Topic: CUETools versions 1.9.5 through 2.1.5 (current) (Read 1348407 times) previous topic - next topic
  • radu
Reply #1675
Gregory,
Can you please add support for XLD logs when cross checking the calculated CRC values against the values from log.
Also, this log:
Exact Audio Copy V0.99 prebeta 5 from 4. May 2009
EAC extraction logfile from 8. October 2009, 17:21
Various / Diggin In The Crates - Rare Studio Masters: 1993-1997
Used drive  : LITE-ON COMBO SOHC-4836K  Adapter: 4  ID: 0
Read mode   : Secure
Utilize accurate stream : Yes
Defeat audio cache   : Yes
Make use of C2 pointers : Yes
Read offset correction   : 6
Overread into Lead-In and Lead-Out   : No
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations   : Yes
Used interface   : Native Win32 interface for Win NT & 2000
Gap handling : Appended to previous track
Used output format   : User Defined Encoder
Selected bitrate : 320 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files\Exact Audio Copy\Flac\flac.exe
Additional command line options : -V -8 -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" %s
TOC of the extracted CD
Track |  Start  |  Length  | Start sector | End sector
1  |  0:00.00 |  4:18.54 | 0 | 19403
2  |  4:18.54 |  3:43.72 | 19404 | 36200
3  |  8:02.51 |  4:14.73 | 36201 | 55323
4  | 12:17.49 |  4:10.57 | 55324 | 74130
5  | 16:28.31 |  4:33.02 | 74131 | 94607
6  | 21:01.33 |  4:30.01 | 94608 |  114858
7  | 25:31.34 |  4:01.74 | 114859 |  133007
8  | 29:33.33 |  3:34.14 | 133008 |  149071
9  | 33:07.47 |  4:27.48 | 149072 |  169144
  10  | 37:35.20 |  4:06.11 | 169145 |  187605
  11  | 41:41.31 |  4:33.35 | 187606 |  208115
  12  | 46:14.66 |  3:22.61 | 208116 |  223326
  13  | 49:37.52 |  3:35.74 | 223327 |  239525
  14  | 53:13.51 |  4:38.54 | 239526 |  260429
  15  | 57:52.30 |  3:41.33 | 260430 |  277037
  16  | 61:33.63 |  3:22.72 | 277038 |  292259
  17  | 64:56.60 |  2:38.61 | 292260 |  304170
  18  | 67:35.46 |  3:17.67 | 304171 |  319012
  19  | 70:53.38 |  4:04.21 | 319013 |  337333
  20  | 74:57.59 |  4:17.27 | 337334 |  356635
Track 13
Filename D:\Transportation Folder\music\EACRips\The Lump Lump [Nubian Mix] [Featuring Brand Nubian].wav
Peak level 93.8 %
Track quality 100.0 %
Test CRC FF237B77
Copy CRC FF237B77
Accurately ripped (confidence 1)  [C55AC37B]
Copy OK
All tracks accurately ripped
No errors occurred
End of status report
EAC extraction logfile from 8. October 2009, 17:58
Read mode   : Secure
Quality : High
Add ID3 tag : No
Track  1
Filename D:\Transportation Folder\music\EACRips\Bring It On [Remix].wav
Pre-gap length  0:00:02.00
Peak level 95.5 %
Test CRC E1DB0FFA
Copy CRC E1DB0FFA
Accurately ripped (confidence 1)  [15F12A21]
Copy OK
Track  2
Filename D:\Transportation Folder\music\EACRips\You Know Now [Remix].wav
Peak level 99.9 %
Test CRC 11DC7E8A
Copy CRC 11DC7E8A
Accurately ripped (confidence 1)  [D7D19EA9]
Copy OK
Track  3
Filename D:\Transportation Folder\music\EACRips\Caught Up in the Game.wav
Peak level 99.9 %
Track quality 99.9 %
Test CRC 70E20EC9
Copy CRC 70E20EC9
Accurately ripped (confidence 1)  [6A4B44B5]
Copy OK
Track  4
Filename D:\Transportation Folder\music\EACRips\Respect the Architect [Remix] [Featuring Bahamadia].wav
Peak level 99.9 %
Test CRC 10C12DDE
Copy CRC 10C12DDE
Accurately ripped (confidence 1)  [DEA84470]
Copy OK
Track  5
Filename D:\Transportation Folder\music\EACRips\Daaam! [Remix].wav
Peak level 92.8 %
Test CRC 91332F1C
Copy CRC 91332F1C
Accurately ripped (confidence 1)  [5BABBDE7]
Copy OK
Track  6
Filename D:\Transportation Folder\music\EACRips\Problemz.wav
Peak level 99.9 %
Test CRC DE393D21
Copy CRC DE393D21
Accurately ripped (confidence 1)  [323FBB65]
Copy OK
Track  7
Filename D:\Transportation Folder\music\EACRips\Rockin’ It.wav
Peak level 99.9 %
Test CRC FFB7D5F7
Copy CRC FFB7D5F7
Accurately ripped (confidence 1)  [F8BAE829]
Copy OK
Track  8
Filename D:\Transportation Folder\music\EACRips\MVP [Remix #2].wav
Peak level 99.9 %
Test CRC 9E1329B5
Copy CRC 9E1329B5
Accurately ripped (confidence 1)  [9E39A0CE]
Copy OK
Track  9
Filename D:\Transportation Folder\music\EACRips\North South East West [Remix].wav
Peak level 100.0 %
Test CRC 22C3E1C4
Copy CRC 22C3E1C4
Accurately ripped (confidence 1)  [BCD16C8E]
Copy OK
Track 10
Filename D:\Transportation Folder\music\EACRips\Story of My Life.wav
Peak level 99.9 %
Test CRC 7EF48E77
Copy CRC 7EF48E77
Accurately ripped (confidence 1)  [DFAD6256]
Copy OK
Track 11
Filename D:\Transportation Folder\music\EACRips\You Can’t Front [Featuring Lord Finesse and Sadat X].wav
Peak level 90.7 %
Test CRC 7AD5C362
Copy CRC 7AD5C362
Accurately ripped (confidence 1)  [11CD821B]
Copy OK
Track 12
Filename D:\Transportation Folder\music\EACRips\Life’s a Bitch [Remix #2] [Featuring AZ].wav
Peak level 99.9 %
Test CRC 41D842ED
Copy CRC 41D842ED
Accurately ripped (confidence 1)  [4680D18E]
Copy OK
Track 13
Peak level 93.8 %
Test CRC FF237B77
Copy CRC FF237B77
Copy OK
Track 14
Filename D:\Transportation Folder\music\EACRips\Lyrics [Remix].wav
Peak level 100.0 %
Test CRC A2ACA0D3
Copy CRC A2ACA0D3
Accurately ripped (confidence 1)  [3739A3BD]
Copy OK
Track 15
Filename D:\Transportation Folder\music\EACRips\Mad Izm ['95 Remix].wav
Peak level 99.9 %
Track quality 99.2 %
Test CRC 69F96744
Copy CRC 69F96744
Accurately ripped (confidence 1)  [207ED13D]
Copy OK
Track 16
Filename D:\Transportation Folder\music\EACRips\Cut That Weak Shit [Remix] [Featuring Kwaze Modoe and Royal Flush].wav
Peak level 100.0 %
Test CRC BBBB801A
Copy CRC BBBB801A
Accurately ripped (confidence 1)  [50085E7B]
Copy OK
Track 17
Filename D:\Transportation Folder\music\EACRips\Love Child.wav
Peak level 91.2 %
Test CRC 93C15DD0
Copy CRC 93C15DD0
Accurately ripped (confidence 1)  [2F48F58A]
Copy OK
Track 18
Filename D:\Transportation Folder\music\EACRips\Guess Who’s Back  [Remix].wav
Peak level 79.3 %
Test CRC C504CF40
Copy CRC C504CF40
Accurately ripped (confidence 1)  [D28482D3]
Copy OK
Track 19
Filename D:\Transportation Folder\music\EACRips\The Difference.wav
Peak level 99.7 %
Test CRC CFFC2800
Copy CRC CFFC2800
Accurately ripped (confidence 1)  [A8C789BB]
Copy OK
Track 20
Filename D:\Transportation Folder\music\EACRips\I Be [Remix].wav
Peak level 99.9 %
Test CRC D2CC24CF
Copy CRC D2CC24C
Accurately ripped (confidence 1)  [9608E61A]
Copy OK
No errors occurred
gives this result:
[CUETools log; Date: 11/28/2011 12:35:19 AM; Version: 2.1.2a]
[CTDB TOCID: Sni6BQSyPWfYy4WIratT49CZjfs-] found.
[ CTDBID ] Status
[fc346744] (3/3) Accurately ripped
[AccurateRip ID: 003ac3c9-03581ae2-63129314] found.
Track  [ CRC ] Status
 01 [15f12a21] (3/3) Accurately ripped
 02 [d7d19ea9] (3/3) Accurately ripped
 03 [6a4b44b5] (3/3) Accurately ripped
 04 [dea84470] (3/3) Accurately ripped
 05 [5babbde7] (3/3) Accurately ripped
 06 [323fbb65] (3/3) Accurately ripped
 07 [f8bae829] (3/3) Accurately ripped
 08 [9e39a0ce] (3/3) Accurately ripped
 09 [bcd16c8e] (3/3) Accurately ripped
 10 [dfad6256] (3/3) Accurately ripped
 11 [11cd821b] (3/3) Accurately ripped
 12 [4680d18e] (3/3) Accurately ripped
 13 [c55ac37b] (3/3) Accurately ripped
 14 [3739a3bd] (3/3) Accurately ripped
 15 [207ed13d] (3/3) Accurately ripped
 16 [50085e7b] (3/3) Accurately ripped
 17 [2f48f58a] (3/3) Accurately ripped
 18 [d28482d3] (3/3) Accurately ripped
 19 [a8c789bb] (3/3) Accurately ripped
 20 [9608e61a] (3/3) Accurately ripped
Track Peak [ CRC32  ] [W/O NULL] [  LOG  ]
 --  100.0 [41E90A22] [30DB2FA7]
 01  95.5 [E1DB0FFA] [4C93568A] [FF237B77]: CRC32 for track 13
 02  99.9 [11DC7E8A] [9430DF94] [E1DB0FFA]: CRC32 for track 1
 03  99.9 [70E20EC9] [0CE504C1] [11DC7E8A]: CRC32 for track 2
 04  99.9 [10C12DDE] [D2CE7E0C] [70E20EC9]: CRC32 for track 3
 05  92.8 [91332F1C] [5FAA2C0D] [10C12DDE]: CRC32 for track 4
 06  99.9 [DE393D21] [C0A4441B] [91332F1C]: CRC32 for track 5
 07  99.9 [FFB7D5F7] [76BF93CE] [DE393D21]: CRC32 for track 6
 08  99.9 [9E1329B5] [FAFD9C98] [FFB7D5F7]: CRC32 for track 7
 09  100.0 [22C3E1C4] [1802AB60] [9E1329B5]: CRC32 for track 8
 10  99.9 [7EF48E77] [02B7C375] [22C3E1C4]: CRC32 for track 9
 11  90.7 [7AD5C362] [69D22E63] [7EF48E77]: CRC32 for track 10
 12  99.9 [41D842ED] [9B2D246D] [7AD5C362]: CRC32 for track 11
 13  93.8 [FF237B77] [40269DC6] [41D842ED]: CRC32 for track 12
 14  100.0 [A2ACA0D3] [37C7D3FA] [FF237B77]: CRC32 for track 13
 15  99.9 [69F96744] [CDDB47C6] [A2ACA0D3]: CRC32 for track 14
 16  100.0 [BBBB801A] [4F181A17] [69F96744]: CRC32 for track 15
 17  91.2 [93C15DD0] [ED833F35] [BBBB801A]: CRC32 for track 16
 18  79.3 [C504CF40] [39A86EC3] [93C15DD0]: CRC32 for track 17
 19  99.7 [CFFC2800] [69DFDDDE] [C504CF40]: CRC32 for track 18
 20  99.9 [D2CC24CF] [EA552F37] [CFFC2800]: CRC32 for track 19
Maybe you can also fix this. It shouldn't be complicated.
  • Last Edit: 04 December, 2011, 05:44:57 AM by Jan S.
  • fadsplat
Reply #1676
How can I change the output folder?
I clicked the icon next to Output, but it won't let me select “Browse”.
'Browse' should be available when the Input is either 'Folder browser' or 'Hide browser'. 'Multiselect Browser' and 'Drag'n'drop mode' require a 'template' because more than one disc can be selected.
Thanks. Setting that Output folder is fiddly. I changed to 'Folder browser', navigated the tree and double-clicked a folder or somehow selected it. Somehow it caused CueTools to rename my folder to "My Music". I deleted that folder, and recreated my original folder. Again, through navigating somehow magically Output now shows the path I wanted, but I'm not sure how I did it.
  • wildsnake
Reply #1677
this problem appeared some time ago, before that everything was good.
i can convert only one album in batch mode, then one of those errors appears.
OpenCL - AMD APP. CPU - Phenon 9550
  • Miguk
Reply #1678
I replaced built-in FLACCL with version 0.4 (exe with command-line parameters). All files were written without any error message. :-)
  • wildsnake
Reply #1679
i did the same as you, but still got errors.
  • B00ze
Reply #1680
Good day.
I recently ripped a CD with EAC (1 bad track; with my Pioneer DVD this is VERY frequent even on pristine CDs) and got curious about a bit at the end of EAC's log that mentionned I could repair the rip with CUETools. So I installed CT and several hours later, I repaired the bad track. Now here's the funny part, I re-verified the repaired CD and I noticed that for the repaired track, the LOG column in accurip's log is still different than all the other tracks - How can it be different, if the track is repaired shouldn't I see "CRC32" in that column?
Here's the verify log (this is a verify of the repaired CD) - Notice that now all tracks are "accurately ripped" (Track #11 was no match before the repair) but also notice for Track #11, at the bottom of the log, how it as a CRC in the "LOG" column instead of the word "CRC32":
[CUETools log; Date: 2011-12-10 14:29:44; Version: 2.1.2a]
[CTDB TOCID: RphOu8zFqN8urSL9dgCcCc.eJw4-] found.
       [ CTDBID ] Status
       [9a7c658f] (40/40) Accurately ripped
[AccurateRip ID: 002059de-0142cf9a-b60fc70d] found.
 01    [3d4b3ecd] (43/48) Accurately ripped
 02    [2fcc4a72] (44/49) Accurately ripped
 03    [e4623e80] (44/49) Accurately ripped
 04    [41d701e1] (44/49) Accurately ripped
 05    [925ce0ab] (44/49) Accurately ripped
 06    [4c8ba048] (43/48) Accurately ripped
 07    [7d5d262d] (44/49) Accurately ripped
 08    [9204c60b] (43/48) Accurately ripped
 09    [a19bdd39] (42/47) Accurately ripped
 10    [54b393fa] (41/46) Accurately ripped
 11    [394d2c39] (41/46) Accurately ripped
 12    [51e27348] (44/49) Accurately ripped
 13    [fbb54872] (41/48) Accurately ripped
AccurateRip v2:
 01    [df71b6dc] (05/48) Accurately ripped
 02    [8d5715f1] (05/49) Accurately ripped
 03    [a32b3e53] (05/49) Accurately ripped
 04    [0df00ef9] (05/49) Accurately ripped
 05    [736d9c5f] (05/49) Accurately ripped
 06    [b1b27c8c] (05/48) Accurately ripped
 07    [f5172bcc] (05/49) Accurately ripped
 08    [3012cc94] (05/48) Accurately ripped
 09    [0936db11] (05/47) Accurately ripped
 10    [80d7d66d] (05/46) Accurately ripped
 11    [8a750164] (05/46) Accurately ripped
 12    [2c577ea9] (05/49) Accurately ripped
 13    [609ecad2] (05/48) Accurately ripped
 --  99.9 [9A01E1DB] [98AFC778]
 01  99.9 [649F0294] [4893435D]  CRC32
 02  99.9 [3CA35CD6] [6D879D3D]  CRC32
 03  99.9 [3EE18882] [5E33A531]  CRC32
 04  99.9 [3DAD00F8] [62E8E57C]  CRC32
 05  99.9 [9FEBA1A9] [E970764B]  CRC32
 06  99.9 [EE4D5485] [66F1747A]  CRC32
 07  99.9 [4159AD04] [7CE498DD]  CRC32
 08  99.9 [176884D2] [FBDCBAD5]  CRC32
 09  99.9 [7DB7747F] [7FE2184C]  CRC32
 10  99.9 [422F708B] [F6A80CA3]  CRC32
 11  99.9 [3BD1FD8D] [119E2454] [8727C71E] <-- Why is this track still different?
 12  99.9 [D2DE2076] [611E0883]  CRC32
 13  99.9 [CF700673] [DE531C8B]  CRC32
Also, can you guys help me readthose CT logs, specifically:
[CTDB TOCID: RphOu8zFqN8urSL9dgCcCc.eJw4-] found. <-- Table of Content ID, this I get.
       [ CTDBID ] Status <-- Why is CTDBID (9a7c658f) not same as TOCID?
       [9a7c658f] (40/40) Accurately ripped <-- What does this mean? Does this mean my rip is accurate?
[AccurateRip ID: 002059de-0142cf9a-b60fc70d] found. <-- Yet another ID, how many IDs does each CD have?
 01    [3d4b3ecd] (43/48) Accurately ripped <-- Is this a compare against "AccurateRip ID: 002059de-0142cf9a-b60fc70d" ?
AccurateRip v2: <-- What does this mean, why does it NOT say "AccurateRip v2 ID: blabla", there's no ID in v2?
I realize I'm asking a lot, but while I understand the lines that display each track's accuracy, most of the rest of the log I do not understand. Why so many IDs (TOCID, CTDBID, AccurateRip ID), why no ID next to "AccurateRip v2" and for that matter, why v1 and v2? And what does that LOG column mean at the end of the log?
Thank you much for any help.
Best Regards,
  • korth
Reply #1681
Wow that's a lot of questions. You couldn't find the answers somewhere in the other 67 pages?
This can be found [a href='index.php?act=findpost&pid=616364']here[/a]. This section is provided for checking the files you have against the EAC log file found in the same folder as the files. It is telling you that (after repair) the CRC found in your EAC log file for track 11 is different than the actual file CRC.
This can be found [a href='index.php?act=findpost&pid=703224']here[/a].
Different database. This section of the log is from the AccurateRip database (used by permission).
  • Last Edit: 11 December, 2011, 10:42:22 AM by korth
korth
  • B00ze
Reply #1682
Thanks alot for the lesson, I'd read the first ~10 pages and quit; I will go read the other 57 pages...
Best Regards,
  • B00ze
Reply #1683
Good day.
Alright, I've started reading this thread again (I'm at page 14 right now, this is taking forever!) while ripping CDs with EAC and I just noticed something. Are any of you aware of some issue with the CueTools plugin in EAC where it does not get called at all for some rips? I find that being able to repair rips is just awesome, and so I want to make sure I participate in submitting to CueTools whenever EAC does a good rip. However, sometimes there is no CueTools text at the bottom of the EAC log at all. Anyone know why?
Here's the EAC log in question; the rip is accurate, and not found in CTDB (I verified with CueTools) yet no CueTools entry at bottom of EAC log:
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 11. December 2011, 16:16
Rush / Power Windows
Used drive  : PIONEER DVD-RW  DVR-116D  Adapter: 0  ID: 1
Read mode              : Secure
Make use of C2 pointers : No
Read offset correction                      : 96
Selected bitrate                : 768 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : E:\Apps\WinXp\Media\EAC\FLAC\FLAC.EXE
Additional command line options : -8 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "BAND=%albuminterpret%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" %hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
       1  |  0:00.33 |  5:37.05 |        33    |    25312
       2  |  5:37.38 |  5:06.37 |    25313    |    48299
       3  | 10:44.00 |  5:07.38 |    48300    |    71362
       4  | 15:51.38 |  6:11.42 |    71363    |    99229
       5  | 22:03.05 |  6:20.38 |    99230    |  127767
       6  | 28:23.43 |  5:15.60 |    127768    |  151452
       7  | 33:39.28 |  5:10.62 |    151453    |  174764
       8  | 38:50.15 |  5:55.28 |    174765    |  201417
Track  1
     Filename F:\Data\Public\RECODE\Rush - Power Windows - 01 - The Big Money.wav
     Pre-gap length  0:00:02.33
     Peak level 97.7 %
     Extraction speed 4.7 X
     Test CRC D59C2942
     Copy CRC D59C2942
     Accurately ripped (confidence 3)  [93C07912]  (AR v1)
     Copy OK
Track  2
     Filename F:\Data\Public\RECODE\Rush - Power Windows - 02 - Grand Designs.wav
     Pre-gap length  0:00:00.70
     Peak level 83.6 %
     Extraction speed 2.9 X
     Track quality 99.7 %
     Test CRC 4D7083B1
     Copy CRC 4D7083B1
     Accurately ripped (confidence 3)  [C4BBED12]  (AR v1)
     Copy OK
Track  3
     Filename F:\Data\Public\RECODE\Rush - Power Windows - 03 - Manhattan Project.wav
     Pre-gap length  0:00:00.27
     Peak level 92.0 %
     Extraction speed 5.7 X
     Test CRC F6E1D407
     Copy CRC F6E1D407
     Accurately ripped (confidence 3)  [775D8EF2]  (AR v1)
     Copy OK
Track  4
     Filename F:\Data\Public\RECODE\Rush - Power Windows - 04 - Marathon.wav
     Pre-gap length  0:00:02.47
     Peak level 78.1 %
     Extraction speed 5.9 X
     Test CRC 5A16693B
     Copy CRC 5A16693B
     Accurately ripped (confidence 3)  [50D9CE95]  (AR v1)
     Copy OK
Track  5
     Filename F:\Data\Public\RECODE\Rush - Power Windows - 05 - Territories.wav
     Pre-gap length  0:00:01.59
     Peak level 78.8 %
     Extraction speed 6.3 X
     Test CRC F9E4B3C2
     Copy CRC F9E4B3C2
     Accurately ripped (confidence 3)  [93EDCC52]  (AR v1)
     Copy OK
Track  6
     Filename F:\Data\Public\RECODE\Rush - Power Windows - 06 - Middletown Dreams.wav
     Pre-gap length  0:00:01.07
     Peak level 78.4 %
     Extraction speed 5.8 X
     Test CRC FBDBDEE1
     Copy CRC FBDBDEE1
     Accurately ripped (confidence 3)  [ED6A9F3D]  (AR v1)
     Copy OK
Track  7
     Filename F:\Data\Public\RECODE\Rush - Power Windows - 07 - Emotion Detector.wav
     Pre-gap length  0:00:00.02
     Peak level 91.3 %
     Extraction speed 7.3 X
     Test CRC 6EFD2BD3
     Copy CRC 6EFD2BD3
     Accurately ripped (confidence 3)  [4D4F40EB]  (AR v1)
     Copy OK
Track  8
     Filename F:\Data\Public\RECODE\Rush - Power Windows - 08 - Mystic Rythms.wav
     Pre-gap length  0:00:00.67
     Peak level 85.6 %
     Extraction speed 3.0 X
     Track quality 99.8 %
     Test CRC 64F48D47
     Copy CRC 64F48D47
     Accurately ripped (confidence 3)  [ECE4AA53]  (AR v1)
     Copy OK
No errors occurred
==== Log checksum 98AA8AA90805A95CA9140AE9E8C59332863B702BC6EB8D9177DD9BE9B5114091 ====
Is this a bug in EAC? Is there a thread on Hydrogen just for the EAC plugin? This happens alot where there is no CueTools entry at end of EAC log :-(
For now I re-rip such CDs with CueRipper just so it gets submitted (then discard the rip, I've already ripped it with EAC) but this is not a good solution...
Thank you much.
Best Regards,
PS: Why is this reply 10000 characters wide (no word-wrap?)
  • Last Edit: 11 December, 2011, 06:19:34 PM by B00ze
  • mjb2006
Reply #1684
It's a known issue with the CTDB plug-in for EAC:
When copying selected tracks instead of an image, CTDB plugin doesn't process a CD if it has a HTOA (i.e. when first track does not start at 0:00:00).
Re: word wrap, it is being adversely affected by the "Additional command line options" line in your codebox. Not your fault.
Most info about CTDB, CUETools, CUERipper and the log files is only learned by reading third-party tutorials, having questions answered in forums, and just playing around with the software. It's on my to-do list to beef up the documentation in Gregory's wiki, and I did try to do that a little bit, but it's still in need of a lot of work. Feel free to register and lend a hand.
  • Last Edit: 11 December, 2011, 09:03:54 PM by mjb2006
  • sauvage78
Reply #1685
Sorting stuff on my HDD I found this huuuge log ... I couldn't resist posting it  It's Iron Maiden - 2010 - The Final Frontier.
[CUETools log; Date: 11/12/11 22:36:36; Version: 2.1.2a]
[CTDB TOCID: qUrQvKCekqMe8BhgyPUESesZhRM-] found.
       [ CTDBID ] Status
       [2fd2ac1c] (7/8) Accurately ripped
       [56b88b51] (1/8) Differs in 1582 samples @03:28:50,03:54:50,04:00:50,04:06:22,04:14:49,04:18:50,04:37:08,04:38:40,04:38:58,04:39:36,05:07:24,
05:08:18,05:09:11,05:10:73,05:14:39,05:15:33,05:17:17,05:18:08,05:21:51,05:29:57,05:36:62,05:40:11,05
:43:06,05:52:18,06:14:39,06:18:05,06:22:49,06:23:42,06:27:12,06:28:04,06:28:71,06:35:12,06:37:30,06:4
0:42,06:42:27,06:44:27,06:57:46,07:02:02,07:13:18,07:49:37,07:53:40,08:02:66,08:03:58,08:09:72,08:18:
59,08:23:15,08:42:06,08:44:57-08:44:58,08:45:09,08:45:14,08:45:47,08:47:52,08:48:53-08:48:54,08:49:22,08:49:49,08:49:61,08:49:67-08:50:00,08:50:05-08:50:10,08:50:25,08:50:43,08:51:23,08:51:40,08:52:50,08:53:13,08:55:13,08:55:53,08:56:45,08:56:55,0
8:56:67,08:56:73,08:57:32,08:57:39,08:59:21,08:59:65,09:02:08,09:19:07,09:22:10,09:25:45,09:28:50,09:
29:04,09:29:48,09:30:35,09:33:19,09:34:34,09:35:18,09:36:05,09:36:34,09:37:48,09:38:17,09:39:73,09:42
:58,09:43:58,09:52:20,09:52:49,09:55:68,09:57:30,10:00:15,10:00:25,10:00:41,10:01:72,10:05:31-10:05:32,10:06:16,10:06:30,10:07:00,10:08:15,10:08:59,10:09:13,10:09:72,10:10:06,10:10:56,10:12:50-10:12:51,10:13:64,10:15:30,10:15:74,10:17:53,10:20:03,10:21:16,10:21:45,10:22:45,10:23:68,10:25:47,1
0:25:54,10:26:16,10:27:22,10:27:43,10:28:11,10:28:26,10:32:59,10:35:71,10:36:12,10:36:25,10:39:23,10:
41:17,10:42:72,10:43:42,10:45:43,10:46:28,10:47:41,10:49:24,10:49:53,10:50:51,10:51:06,10:53:32,10:53
:47,10:53:61,10:55:14,10:56:08-10:56:10,10:56:23,10:59:50,11:00:02,11:01:30,11:01:60,11:02:58-11:02:60,11:02:72,11:05:53,11:08:27,11:09:08,11:10:35,11:11:18,11:12:70,11:13:65,11:14:32,11:14:45-11:14:49,11:15:33,11:17:37,11:19:57-11:19:59,11:24:26-11:24:30,11:25:39,11:26:52,11:27:07,11:27:58,11:29:26,11:30:21,11:31:26,11:33:46,11:35:12,11:38:35,1
1:41:07,11:43:69,11:47:09,11:47:66,11:48:16,11:48:47,11:49:71,11:50:04,11:51:09,11:52:69,11:54:02-11:54:04,11:57:56,11:59:08,12:00:03,12:01:57,12:03:64,12:04:18,12:16:70,12:17:51,12:18:18,12:23:20,1
2:37:13,12:37:42,12:39:62,12:48:70,12:49:22,12:55:26,12:56:06,12:56:62,13:17:04,13:17:20,13:22:54,13:
29:56,13:30:10,13:35:06,13:38:42-13:38:43,13:46:67,13:51:04,13:51:31,13:56:14,13:57:35,14:02:26,14:03:06,14:04:71,14:08:22,14:09:16,1
4:10:68,14:15:18,14:19:67,14:31:72,14:34:57,14:37:54,14:42:12,15:00:15,15:22:53,16:55:70,17:11:05,17:
12:41,17:21:00,17:27:04,17:29:26,17:30:70,17:32:57,17:33:23,17:33:64,17:36:10,17:37:61,17:38:28,17:41
:18,17:44:05,17:56:02,17:56:46,17:57:53,18:00:02,18:05:12,18:05:63,18:08:30,18:08:51,18:08:62,18:09:3
7,18:09:43-18:09:47,18:13:59,18:14:48-18:14:49,18:19:19,18:21:30,18:22:66,18:24:25,18:25:13,18:27:64,18:28:29,18:32:11,18:33:57,18:35:31,1
8:36:56,18:42:39,18:45:05,18:46:41,18:49:01,18:54:35,18:59:29,19:09:39,19:18:68,19:19:34,19:20:00,19:
20:60,19:24:29,19:25:16,19:28:61,19:31:42,19:33:02,19:33:71-19:33:72,19:34:34,19:35:65,19:36:33,19:37:40,19:38:32,19:38:49,19:40:23,19:41:72,19:43:24,19:46:27,1
9:47:35,19:47:56,19:51:23,19:51:33,19:52:36,19:52:67,19:55:51,19:56:58,19:57:23,19:57:64,19:58:31,19:
59:37,20:00:45-20:00:46,20:01:21,20:04:72,20:06:02-20:06:03,20:06:44,20:07:10-20:07:11,20:08:17,20:08:47,20:09:12,20:09:40,20:11:15,20:13:51,20:16:71,20:25:37,20:26:50,20:33:59,2
0:38:17,20:39:68,20:41:42,20:46:20,20:51:14,21:26:53,21:54:01,21:56:45,21:59:46,22:12:11,22:13:39,22:
16:02,22:20:14,22:27:73,22:28:69,22:32:39,22:32:53,22:44:22,23:26:43,23:32:50,23:34:44,23:38:63,23:41
:04-23:41:05,23:43:09,23:44:06,23:46:25,23:49:67,23:51:00,24:08:50,24:14:46,24:26:59,24:34:62,25:01:31,2
5:05:57,25:10:73,25:18:07,25:19:61,25:21:24,25:22:62,25:23:15,25:24:24,25:25:04,25:26:36,25:31:58,25:
43:06,25:45:40,25:47:14,25:50:18,25:50:32,25:50:59,25:52:64,25:54:27,25:56:17,26:10:26,27:16:05,27:52
:41,28:00:74,28:07:37,28:08:62,28:09:33,28:10:40,28:11:53-28:11:55,28:12:50,28:22:56,28:43:70,28:44:51,29:19:53,29:23:73,29:41:37,29:45:03,30:25:52,30:33:37,3
0:39:39,30:44:73,30:46:60,30:50:00,30:55:44,30:55:71,30:58:67,31:00:37,31:01:67,32:55:59,34:10:42,34:
19:39,34:21:56,34:25:32,34:26:67,35:07:40,35:10:72,35:27:63,35:56:01,36:19:41,37:01:33,37:11:53,37:58
:05,38:00:52,38:27:68,39:12:46,39:13:26,39:13:52,39:39:17,39:41:37,39:41:62,40:03:45,40:06:52,40:09:0
5,40:09:27,40:10:27,41:24:56,41:27:03,41:28:46,41:37:00,41:40:31,41:44:16,41:46:08,41:47:53,41:48:55,
41:49:20-41:49:22,41:51:36-41:51:38,41:54:31,41:54:57,42:00:16,42:00:55,42:02:74,42:04:70-42:04:71,42:05:49,42:06:66,42:10:50,42:13:74-42:14:00,42:17:25-42:17:26,42:19:24,42:20:46,42:24:74,42:26:57-42:26:62,42:28:29,42:29:06,42:29:31,42:31:10-42:31:11,42:31:60,42:32:36,42:33:01-42:33:02,42:33:23,42:34:25,42:35:13,42:35:63-42:35:65,42:36:13,42:36:39,42:38:08-42:38:09,42:40:34,42:41:08,42:42:33-42:42:34,42:43:54,42:44:32,42:45:55,42:46:29-42:46:31,42:47:55,42:57:29,43:02:42,43:08:30,43:26:07,43:30:27,43:32:25,43:33:03-43:33:05,43:35:62,43:44:06,43:45:25,43:45:51,43:52:28,43:53:65,43:55:04-43:55:09,43:55:57-43:55:58,43:58:40,43:59:15,43:59:26,43:59:51-43:59:53,44:00:14,44:00:38-44:00:43,44:01:15,44:02:43,44:03:43,44:04:63,44:05:67,44:08:37,44:10:35,44:12:24,44:13:09,44:13:59,4
4:15:10,44:15:46-44:15:50,44:16:33,44:28:26,44:39:13,44:42:22,44:48:06,44:53:57,45:02:20,45:03:02,45:09:25,45:10:68,4
5:16:13,45:16:36,45:18:07,45:19:15,45:20:71,45:23:47-45:23:48,45:25:70,45:26:08,45:30:40,45:35:06,45:37:27,45:38:66,46:39:10,46:48:35,46:56:61,47:05:02,4
7:09:51,47:13:19,47:14:45-47:14:46,47:14:58,47:17:48,47:18:51,47:18:74,47:19:62,47:20:02,47:21:18,47:23:69,47:25:19,47:29:15,4
7:31:03,47:31:51,47:33:20,47:35:74,47:36:35,47:37:10-47:37:11,47:42:46,47:53:22,50:27:72,50:31:18,50:32:64,50:35:18,50:36:03,50:37:49,50:39:17,50:39:49,5
0:40:02,50:40:62-50:40:65,50:42:02,50:43:74,50:44:58,50:45:42,50:45:74,50:46:55,50:47:10,50:48:54,50:49:69,50:51:06,5
0:53:06,50:54:19,50:58:43,50:59:58,51:00:44,51:01:01,51:02:13,51:02:44,51:02:72,51:04:39,51:05:22,51:
06:06-51:06:07,51:07:51,51:08:62-51:08:64,51:09:16,51:10:00,51:12:21,51:13:07,51:13:65,51:15:33,51:17:02,51:17:61,51:19:17,51:20:11,5
1:21:27,51:21:53,51:22:24,51:24:03,51:24:62,51:25:32-51:25:33,51:26:01,51:28:00,51:28:58,51:28:63,51:29:41,51:31:10,51:31:68,51:32:23,51:32:52,51:32:67-51:32:68,51:34:18,51:35:23,51:35:61,51:36:63,51:37:30,51:38:15,51:38:72,51:40:17,51:40:41,51:41:56,5
1:42:08-51:42:09,51:42:68,51:44:35,51:44:65,51:45:18,51:46:02-51:46:03,51:47:43,51:47:54,51:48:47,51:48:53,51:49:07,51:49:38,51:49:66,51:50:49,51:51:31,51:52:13,5
1:53:51,51:55:72,51:56:55,51:57:37,51:57:66,51:59:00-51:59:01,51:59:57,52:00:09,52:00:30,52:02:02,52:02:53,52:05:16,52:06:56,52:08:24,52:10:47,52:12:72,5
2:14:41,52:16:23,52:17:47,52:19:11-52:19:12,52:21:35,52:22:33,52:22:61,52:24:24,52:24:39,52:28:00,52:28:27,52:29:40-52:29:42,52:32:15,52:32:71,52:35:46,52:35:73,52:36:14,52:36:24,52:37:37,52:38:74,52:39:56,52:42:59,5
2:43:41,52:44:22,52:45:05-52:45:06,52:45:62,52:48:07,52:48:64,52:50:24,52:51:21,52:52:62,52:54:29,52:54:71,52:57:31,52:57:74,5
2:58:71,52:59:69,53:00:20,53:00:35,53:01:29,53:01:56,53:05:39,53:07:00,53:07:55,53:08:37,53:10:00-53:10:01,53:11:38,53:11:67,53:12:18,53:13:53,53:14:35,53:17:33,53:22:20,53:24:60-53:24:61,53:25:52-53:25:54,53:27:32-53:27:33,53:28:16,53:29:22,53:30:19,53:30:63,53:31:58,53:33:20-53:33:21,53:34:56,53:36:61,53:37:54,53:39:01,53:41:19,53:42:55,53:43:34,53:44:14,53:44:70,53:46:05,5
3:47:11,53:47:32,53:48:46,53:52:23,53:53:03,53:55:71,53:59:21,54:00:01,54:00:27,54:01:08,54:01:60,54:
03:37,54:04:27,54:07:23,54:08:47,54:09:62,54:13:62,54:14:31,54:15:74,54:17:30,54:18:63,54:20:22,54:23
:12,54:24:40,54:27:12,54:33:59,54:35:17,54:38:08,54:38:63,54:39:42-54:39:43,54:40:21,54:40:74,54:43:11,54:43:65,54:46:00,54:46:53,54:48:41,54:49:17,54:53:35,54:59:00,5
5:00:29,55:04:47,55:06:35,55:09:34,55:10:14,55:13:72,55:19:67,55:22:08,55:27:20,55:28:55,55:34:00,55:
37:58,55:38:39,55:40:00,55:44:53,55:45:22,55:46:17,55:46:60,55:47:54,55:50:36,55:51:16,55:56:04,55:56
:31,55:57:13,55:59:27,56:01:01,56:01:41,56:03:49,56:05:62,56:11:03,56:11:44,56:22:05,56:24:35,56:28:0
1,56:28:56,56:31:48,56:32:25,56:33:04,56:35:16,56:38:02,56:42:23,56:43:01,56:44:32,56:50:11,56:51:45,
56:52:23,57:00:20,57:00:73,57:05:03,59:47:36,60:06:55,60:09:71,60:20:53,60:25:42,60:27:14,60:47:71,60
:56:26-60:56:27,61:01:27,61:01:63,61:03:61,61:03:74,61:04:51,61:06:53,61:10:53,61:11:24,61:14:51,61:22:37,6
1:49:43,62:07:22,62:11:04,62:13:14,62:24:62,62:35:73,62:40:14,62:42:31,62:45:54,62:50:71,62:59:47,63:
06:59,63:13:00,63:18:43,63:27:19,63:43:45,63:50:72,63:51:46,63:53:48,64:00:29,64:01:03,64:01:53,64:02
:41,64:02:68,64:05:42,64:07:55,64:08:13,64:08:29,64:09:04,64:09:66,64:10:27,64:10:40-64:10:41,64:11:26,64:18:16,64:22:21,64:22:35,64:23:23,64:29:23-64:29:24,64:29:60,64:30:35,64:31:10,64:31:70-64:31:71,64:32:32,64:33:19-64:33:20,64:58:37,65:10:39,65:15:61,65:16:27,65:19:45,65:25:44,67:52:13,68:22:72,68:27:04,68:32:45,6
8:33:10,68:34:48,68:36:49,68:38:12,69:26:54,69:45:62,69:57:69,70:14:56,70:15:72,70:20:27,70:25:38,70:
27:31,70:27:54,70:34:29,70:38:62,70:44:61,70:52:50,70:53:22,70:55:60,71:01:69,71:02:55,71:03:15,71:06
:33,71:18:70,71:19:41,71:45:42,71:56:27,71:59:31,72:01:43,72:11:24,72:19:64,72:21:10,72:26:48,72:56:5
1,73:26:14,73:35:74,73:54:37,74:04:39-74:04:40,74:08:60,74:16:34,74:44:45,74:45:22,74:46:25,74:47:30,74:48:63,74:52:28
[AccurateRip ID: 001ad3a9-00d82b34-8911f60a] found.
 01    [4bbc4d50] (005/216) Accurately ripped
 02    [f25786ab] (005/216) Accurately ripped
 03    [97baf0f5] (005/219) Accurately ripped
 04    [61914777] (004/217) Accurately ripped
 05    [3b7444dc] (004/217) Accurately ripped
 06    [74a56f5c] (004/215) Accurately ripped
 07    [6d565c22] (004/217) Accurately ripped
 08    [0ad94419] (004/217) Accurately ripped
 09    [bb396870] (003/214) Accurately ripped
 10    [7b3de080] (004/214) Accurately ripped
Offsetted by 19:
 01    [9b8654e5] (146/216) Accurately ripped
 02    [39ca0056] (148/216) Accurately ripped
 03    [c45c9420] (149/219) Accurately ripped
 04    [e92e5920] (149/217) Accurately ripped
 05    [e0d3fb82] (149/217) Accurately ripped
 06    [e4b427d0] (149/215) Accurately ripped
 07    [5f59da47] (149/217) Accurately ripped
 08    [e97eb561] (149/217) Accurately ripped
 09    [b5513330] (147/214) Accurately ripped
 10    [d1ad382b] (146/214) Accurately ripped
Offsetted by 25:
 01    [41476abf] (039/216) Accurately ripped
 02    [8fb5f386] (039/216) Accurately ripped
 03    [d4b5e8d6] (039/219) Accurately ripped
 04    [eabd64d4] (038/217) Accurately ripped
 05    [fb5cce76] (040/217) Accurately ripped
 06    [dec9d720] (038/215) Accurately ripped
 07    [e1f1e44f] (038/217) Accurately ripped
 08    [5dfcb992] (038/217) Accurately ripped
 09    [4996aca4] (038/214) Accurately ripped
 10    [557cfaf6] (038/214) Accurately ripped
Offsetted by 1:
 01    [b237dd3d] (002/216) Accurately ripped
 02    [0eff8c46] (000/216) No match
 03    [c9c4a85a] (002/219) Accurately ripped
 04    [9030c7e9] (002/217) Accurately ripped
 05    [6cba691a] (000/217) No match
 06    [e99b5c78] (000/215) No match but offset
 07    [e5027213] (002/217) Accurately ripped
 08    [255745b7] (002/217) Accurately ripped
 09    [f877c6cf] (002/214) Accurately ripped
 10    [cfe775cc] (002/214) Accurately ripped
 --  100,0 [88B62A44] [E6A2450B]  CRC32
 01  100,0 [88DB9127] [3F9BFE55]
 02  100,0 [6304AE32] [05C232FC]
 03  100,0 [3C640803] [414C3EA4]
 04  100,0 [CA556664] [3DD68C85]
 05  100,0 [9A9F48CF] [7A6AF916]
 06  100,0 [88108C86] [F767304D]
 07  100,0 [72450FED] [4C3D2B60]
 08  100,0 [0ECE4025] [874490CB]
 09  100,0 [DC06AF9F] [0B960262]
 10  100,0 [A4604796] [2784E74D]
Rip & Check: EAC Secure [Low/C2]+CUETools [AR Confidence 2+]
NAS (Backup): Flac -4 (for Speed) | CDImage+CUE with F2K
DAP (Playback): Opus 128Kbps | Tracks with F2KM on Android (LG G5)
Video: AV1 (2160p30@24Mbps-2Pass) Asap !!!
  • B00ze
Reply #1686
Ah, I should've re-checked that wiki; I do have it opened in one of the tabs in browser, but never thought to click on the plugin page (right now I'm trying to get thru this thread; I'm at page 32 right now). There's a lot of information to absorb.
Well then for now I guess I'll just use CueRipper to submit (CueTools is supposed to ask to submit at some point, there is a setting for this in advanced, but I haven't figured out how to get it to submit yet).
Thanks again for the information.
Best Regards,
  • korth
Reply #1687
Action: Verify will do it but only if AccurateRip confidence is 2+ and there is no current matching CTDB entry. You cannot add to an existing CTDB entry using Verify. Of course Submit to CTDB has to be True under Advanced. I apologize for being terse earlier.
  • Last Edit: 12 December, 2011, 10:24:56 PM by korth
korth
  • B00ze
Reply #1688
Good evening Korth.
I'm at page 46 of this thread, slowly moving forward.
I've been ripping more CDs and I find that CueRipper is WAY better than EAC when it comes to bad pressings. Where EAC detects 5-20 (yes, 20) "Suspicious" positions for some tracks and fails AR test, CueRipper detects 1 such position (or none) and passes AR test. I will post more about this later, but lets just say it is far better at error recovery than EAC (even with the 5*16 re-reads). CR is also much faster.
About submitting with CueTools:
I can't get it to submit; here is a verify which has a total confidence of 4, yet CueTools is not asking for submit (and yes, it's turned on in advanced settings):
[CUETools log; Date: 2011-12-15 00:32:52; Version: 2.1.2a]
Pregap length 00:00:32.
[CTDB TOCID: aZdHKV0MXmQGVnILK0gQMr5Xytk-] disk not present in database.
[AccurateRip ID: 00081a88-002b8b53-46085e06] found.
 01    [84595bf2] (2/6) Accurately ripped
 02    [f801ab27] (2/6) Accurately ripped
 03    [19ce2654] (2/6) Accurately ripped
 04    [57eb60f1] (2/6) Accurately ripped
 05    [f9360dff] (2/6) Accurately ripped
 06    [557ae3b4] (2/6) Accurately ripped
Offsetted by 736:
 01    [39fe3b12] (2/6) Accurately ripped
 02    [2b7a8607] (2/6) Accurately ripped
 03    [608b7354] (2/6) Accurately ripped
 04    [411ad9d1] (2/6) Accurately ripped
 05    [3727b09f] (2/6) Accurately ripped
 06    [67d86dba] (2/6) Accurately ripped
Offsetted by 816:
 01    [a6c7cdc2] (0/6) No match but offset
 02    [b112ca57] (0/6) No match but offset
 03    [89a006d4] (0/6) No match but offset
 04    [54e2cb21] (0/6) No match but offset
 05    [bde3588f] (0/6) No match but offset
 06    [def9a21d] (0/6) No match but offset
 --  89.6 [1B2B1222] [50BA4722]
 01  82.1 [F57FE8CA] [223180AE]  CRC32
 02  89.6 [DA634237] [554CECE9]  CRC32
 03  85.9 [B1A48338] [4E59B2DF]  CRC32
 04  78.6 [119B0E77] [3F293967]  CRC32
 05  82.7 [DA443803] [6BAC3CF0]  CRC32
 06  89.6 [1E6ABF03] [C797114A]  CRC32
Am I mis-understanding something?
Thank you much.
Best Regards,
  • sauvage78
Reply #1689
If I recall well CT will only submit if "Verify/Default" is used not "Verify/Only If Found". Maybe you're using "Verify/Only If Found".
  • B00ze
Reply #1690
WooHoo, Success!
Merci beaucoup Sauvage, c'etait ca! I needed to verify at default. I dont need "Only If Found" anyway, I rip CDs one at a time and verify the rip immediately afterwards - i.e. I never batch verify anything. I think CT just defaulted to selecting that mode and I never dared touch it.
I guess it makes sense; you dont want the submit pop-up to show when you are verifying a thousand songs...
Best Regards,
  • B00ze
Reply #1691
Ah, found it! page 49 of the thread:
Only-If-Verify will not submit
  • B00ze
Reply #1692
The slider on the right is the ripping method. Secure means that the track is is read twice and the checksums are compared to see if the rip is clean. Paranoid mode will rip the track 4 times and compare the checksums of each rip to make sure they match.
That does not seem entirely accurate; when I rip in paranoid mode I see "Ripping@..." once, then Retry 1 and Retry 2; no Retry 3... So I would say Paranoid reads 3 times (on sectors that have no errors). Paranoid might allow more retries than secure when there -are- errors, I haven't tried yet.
CUERipper v2.1.2 Copyright (C) 2008-10 Gregory S. Chudov
This is free software under the GNU GPLv3+ license; There is NO WARRANTY, to
the extent permitted by law. <http://www.gnu.org/licenses/> for details.
Usage    : CUERipper.exe <options>
-S, --secure             secure mode, read each block twice (default);
-B, --burst              burst (1 pass) mode;
-P, --paranoid           maximum level of error correction;
Regards,
PS: Anyone know how to make CueRipper start in Paranoid mode? It resets to secure everytime I start it. I tried SecureMode=2 -> Ng; Tried ParanoidMode=1 but no go either. I don't think it has the ability to retain Paranoid in its settings file...
  • Last Edit: 15 December, 2011, 11:37:15 PM by B00ze
  • korth
Reply #1693
SecureMode=2 would be the correct setting but CUERipper does not start in Paranoid mode. Why would you even want to use this mode on anything other than a badly scratched or scuffed disc? Secure mode will read each sector a minimum of 2 times and up to 32 times if the reads don't match.
korth
  • sauvage78
Reply #1694
A feature that I would like to be in CT is the ability to check & update .accurip against the database in order to check lossy encoded files for which you know the lossless ID/CRC.
Exemple:
1- Rip a CD losslessly then check against AR/CTDB database, unfortunately the CD is not in database either because it is rare or new.
2- Unfortunately you don't have the HDD space to store it losslessly, so you encode it lossyly.
3- Happily as you have checked it when it was lossless you still have all the ID & CRC necessary to re-check later even without having the lossless data anymore.
4- With this new feature, update the lossless .accurip in order to verify if the rip is now in database & if it was really accurate.
Indeed if it's not accurate you cannot repair as it's lossy now, still it would be interesting to be able to verify afterward that a lossy rip was accurate before being encoded.
  • B00ze
Reply #1695
Hey Gorth!
I dont mind Paranoid, I have several CDs in perfect condition (not a scratch, not a smudge, nothing) where both EAC and CueRipper read tons of errors (EAC took 12 hours to rip one of those and reported 20+ suspicious positions on 2 tracks; CueRipper ripped it in an hour and it passed AR, but the RED bar was always almost maxed). You become paranoid when this happens on several otherwise pristine CDs. I'd use CueRipper always, if it could do a few things more (external compressor with tags passed on command line, drop-box for album art, database, ...)
It's on one of those CDs that I had to re-rip with CueRipper that I noticed significant differences in PREGAP displayed in EAC/Cue logiles.
Look at this, same CD ripped with both programs:
Rush / Moving Pictures
        1  |  0:00.32 |  4:37.08 |        32    |    20814
        2  |  4:37.40 |  6:10.70 |     20815    |    48634
        3  | 10:48.35 |  4:26.00 |     48635    |    68584
        4  | 15:14.35 |  4:21.35 |     68585    |    88194
        5  | 19:35.70 | 11:00.00 |     88195    |   137694
        6  | 30:35.70 |  4:45.52 |    137695    |   159121
        7  | 35:21.47 |  4:46.73 |    159122    |   180644
Track 1  EAC= Pre-gap length 0:00:02.32  CueRipper= Pre-gap length 0:00:02.42
Track 2  EAC= Pre-gap length 0:00:03.28  CueRipper= Pre-gap length 0:00:03.37
Track 3  EAC= Pre-gap length 0:00:00.68  CueRipper= Pre-gap length 0:00:00.90
Track 4  EAC= Pre-gap length 0:00:00.55  CueRipper= Pre-gap length 0:00:00.73
Track 5  EAC= Pre-gap length 0:00:01.04  CueRipper= Pre-gap length 0:00:01.05
Track 6  EAC= Pre-gap length 0:00:00.68  CueRipper= Pre-gap length 0:00:00.90
Track 7  EAC= Pre-gap length 0:00:01.47  CueRipper= Pre-gap length 0:00:01.62
Is there something wrong with CueRipper's gap detection?
Gregory:
Your database now contains almost all of the Rush albums; now that you're here (Canada) you're gonna have to start listening to Rush ;-) And if you end-up ripping your shiny new Rush CDs, you'll have an entry to compare against :-) You're in Ottawa right? If you're looking for a decent rock radio station, try 97.7fm; it's in Montreal but it might reach ya. They don't play enough Floyd, but they do play a lot of Rush, lol.
Best Regards,
  • B00ze
Reply #1696
I've just had CueRipper reach retry#61 on a rip before the red bar disappeared.
If Paranoid mode doubles the retries (32->64) I'd say it's worth it on some rips.
L8r,
  • JeanV
Reply #1697
How can I split the image with this cue sheet?
TRACK 01 AUDIO
   TITLE "Man's Best Friend"
   PERFORMER "Clark Hutchinson"
   INDEX 01 00:00:00
  TRACK 02 AUDIO
   TITLE "Love Is The Light"
   INDEX 01 05:50:40
  TRACK 03 AUDIO
   TITLE "The Light Burns On"
   INDEX 00 05:51:04
   INDEX 01 11:48:23
  TRACK 04 AUDIO
   TITLE "Come Up Here"
   INDEX 00 05:51:14
   INDEX 01 14:23:48
  TRACK 05 AUDIO
   TITLE "Disorentared. Part One."
   INDEX 00 05:51:31
   INDEX 01 17:22:02
  TRACK 06 AUDIO
   TITLE "Boat In The Morning Mist"
   INDEX 00 05:51:62
   INDEX 01 19:12:17
  TRACK 07 AUDIO
   TITLE "Oroented"
   INDEX 00 05:52:42
   INDEX 01 23:49:35
  TRACK 08 AUDIO
   TITLE "First Reminder"
   INDEX 00 05:52:73
   INDEX 01 25:35:36
  TRACK 09 AUDIO
   TITLE "Mix Elixir"
   INDEX 00 06:20:67
   INDEX 01 30:54:35
  TRACK 10 AUDIO
   TITLE "Poison"
   INDEX 00 09:21:01
   INDEX 01 33:54:45
  TRACK 11 AUDIO
   TITLE "Disoientated Part Two (As)"
   INDEX 00 13:35:66
   INDEX 01 38:09:18
The gaps look very odd, and I get this error: 'Exception: Indexes must be in chronological order' error.
Thank you.
  • Last Edit: 19 December, 2011, 08:10:21 AM by db1989
  • mjb2006
Reply #1698
JeanV, you need to use codebox tags when posting logs, etc., so they appear in a scrollable section. Too late now.
What did you use to generate that cue sheet? Or did you just "find" it somewhere? It's damaged beyond repair.
The timestamp after each INDEX ## is supposed to be a position (minutes:seconds:frames format) within most recently mentioned audio FILE (or whichever file you're forcing the cue sheet to be used with). So track 10 index 01 begins at 33:54:45 and track 11 index 01 begins at 38:09:18 ... probably correct. But this means it is nonsensical for track 11 index 00, which is in between, to be at 13:35:66. The story is the same for all the other index 00s.
For splitting, you really only need the index 01s (because you're splitting on track boundaries, and for this disc there's no track 01 index 00 to worry about). So to "fix" the cue sheet, you could delete the INDEX 00 lines, and then it should "work". It no longer represents the original CD, but in this case, that's not a change from the status quo. It didn't represent the original CD properly anyway
If you were to use the cue sheet with the index 00s deleted to burn a copy, the resulting CD-R will be mastered with no 'gaps' (places where you see the cd player count from a negative time up to 0:00 at the end of each track). The audio and the main track boundaries will be OK.
  • Last Edit: 19 December, 2011, 01:28:14 AM by mjb2006
  • Porcus
Reply #1699
67 pages, that's a lot ... I would rather advise users to go to http://www.cuetools.net/wiki/
(And then perform a couple of searches, and then ask.)
