Topic: CUETools versions 1.9.5 through 2.1.6 (Read 1951334 times) previous topic - next topic
CUETools versions 1.9.5 through 2.1.5 (current)
Reply #2300
Hope to see the new Monkey's Audio Latest Version 4.12 (June 26, 2013)  being added to CUETools v2.1.5 before it gets officially released.
Reply #2301
Hello.
in 2.1.5 version history "FLACCL: hi-res audio support", but error "Exception: Audio format is not Red Book PCM." appear.
Please help to solve this. It happens with such file, that's when I try it recompress in FLAC...
Format                              : FLAC
Format/Info                        : Free Lossless Audio Codec
Duration                            : 2mn 26s
Bit rate mode                      : Variable
Bit rate                              : 1 485 Kbps
Channel(s)                          : 2 channels
Sampling rate                      : 48.0 KHz
Bit depth                            : 24 bits
Stream size                        : 25.9 MiB (100%)
Writing library                      : libFLAC 1.2.1 (UTC 2007-09-17)
Reply #2303
You are probably using an old version, even if it's 2.1.5 - there have been several updates to 2.1.5. Download it again here: http://www.cuetools.net/install/CUETools_2.1.5.zip
Pretty sure its the newest (installed in last 2 weeks), but will re-install and try again.
Reply #2304
FLACCL: hi-res audio support refers to the CUETools.FLACCL.cmd.exe command-line tool.
CUETools.exe still only accepts PCM (or lossless) Red Book audio input. You will still receive an "Exception: Audio format is not Red Book PCM" in CUETools if you try to input other than 16-bit, 44.1kHz stereo.
korth
Reply #2305
How do I update to 2.1.5? Do I simply replace the files?
Reply #2306
The zip file contains a folder named CUETools_2.1.5
You can simply unzip to the same parent folder as the previous version and update any references or shortcuts you made for the previous version to the new folder name. You can run as you did the previous version unless you ran as a portable application, then you'll need to copy/paste the CUE Tools and CUERipper sub-folders from the previous version to the CUETools_2.1.5 folder and delete the user_profiles_enabled file from the CUETools_2.1.5 folder before you run.
Note that there are still a few minor bugs in 2.1.5 so you might want to keep the previous version (and folder) until 2.1.5 is stable.
You can (as you suggested) copy and replace the files in the previous version's folder if you prefer. If you run as a portable application make sure to delete the user_profiles_enabled file if it gets added back to the folder.
korth
Reply #2307
Downloaded fresh last night. In repair mode, CT is stripping ALL track AND disc number padding now. So the original files meta-data has tracks 01,02,03, total tracks 09... and disc 01, total 01. CT strips the padding, so they are 1,2,3... total 9, disc 1, total 1...
In repair mode, CT to should copy everything exactly and only repair the audio stream.
Reply #2308
What about adding cross-pressing verification for AccurateRip v2
Reply #2309
Need help with newest version (2.1.5)
When I'm trying to convert file with FLACCL encoder, I get this message: "Exception: Build failed with error code BUILD_PROGRAM_FAILURE"
When I'm converting using libFLAC everything is fine. On previous version (2.1.4) FLACCL worked just fine.
What's the matter?
Reply #2310
Usually with BUILD_PROGRAM_FAILURE there should be a more detailed error message, a line of source code or something. No such luck?
CUETools 2.1.6
Reply #2312
What GPU are you using?
CUETools 2.1.6
Reply #2313
nvidia 9800GT
Reply #2314
What's the matter?
I have the same problem with my 8600GT, it works on a previous beta of 2.1.5 (downloaded in May) and on 2.1.4.  I get the same error message with no further detail.
EDIT: I updated to the latest nVidia drivers, but this made no difference.
Reply #2316
In that case, where can I find previous 2.1.5 beta?
Reply #2317
I will probably update it in a few days.
CUETools 2.1.6
Reply #2318
When you convert files you ripped with CueRipper, the file selection dialog shows two items to convert in each folder: the .cue file and the collection of audio files themselves. Simply proceeding means that CueTools will encode everything twice and ask you whether you want to overwrite. Am I missing something, or is the only way to not do things twice to go through and manually deselect something in every folder?
Reply #2319
Assuming you're using 'Multiselect Browser' input mode (you didn't specify), select only the CUE file(s) instead of having CUETools process the whole folder (don't put a check in the folder(s)).
Edit: browser type
korth
Reply #2320
That's hardly practicable if you're trying to select a large set of files though, something like "process .cue only" option would be nice to have.
Reply #2321
Not sure why it wasn't announced but there is a new update
that should fix a few 'critical' bugs that involved 'Exception' messages.
Other requests and minor bug fixes may be addressed in a future update. There is no need to 'bump' your requests at this time.
Looks like libFLAC was also updated to version 1.3.0 and some new hardware support for FLACCL.
See Changelog for more info.
korth
Reply #2322
Just tested the newest 2.1.5, got an exception closing CUETools:
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
  at JDP.frmCUETools.SaveSettings()
  at System.Windows.Forms.Form.WmClose(Message& m)
  at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
  at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5466 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
CUETools
Assembly Version: 2.1.5.0
Win32 Version: 2.1.5.0
CodeBase: file:///D:/Program%20Files/CUETools/CUETools.exe
Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CUETools.Processor
CodeBase: file:///D:/Program%20Files/CUETools/CUETools.Processor.DLL
CUETools.Codecs
CodeBase: file:///D:/Program%20Files/CUETools/CUETools.Codecs.DLL
System.Xml
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
CUETools.CTDB
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///D:/Program%20Files/CUETools/CUETools.CTDB.DLL
CUETools.Compression
CodeBase: file:///D:/Program%20Files/CUETools/CUETools.Compression.DLL
CUETools.Ripper
CodeBase: file:///D:/Program%20Files/CUETools/CUETools.Ripper.DLL
CUETools.Codecs.APE
Assembly Version: 1.0.4933.39970
Win32 Version:
CodeBase: file:///D:/Program%20Files/CUETools/Plugins%20(x64)/CUETools.Codecs.APE.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
CUETools.Codecs.FLAC
Assembly Version: 1.5.0.0
Win32 Version:
CodeBase: file:///D:/Program%20Files/CUETools/Plugins%20(x64)/CUETools.Codecs.FLAC.dll
CUETools.Codecs.HDCD
CodeBase: file:///D:/Program%20Files/CUETools/Plugins%20(x64)/CUETools.Codecs.HDCD.dll
CUETools.Codecs.LAME
CodeBase: file:///D:/Program%20Files/CUETools/Plugins%20(x64)/CUETools.Codecs.LAME.dll
CUETools.Codecs.TTA
Win32 Version:
CodeBase: file:///D:/Program%20Files/CUETools/Plugins%20(x64)/CUETools.Codecs.TTA.dll
CUETools.Codecs.WavPack
Assembly Version: 1.2.0.0
Win32 Version:
CodeBase: file:///D:/Program%20Files/CUETools/Plugins%20(x64)/CUETools.Codecs.WavPack.dll
CUETools.Compression.Rar
CodeBase: file:///D:/Program%20Files/CUETools/Plugins%20(x64)/CUETools.Compression.Rar.dll
Bwg.Hardware
Assembly Version: 0.0.7.1
Win32 Version: 0.0.7.1
CodeBase: file:///D:/Program%20Files/CUETools/plugins/Bwg.Hardware.DLL
Bwg.Logging
CodeBase: file:///D:/Program%20Files/CUETools/plugins/Bwg.Logging.DLL
Bwg.Scsi
CodeBase: file:///D:/Program%20Files/CUETools/plugins/Bwg.Scsi.DLL
CUETools.Codecs.ALAC
CodeBase: file:///D:/Program%20Files/CUETools/plugins/CUETools.Codecs.ALAC.DLL
CUETools.Codecs.FLACCL
CodeBase: file:///D:/Program%20Files/CUETools/plugins/CUETools.Codecs.FLACCL.DLL
CUETools.Codecs.FLAKE
CodeBase: file:///D:/Program%20Files/CUETools/plugins/CUETools.Codecs.FLAKE.DLL
CUETools.Codecs.WMA
CodeBase: file:///D:/Program%20Files/CUETools/plugins/CUETools.Codecs.WMA.DLL
CUETools.Compression.Zip
CodeBase: file:///D:/Program%20Files/CUETools/plugins/CUETools.Compression.Zip.DLL
CUETools.Ripper.SCSI
CodeBase: file:///D:/Program%20Files/CUETools/plugins/CUETools.Ripper.SCSI.DLL
CUETools.CDImage
CodeBase: file:///D:/Program%20Files/CUETools/CUETools.CDImage.DLL
ICSharpCode.SharpZipLib
Assembly Version: 0.85.5.452
Win32 Version: 0.85.5.452
CodeBase: file:///D:/Program%20Files/CUETools/plugins/ICSharpCode.SharpZipLib.DLL
OpenCLNet
CodeBase: file:///D:/Program%20Files/CUETools/plugins/OpenCLNet.DLL
WindowsMediaLib
Assembly Version: 1.1.0.23204
Win32 Version: 1.1.0.23204
CodeBase: file:///D:/Program%20Files/CUETools/plugins/WindowsMediaLib.DLL
6oq6hbqq
te50tyyf
msvcm90
Assembly Version: 9.0.30729.6161
Win32 Version: 9.00.30729.6161
CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251/msvcm90.dll
l-assjk4
-i8f3dpc
kyxcywfq
2cgziuyt
qccjsjxl
lzcxqq3p
-jszqn-w
uxcsqipy
r3yagzb8
ui7jjavn
bguemp1v
agol2ljd
CUEControls
CodeBase: file:///D:/Program%20Files/CUETools/CUEControls.DLL
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
CUETools.AccurateRip
CodeBase: file:///D:/Program%20Files/CUETools/CUETools.AccurateRip.DLL
lgksrzqf
w6uyiyzz
taglib-sharp
Assembly Version: 2.0.4.0
Win32 Version: 2.0.4.0
CodeBase: file:///D:/Program%20Files/CUETools/taglib-sharp.DLL
Accessibility
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
CUETools.Parity
CodeBase: file:///D:/Program%20Files/CUETools/CUETools.Parity.DLL
ufymrm6i
Freedb
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///D:/Program%20Files/CUETools/Freedb.DLL
klx3gtra
Only once though, maybe it has something to do with me having 2.1.4 config info previously
Reply #2323
A small remark - if the 'Offset' field is filled and I attempt to create a CUE sheet of the selected album (using the 'Create CUE Sheet' checkbox), I will get the 'Writing a non-zero offset...' warning, which I don't think has any meaning as far as CUE sheet creation goes. I am not encoding the tracks or anything.
Reply #2324
New version didn't fix my problem, still getting that message
