Topic: Low Bitrate VBR sounds worse in 3.98 (Read 12898 times) previous topic - next topic
I initially thought vbr had improved in 3.98 until I looked at the file size.
This showed up when encoding spoken word audiobooks.
3.98 V8 does sound better than 3.97 V8, but it should it gives about the same file size as 3.97 V7.
Using the new floating point, V9.1 gives the same size as the old V8 and sounds much worse.
I know vbr is more quality orientated, and abr is for a more predictable file size, but it struck me strange.
I thought the old vbr-new, which I was using in 3.97, had now just become the default vbr.
It seems a lot more has changed and not for the better.
The increased size adds up over a 16 hour book, think I'll go back to 3.97.
I would be interested to hear any ideas or opinions on this.
Cheers.
Is stereo important to you? If not, give
-V8 -m m --resample 24
a try. Transparent to me and very small file size.
I will give your settings a try, and yes I encode as mono files.
Still very curious as to why the quality/size ratio altered so much.
I've noticed that too. I guess part of the reason is because --strictly-enforce-ISO has been defaulted in 3.98.
Actually, it has been known since quite a while that at below 90kbps, ABR tends to give higher quality than VBR. This does of course not invalidate the regression which you are pointing out. Just mentioning that below 90kbps, the "VBR is better"-mantra is no longer true.
From the Hydrogenaudio wiki:
For very low bitrates, up to 100kbps, ABR is most often the best solution. Use --abr <bitrate> (e.g. --abr 80).
--preset voice is only available in the command line front-end, and is there for compatibility. It is currently mapped to --abr 56 -mm, so that means that the recommendation would be to encode in mono, and use ABR.
Also note, that far as I know, lame is tuned down to 80 kbit/s only.
I did a lot of testing last year, using 3.97 then of course, and read the wiki before settling on V8.
ABR may be better for music at low bitrates, but with audio books they sounded better VBR every time.
It may be because audio books can be very dynamic. A read of todays newpaper stories is very different audio to an actor shouting "RUN FOR COVER" one minute then whispering "i love you babe" next minute as he is about to die for example.
Just did some tests with ABR in 3.98 and still find this to be true, when going for this target quality and size.
@ euphonic, I used ISO enforce in 3.97 too.
I encoded quiet piano music with 3.97 -V7 --vbr-new and 3.98.2 -V7. Bitrates are 52 and 72kbps respectively, and spectrograms show that 3.98 keeps more quiet sounds than 3.97 (left is 3.97, right is 3.98). Is it bad or good -- that's quite a different issue.
My point entirely. With the increase in kbps in the same V setting shown here, wouldn't you expect a better quality?
@ lvqcl, I'd be interested to know how 3.97 at -V6 looked and sounded to you.
            It could be just like 3.98 -V7!
As audiobook are listened at moderate volume this keeping of very quiet sounds IMHO mostly wastes bitrate here. These quiet sounds are usually noise and/or not important really as they are not typically heard anyways under casual listening.
If you raise ATH in LAME by 15 dB (--athlower -15) you may notice no to little difference at a gain of 15-25% lower bitrate IIRC  (at stereo, 44.1 khz). Say from 100kbps to 80 kbps. I used even -25 dB and this seemed good trade-off for my audiobook listening purposes.
However --athlower switch does not work in normal LAME builds. I wish it did because the debug build I've got is a bit slow.
Jetpower, are you saying --athlower - 15 won't work in 3.97? Shame I'd like to try that.
Here is an example of what I found with the two versions, using a short edit of 44.1 kHz mono.
3.98: V9.1 Size 405.9 kb and 51 kbps.
3.97: V8    Size 400.1 kb and 50 kbps.
The 3.98 is noticably worse, although size and kbps are virtually equal.
I know I'm using setting not commonly used, the current poll on what people use shows that.
But if this result extends to higher quality V settings as well, what has really improved with 3.98?
I had this LAME linked in this post .
It has those weird experimental options enabled:)  - but is a third slower than rarewares LAME.
Now that I tried it again it seems you can even go as low as -40dB and at the same time adjust -V quality  to get good bitrate.
Aside of the fact that two files with equal size will have equal kbps (since one is a reflection of the other, not counting metadata like an ID3 tag), you are telling the encoder to do different things in those commandlines.
Let me explain it:
It is a known fact that lame 3.98 has increased the average bitrate of the -V settings. Am I saying that it needs more bitrate to do the same? Yes, almost. The tweakings it has received are affecting the whole range of the -V setting. For the same setting, it looks as an improvement in quality, but for the same bitrate (as you found out) especially on the highest and lowest ends, the results translate to more than one point of the -V setting, and as such, applying lower quality setting parameters.
Of course, with a content like voice, it makes sense to use VBR, since the encoder could adapt to the demands, keeping the bitrate quite low. ABR does not help too much, since the ABR algorithm, at low bitrates, will not switch much far from the target bitrate, and as such not really adapting to quality demands.
The only thing that i can tell you is that currently 3.97 fits your scenario better, and that no effort of tweaking 3.98 will give a similar result.
Is this going to be addressed? I can't tell for sure. It sure there is enough difference for them to check what has happened (requiring 25% more of bitrate for a similar quality is just too much), and probably part of the problem is shown in that screenshot that lvqcl posted. (Screenshots do not show quality, but can show defects), which is precisely the effect that the setting jetpower mentioned has.
Those settings are just in the debug builds, since they can be used, at the indication of the developers, to know if an internal parameter should be better adjusted to another value, or if it has relation to an artifact.
Free experimentation of those settings is not encouraged, nor is it recommended. It is especially important to notice that where a setting can show no difference to an encoded piece, it can change another quite much.
LAME here is overly careful with ATH because it cannot foresee listening conditions. As the mp3 will be for personal use I see no problem with using experimental switches and this one in particular. I think the goal here is not transparency but optimal compression - to cram as much voice recording as possible with acceptable quality on the device one uses.
Jaz, thanks for the detailed answer.
When 3.98 was officially released it was stated vbr-new was now the default. Obviously the experimentation with vbr-new has gone on beyond what it was in 3.97, rather than just vbr-new as it was then being the new default. I can see how the changes have come about.
I will stick with 3.97 for the moment, it is more efficient for what I'm doing.
According to the LAME Wiki V9.1 would be at 24 kHz sampling rate while V8 is at 32 kHz sampling rate. The lowpass frequency is also greatly reduced with V9.1. Such a step change is a major difference when you maintain constant bitrate in this way.
Your experience indicates that the bang-for-your-buck (or bang-for-your-bitrate) tradeoff in LAME 3.98.2 has worsened for speech in the low quality region. It's plausible that music will have fewer annoying artifacts and might be improved despite the loss of higher frequencies (which is at least a consistent degradation) when you target the same bitrate, or it might be that perceived quality per bitrate in non-transparent regions has suffered from changes that maintain transparency better in the higher-quality -V settings.
3.97 (V9) - yes, but 3.98.2 - 22.05 kHz. (tested just now).
What you are seeing is the workaround for the "sandpaper noise problem" at work. We may revisit it with 3.99 and maybe poeple interested at low quality settings take a look at beta versions then.
I had been using Razorlame and LAME 3.97b2 combo for many years, and was very happy - but when I saw 3.98.2 I thought, "Whoa, I'm way behind the times." So I installed and did some tests.
Most of my LAME transcoding involves speech - specifically AM radio broadcasts, which are clearly recorded by people who don't know what they're doing with LAME. One show in particular, is typically 55MB in size.
I then retranscode using my aforementioned combo set using -V 9 --vbr-new, which gives me great, nearly transparent, if not transparent quality, and the resultant filesize is ~22MB-24MB, a substantial savings.
Last night I used Razorlame with the latest 3.98.2 and was surprised beyond belief... using -v9 as the setting, the filesize ballooned upwards by 43%!
So I took a "War of the Worlds" radio broadcast I have as an mp3, and expanded it to a wave file: 306791KB (per Windows explorer). Using 3.97b2, resultant mp3 filesize was 8822KB, and sounded like all my other AM radio transcodings - virtually transparent. So I tried Razorlame with 3.98.2. First, as most may have read, the bit-rate bars do not function at all, and the progress bars do not function as well - stay at 0%. After transcoding was finished, I was astounded to see the -v9 3.98.2 filesize had ballooned to 12654KB, again, a 43% increase in size!
I have not tried 3.98.2 with music yet, but it will be interesting - I usually use -v2 for most stuff, so will do a few tests to see if the filesize differences are noticeable. I can't imagine real-world listening experience would change perceptively enough for a human to notice.
I'll have to say, a 43% increase in filesize for same-setting, low-grade speech/AM radio broadcast material sucks donkey-balls.
DW
Windows XP sp3
I have been using 3.97 and recently thought oh! there is the new 3.98 for me.... I have been encoding a lot of audio books lately and have been disappointed with the inreased file sizes from 3.98.  I am sticking to 3.97
For audio books I do
-mm --vbr-new -V9 --lowpass 9.5
When V9 makes the quality drop noticeable and I switch to V8...
