sep=0
wavecode_1_bSpectrum=0
wavecode_1_bUseDots=0
wavecode_1_bDrawThick=0
wavecode_1_bAdditive=0
wavecode_1_scaling=1.0
wavecode_1_smoothing=0.5
wavecode_1_r=1.0
wavecode_1_g=1.0
wavecode_1_b=1.0
wavecode_1_a=1.0
wavecode_2_enabled=0
wavecode_2_samples=512
wavecode_2_sep=0
wavecode_2_bSpectrum=0
wavecode_2_bUseDots=0
wavecode_2_bDrawThick=0
wavecode_2_bAdditive=0
wavecode_2_scaling=1.0
wavecode_2_smoothing=0.5
wavecode_2_r=1.0
wavecode_2_g=1.0
wavecode_2_b=1.0
wavecode_2_a=1.0
wavecode_3_enabled=0
wavecode_3_samples=512
wavecode_3_sep=0
wavecode_3_bSpectrum=0
wavecode_3_bUseDots=0
wavecode_3_bDrawThick=0
wavecode_3_bAdditive=0
wavecode_3_scaling=1.0
wavecode_3_smoothing=0.5
wavecode_3_r=1.0
wavecode_3_g=1.0
wavecode_3_b=1.0
wavecode_3_a=1.0
shapecode_0_enabled=0
shapecode_0_sides=4
shapecode_0_additive=0
shapecode_0_thickOutline=0
shapecode_0_textured=0
shapecode_0_x=0.5
shapecode_0_y=0.5
shapecode_0_rad=0.1
shapecode_0_ang=0.0
shapecode_0_tex_ang=0.0
shapecode_0_tex_zoom=1.0
shapecode_0_r=1.0
shapecode_0_g=0.0
shapecode_0_b=0.0
shapecode_0_a=1.0
shapecode_0_r2=0.0
shapecode_0_g2=1.0
shapecode_0_b2=0.0
shapecode_0_a2=0.0
shapecode_0_border_r=1.0
shapecode_0_border_g=1.0
shapecode_0_border_b=1.0
shapecode_0_border_a=0.1
shapecode_1_enabled=0
shapecode_1_sides=4
shapecode_1_additive=0
shapecode_1_thickOutline=0
shapecode_1_textured=0
shapecode_1_x=0.5
shapecode_1_y=0.5
shapecode_1_rad=0.1
shapecode_1_ang=0.0
shapecode_1_tex_ang=0.0
shapecode_1_tex_zoom=1.0
shapecode_1_r=1.0
shapecode_1_g=0.0
shapecode_1_b=0.0
shapecode_1_a=1.0
shapecode_1_r2=0.0
shapecode_1_g2=1.0
shapecode_1_b2=0.0
shapecode_1_a2=0.0
shapecode_1_border_r=1.0
shapecode_1_border_g=1.0
shapecode_1_border_b=1.0
shapecode_1_border_a=0.1
shapecode_2_enabled=0
shapecode_2_sides=4
shapecode_2_additive=0
shapecode_2_thickOutline=0
shapecode_2_textured=0
shapecode_2_x=0.5
shapecode_2_y=0.5
shapecode_2_rad=0.1
shapecode_2_ang=0.0
shapecode_2_tex_ang=0.0
shapecode_2_tex_zoom=1.0
shapecode_2_r=1.0
shapecode_2_g=0.0
shapecode_2_b=0.0
shapecode_2_a=1.0
shapecode_2_r2=0.0
shapecode_2_g2=1.0
shapecode_2_b2=0.0
shapecode_2_a2=0.0
shapecode_2_border_r=1.0
shapecode_2_border_g=1.0
shapecode_2_border_b=1.0
shapecode_2_border_a=0.1
shapecode_3_enabled=0
shapecode_3_sides=4
shapecode_3_additive=0
shapecode_3_thickOutline=0
shapecode_3_textured=0
shapecode_3_x=0.5
shapecode_3_y=0.5
shapecode_3_rad=0.1
shapecode_3_ang=0.0
shapecode_3_tex_ang=0.0
shapecode_3_tex_zoom=1.0
shapecode_3_r=1.0
shapecode_3_g=0.0
shapecode_3_b=0.0
shapecode_3_a=1.0
shapecode_3_r2=0.0
shapecode_3_g2=1.0
shapecode_3_b2=0.0
shapecode_3_a2=0.0
shapecode_3_border_r=1.0
shapecode_3_border_g=1.0
shapecode_3_border_b=1.0
shapecode_3_border_a=0.1
per_frame_1=wave_r = wave_r + 0.350*( 0.60*sin(0.980*time) + 0.40*sin(1.047*time) );
per_frame_2=wave_g = wave_g + 0.350*( 0.60*sin(0.835*time) + 0.40*sin(1.081*time) );
per_frame_3=wave_b = wave_b + 0.350*( 0.60*sin(0.814*time) + 0.40*sin(1.011*time) );
per_frame_4=cx = cx + 0.110*( 0.60*sin(0.374*time) + 0.40*sin(0.294*time) );
per_frame_5=cy = cy + 0.110*( 0.60*sin(0.393*time) + 0.40*sin(0.223*time) );
per_frame_6=decay = decay - 0.01*equal(frame%20,0);
per_frame_7=//zoom = 1;
per_frame_8=//warp = 0;
warp_1=`shader_body
warp_2=`{
warp_3=`    // sample previous frame
warp_4=`    ret = tex2D( sampler_main, uv ).xyz;
warp_5=`    ret += tex2D(sampler_blur2, uv).xyz*0.1;
warp_6=`    ret /= 1.1;
warp_7=`
warp_8=`    // darken over time
warp_9=`    ret -= 0.02;//*= 0.95; //or try: ret -= 0.004;
warp_10=`}
comp_1=`shader_body
comp_2=`{
comp_3=`    ret = tex2D(sampler_main, uv).xyz*1 +
comp_4=`              GetBlur1(uv)*3 +
comp_5=`              GetBlur2(uv)*0 +
comp_6=`              GetBlur3(uv)*0 +
comp_7=`              0;
comp_8=`    ret += GetBlur2( (uv-0.5)*0.333 + 0.5);
comp_9=`    ret *= 1;
comp_10=`}
Curaçao by Br3tt
Reply #137
Need help, i download your plugin and follow every step you say on install notes and it isn't look like you have on your pictures
This is the near i get...not so far but there are missed stuff and i still having the original menu
Curaçao by Br3tt
Reply #138
To get rid of the original menu click on VIEW then untick SHOW STATUS BAR and SHOW TOOLBARS
Curaçao by Br3tt
Reply #139
...img...
follow every step .. really ?
extract for installation notes, first point :
1) Firstly install foobar2000 to its default location of C:\Program Files\foobar2000\
    If you already have Foobar installed to any other location other than this then Curaçao WILL NOT WORK
maybe you have not take care about this important point ?
Curaçao by Br3tt
Reply #140
It works now  really thanks... my mistake
between, very nice skins you have here!!
Curaçao by Br3tt
Reply #142
[quote name='Rozzo' date='Nov 26 2008, 09:42' post='601424']
[/quote]
[/quote]
Ys
Rozzo
[/quote]
Maybe I'm missing something, I see two magnifying glass buttons, one on the lyrics panel and one on the album art.  Which panel is the now playing?  Thanks!
Curaçao by Br3tt
Reply #143
Thanks London Mike and Falstaff. Curacao config is really great with Milkdrop!
With F8 we can edit plugin path and choice preset which is used in Milkdrop.
Curaçao by Br3tt
Reply #144
So bad!
I have 2 problems:
When I add them to my Library, I can't see: FATE OF NORNS, THE CRUSER, ONCE SENT FROM THE GOLDEN HALL in my library :| File type is mp3.
Some albums don't show in playlist and library...
Another, when I start Milkdrop 2.0e, i have a message: The plugin crashed during initialization.
It's don't show in presets list!
Curaçao by Br3tt
Reply #145
Ys
Rozzo
The upper one (album art) is the now playing panel...Just press the buttons and see what they do...they don't bite...
Curaçao by Br3tt
Reply #146
I have a couple of problems which I've been trying to resolve on my own. Without any luck.
The background image is the cover of the album currently playing.
I have my artist images in "../%artist%/%artist%.jpg"
ie. D:\Musikk\Saturnus\Saturnus.jpg
The blue button above the volume control restarts Foobar or something.
Shpeck only finds AVS, while my other (now uninstalled of course) foobar found everying (Milkdrop etc).
Any tips?
Curaçao by Br3tt
Reply #147
Any tips?
i explain with a video where to change artist and cover paths on my website http://br3tt.online.fr
the blue button restart foobar, it do what it is designed for
right click on previous/next buttons around the shpeck panel give you a context menu to select which vis to start at foobar launch, just tick Milkdrop instead of AVS
Curaçao by Br3tt
Reply #148
I've watched that video, and I know where to change it. But I don't know what to change it to =p
Oh, I thought I saw that that was the preferences button or something, in an overview picture. Nvm then^^
And about Shpeck: It doesn't show up anything else but AVS in the preferences.
Thanks for the fast reply.
