Topic: foo_uie_wsh_panel: Custom Volume Bar (Read 24956 times) previous topic - next topic
this thread was for wsh panel. i'm guessing you're using wsh panel mod. the syntax is different and that's why it doesn't work.
you really should stick with the newer mod version though as it's still being developed.
I see, thanks. Anyone want to share their volume bar using an algorithm made for wsh_panel_mod?
wsh panel mod already comes with sample code for a volume control. why not use that? it's right there when you add a new panel to a layout (or you can use the "reset default" button)
