Topic: APE+CUE problems (Read 3132 times) previous topic - next topic
APE+CUE problems
Hmm, it seems that beta3 doesn't detect the length of the *last* track in the album, if the album is APE image referenced by CUE.
OS: Win XP
As far as I remember, beta2 had no such issues
APE+CUE problems
Everything works ok here. Maybe your cue files are corrupted?
Take a look at the console after you load the cuesheet.
APE+CUE problems
Oh yeah, my mistake, I renamed the .ape to .cue.ape (then excluded .cue.ape from my library so it doesn't show up) then forgot to point the .cue to the new file. Silly me, it's working now.
APE+CUE problems
My files worked fine for me for years till beta 3.  May be the problem is related to CUE name/extension.  Problematic ones have ".ape.cue" extension, and problem disappears after changing the extension to ".cue".
Reverting back to ".ape.cue" could lead to problem again, but not for all my images. Weird.
One more issue, it seems that Album List (I'm using Default UI) doesn't locate APE files with *embedded*, however if I drag'n'drop such file into playlist  if plays fine. (I have no masks in "exlude" both in Gnereal and Media Library).
BTW, killing both database.dat and database.fpl and re-creating database at startup solved all my problems.
