Topic: Resampler plugin (Read 504391 times) previous topic - next topic
Re: Resampler plugin
Reply #125
I maybe being an idiot - it has been known - but I can't configure the SoX component in the 'Convert...' dialogue box in f2k v1.1
I can use the component in real time and I must say I'm really impressed with the quality from 24b96k to 16b44k... really impressed.
I'm running f2k v1.1 on win7 Pro (x64), could this be a reason I can't configure the component.
Cheers
Reply #126
What happens when you press "Configure selected" button?
Reply #127
Guess what, It was me being an idiot. A little further digging around led to me realising I need to use the 'DSP Chain Preset'.
I successfully converted a file from 96KHz to 44.1KHz. The bit depth didn't change however from 24bit to 16bit. Is that because I used 'Very High' setting?
BTW... the 'configured selected' button is always greyed out.
Reply #128
No. Click on Output format link in main converter window and set output bit depth to 16.
Select "SoX Resampler" entry in Active DSPs list and this button should be enabled.
Reply #129
Sorry, it still stays greyed out. I've used the DSP chain option and it worked like a treat that way though.
Great stuff, thanks for getting SoX onto windows.
Reply #130
Thank you for your resampler, it has increased the quality but it also adds a small "click" at the beginning.
Configuration : Foobar 1.1.1 with resampler 0.5.5 mod (target resample rate: 176400)
Pc with Intel i5 , USB output in KS with Hiface and V-DAC
Can you do something ?
Thanks in advance
Reply #131
Cannot reproduce the issue. Does the 'click' exist with PPHS or other resamplers?
Reply #132
Yes, but I also noticed recently that the same exists with any DSP plugin. This is probably due to the way Foobar manages the plugins in my particular configuration with the Hiface in Kernel Streaming but I am not expert enough to draw any conclusion. Could be also Hiface's fault.
Have you tried also with a Hiface ?
Reply #133
Not everyone has a Hiface, try switching back to DirectSound to see if you still have that particular problem. Also are you using the new VST bridge?
Reply #134
Which one should I use (0.5.4.4 or 0.5.5) for INTEL SSE2 Pentium 4 non-HyperThreading processor?
Greetings ...
Reply #135
0.5.5 requires SSE3 so you don't have choice
Reply #136
So the bold should be "requires".
Thanks a lot!
Reply #137
So the new foobar2000 resampler should work fine on AMD Athlon PCs ?
Does it clash with any version of Windows?
Reply #138
0.5.4.4 works on any CPU, 0.5.5 requires SSE3 (so it works on almost all modern CPUs).
And of course it doesn't have any particular OS requirements.
Reply #139
Thank you for this great sounding plugin!
In this thread, one slight drawback was pointed out, it's that it seems to attenuate the bass response a bit: http://www.head-fi.org/forum/thread/467853...r-sox-resampler
Any thoughts on that matter please? Because I tend to agree.
Reply #140
Wow, what a thread!
PROS:
-Slightly smoother treble, and definitely less grainy
-Clearer low-level details and easier to hear ambience of the recording
-Larger soundstage (because of the above point)
-Blacker background
-Better dynamics
CONS:
-Slightly less bass
the better focus, clearer vocals, deeper soundstage, better imaging, ambience details retrieval and a sense of "faster" sound and musical flow. but i noticed the sound significantly lost on the weight, cello and violins immediately struck me as too thin sounding and unnatural.
Well, for 44.1 => 96kHz upsampling  the frequency response of SoX resampler is almost flat for 0...20.5 kHz (default settings). So it doesn't attenuate low frequencies.
BTW, version 0.5.6 is out.
Reply #141
Thanks for the swift reply! Yes, I know that sounds weird, but I'd dare saying that the deep bass appears to be less percussive. I've tried it on some old school hip hop, and the TR808 kick drums seem less percussive indeed. But that was with 0.55, I'll try again tomorrow with fresh ears using 0.56.
Reply #142
Fresh ears may or may not help. Unless you are doing a blind test you may hear differences that do not exist. If you expect to hear a difference your brain can fabricate it. You must perform a blind test to avoid that. This has been nicely demonstrated in Ethan Winer's "Audio Myths Workshop" video from the 2009 AES conference: http://www.youtube.com/watch?v=BYTlN6wjcvQ
The audio device may produce a different frequency response when its HW is set to a different sample rate, but usually these differences are not big enough to be audible. However, to completely eliminate the possible effect of the HW working differently with different sample rates you can prepare and compare audio samples that have the same final sample rate.
For instance, if you are resampling from 44.1 to 96 KHz, a good test would be to resample a 44.1 KHz audio sample to 96 KHz once and compare it with a sample that has been resampled three times: 44.1 -> 96 -> 44.1 -> 96 KHz. If resampling causes an audible difference, the difference should more pronounced in the latter sample. You can include a resampler in the DSP options when you convert files with foobar.
Create the two resampled audio files. Compare them with foobar's ABX comparator. If you can detect a difference in a blind ABX test post the test log here and a short clip of the original unresampled audio file (max. 30 s) to the uploads forum.
Reply #143
yeah, thanks for the instructions!
but tbh, the THD in the trebles is too high, and the low end bass sounds less percussive and dull. It still sounds much better than PPHS, this one sounds horrid.
I fully agree with the guys on head-fi, it's very nice for 1h then it gets odd. Upsampling doesn't come for free, never did, never will.
Reply #144
What is the difference of MOD2 and MOD1?
PPHS(ultra)
Speed (x realtime): 26.301
SSRC X
Speed (x realtime): 30.351
MOD 1
Speed (x realtime): 67.376
MOD 2
Speed (x realtime): 366.118
Reply #147
Please watch the video in my link and try the ABX test.
In my experience the mentioned resamplers do not audibly alter the audio quality when they resample from one sample rate to a higher sample rate. A while ago I measured some upsampled test files. With the default settings SoX produced a lot less ringing and other artifacts than PPHS at about 20 kHz, but even the distortion that PPHS produced was likely to be completely inaudible because of the very high frequency. PPHS has been designed to be fine for playback purposes. If you can prove otherwise, please post your ABX logs and test samples.
I just did a quick test. I compared two "Sox" samples. The first one was upsampled once from 44.1 to 96 kHz (using the 24-bit output mode to avoid any increased noise floor) and the second sample was upsampled four times: 44.1 -> 48 -> 64 -> 88.2 -> 96 kHz (all 24-bit).
I couldn't hear any difference in an ABX test. I also measured the difference signal of these two files with Adobe Audition. Its maximum amplitude was -129 dB below 0 dBFS at about the 19.5 - 21.5 kHz frequency range. I.e. much below anything that can be audible. The lower frequencies were even quieter. I can upload the samples if anyone wants to try them.
In general, upsampling is useful only in certain cases when a particular hardware device does not perform well (or not at all) at a certain sample rate.
(Of course you may have other good reasons to resample than audio quality. You may have a receiver that supports only certain sample rates, you may want to mix various audio streams that are of different sample rates, etc.)
Reply #148
Version 0.6.0 was released.
Reply #149
Hi lvcql,
Thanks for all your work on this plugin.
My media PC is connected to a Meridian audio processor and I currently use your plugin to upsample all my lossless CD rips to 88.2kHz in the hope that minimizes the effects of any jitter in the SPDIF connection between my soundcard and the processor.
Meridian and some other high-end companies like Ayre claim that their new upsampling "apodizing" filters can help sound quality by minimizing pre-echo.  Unfortunately, my older Meridian processor doesn't implement these new upsampling filters.
Someone on the Meridian forums has been trying to reproduce a filter which has an impulse response like the Meridian filter using a SOX plugin for their squeezebox server, see: http://www.meridianunplugged.com/ubbthread...5273#Post125273
Unfortunately, the SOX filter which has an impulse response which looks closest to the Meridian one has a passband parameter of 87.5% which is lower than the GUI for your plugin allows.  From reading the thread on the Meridian forums it looks like setting a low passband on these filters helps shape how fast the post-echo tails off.
Is there any possibility you could extend the minimum allowed passband in your plugin down to 85% so that I could try some of the low passband combinations mentioned in the link?
-Ronnie
