Topic: CUETools versions 1.9.5 through 2.1.6 (Read 1948429 times) previous topic - next topic
CUETools versions 1.9.5 through 2.1.5 (current)
Reply #1375
uh I'm not intending to chase anyone...
The case actually applies to me...
I ripped with incorrect settings many albums, most were reported as accurate.
If I re-rip them again and compare both rips with a checksum verification tool, chances are they are both the same (considering that I used the correct offset in both rips). The other alternative is that the checksum verification (like CRC 128bit), reports differences between tracks of the two rips. That would most likely indicate that the first rip was different/inaccurate though it was reported as accurate and maybe shared the same AR/CTDB checksum. My question is how likely/or maybe possible is that this can happen.
In others words, up to what point I should be confident that my old rips would pass a CRC 128bit verification/be identical to re-rips with correct settings, or not.
Reply #1376
So let's say this case scenario
1. A rip with burst mode and other incorrect settings.
2. Same disc rip with secure mode/correct settings.
3. Both rips have different CRC128/64.
4. AR/Cuetools databases report both as accurate.
How likely or unlikely is 4 (as well as 3)?
Normally there's a roughly 2^(-32) chance (1 disc out of 4294967296), assuming the errors in burst mode were random.
It's hard to estimate the chance of non-random errors which could in theory be caused by CD-drive's firmware or something like that, when the database can contain a CRC from someone with the drive which has exactly the same problem. But you can probably be sure this didn't happen to you if AR confidence level was high enough, because the majority of submissions would be made using different drives that are unlikely to have exactly the same bug.
There's a quite high probability that the CRC of the complete image will differ, when there are problems reading the first or the last few samples of the disc, which AR/CTDB deliberately ignore.
This shouldn't worry you, however, because those are small areas and usually are very close to silence, so those errors won't be audible.
To cut the long story short: you can trust AR if confidence levels are 'high enough'. You'll have to determine that 'high enough' level for yourself depending on how paranoid you are.
CUETools 2.1.6
Reply #1377
Hello again!
I'm still a newbie with this tool, so I need a little help... I'm trying to verify my flacs (with no cue file). For some of them, after the verification, the tags look like this:
ACCURATERIPCOUNT = 0
ACCURATERIPCOUNTALLOFFSETS = 147
ACCURATERIPCOUNTWITHOFFSET = 177
ACCURATERIPTOTAL = 165
I suppose this means the rip is not accurate?
My question is about ACCURATERIPCOUNTALLOFFSETS and ACCURATERIPCOUNT - which one shows if the rip is accurate?
When the result in CueTools is "AR: rip accurate (30/33)", which tag corresponds to the first number (30 in this case)?
I'll be grateful if you can point me where I could read a detailed description of the exact meaning of this tags.
Thank you in advance!
Reply #1378
enable the "batch log" pane (button to the left of the preferences "cog" button). then change the "input" section to "local database". then find the album and highlight it, then you'll see the full log in the bottom pane and you can see how the numbers correspond with the tags.
Reply #1379
AR: rip accurate (ACCURATERIPCOUNTALLOFFSETS/ACCURATERIPTOTAL)
EAC shows (ACCURATERIPCOUNT/ACCURATERIPTOTAL).
ACCURATERIPCOUNTALLOFFSETS is the sum of confidence against all pressings.
CUETools 2.1.6
Reply #1380
So you are saying I have an obligation to do this? [...] The saying goes "if you give a dog a bone, you do not want to hear from the dog if it does not taste nice".
Just a very few points in here.
1) Generally speaking, I think that «listen to good advise» is good advise, obligation or not.
2) ... and I think Spoon did -- or attempted to do -- just that. Take a look at http://www.hydrogenaudio.org/forums/index....showtopic=61468 .
3) Gregory, you did contribute on the matter (posting #53 and later), and from what I can see, you supported the current choice of checksum, right? (#57). If the checksum is still flawed then well, too bad, but it is not because it was chosen without consulting the Hydrogenaudio braintrust.
4) For an "AccurateRip 3" to be feasible now, I think the following three considerations are relevant: (I) is AR2 fundamentally flawed?, (II) is «anyone» yet using AR2?, (III) what are the costs of actually correcting it?. For (I), I think the relevant benchmark is «how bad is this compared to the weakness which as a matter of fact did trigger an update?», (III) I leave to you coders (Gregory, you could maybe even give Spoon a cutandpastable codebone here?  ), and for (II) ... well, I do not know. AR2 support found its way into EAC last November, so it might be too late to be a good option?
Reply #1381
The current choice of format is not CRC32. Gregory supported CRC32 against hashes. Please read #63.
Reply #1382
I was against the whole idea of introducing a new CRC (#53), and in case it was decided to introduce a new CRC, i advocated the use of CRC32 (#53, #57, #63). I said (#63) that new CRC is not much better than the old one. But there's not much point in bringing it all up now. What's done is done, i don't think that it can easily be reversed.
I) No, it's not. And AR1 was not.
II) When i verify my rips with ARv2-supporting version of CUETools, i see quite a lot of AR2 CRCs. Probably around 5-10 percents of the database are V2 CRCs.
III) If it was to be replaced with CRC32, that would be very easy to implement in CUETools. Much-much simpler than to implement cross-pressing verification for AR2 CRC.
CRC32 is very well known and it's implementations are all-over the place.
I already did provide a link to efficient Fletcher-32 CRC code - it's based on the same idea that AR2 CRC, but without the bug and is a bit faster:  http://en.wikipedia.org/wiki/Fletcher%27s_...m#Optimizations
But it's a little bit too late for that.
At this point, my first choice would be to just drop ARv2 CRC and revert back to ARv1 CRC, and purge all ARv2 CRCs from the database if it's possible. Just to keep things simple.
My second choice would be to do nothing and live with ARv2. It's ugly, and doesn't support cross-pressing verification too well, but it works.
My third choice would be to purge all ARv2 CRCs from the database and switch to CRC32, just to stop all the speculations about the perceived "flaws" in AR.
Fletcher-32 would be my last choice. It's a quite strong and very fast CRC, but it doesn't have to be that strong or that fast, and it's not a very well-known CRC.
CUETools 2.1.6
Reply #1383
Let me guess... Spoon chose to work on his own implementation due to marketing reasons.
BTW, the whole AR idea was great and all credits go to Spoon, and secondly, to Gregory for extending this concept.
Reply #1384
Lets talk a little about perceived flaws in AR2...yes on very small datasets you can simulate collisions more readily than a CRC32, but I do not think this is true once a large amount of data passes through either (and any track on a CD is a large amount of data).
Reply #1385
Given that we have a "large amount of data" (i.e. a full track), and given also some «realistic drive behaviour», then it would be a good thing to have at least some partial knowledge of what errors are possible, plausible and likely.
A very particular example: I guess you guys know fairly well how drives interpolate missing samples. So I would suppose that a likely erroneous sample delivered from the CD drive, is the interpolated value. So the «distribution of erroneous samples» should be expected to be far from uniform.
How often could such an error (assuming that the true value is not by coincidence equal to the interpolated!) lead to a collision? (The answer does possibly depend on what is the distribution in real music of "middle samples" given the two neighbours.)
Reply #1386
Thanks again. I should have studied CRC tech specs... now I did.
IMHO = or > 2 or if the number of matches is the highest, seems right.
Thanks for taking the time.
Reply #1387
A minor feature request if I may:
could it be possible to provide a general setting to "always overwrite" files, or perhaps only non-critical files (e.g. .accurip, .log, .cue...)? The setting checkbox which pops up at run-time allows overwriting files during a batch job but is not remembered between or within subsequent sessions.
(Or perhaps did I overlook something...)
Reply #1388
Summary: .accurip says rip is accurate, and if you compare .accurip CRC32 values to .log CRC values each track matches, but .accurip says that CRC32 values don't match for some tracks.
Using CueTools 2.0.9, I ran a Verify on a recent rip, and the result is puzzling. The .accurip report generated by CueTools says that the rip is accurate, but the bottom section says that the CRC32 values for tracks 5-9 don't match the CRC values for same tracks in the log, but instead match other track numbers. This is very strange.
Track Peak [ CRC32  ] [W/O NULL] [  LOG  ]
--  95.3 [B32808E7] [942C824D]
01  89.6 [82FBCB38] [97D51307]  CRC32
02  87.2 [F88E3C98] [BB1556DD]  CRC32
03  89.5 [B3BB9AC3] [6C8DE019]  CRC32
04  90.6 [BA3FCC92] [B6938BD8]  CRC32
05  92.1 [73266BBC] [C902FE6B] [71E0C6B3]: CRC32 for track 6
06  83.9 [71E0C6B3] [7CF02AB2] [EA5530EF]: CRC32 for track 8
07  90.5 [67E5854C] [8C6E2362] [CE06ED2E]: CRC32 for track 9
08  93.1 [EA5530EF] [F3CAC94F] [73266BBC]: CRC32 for track 5
09  95.3 [CE06ED2E] [88EA19E5] [67E5854C]: CRC32 for track 7
However, when I check for myself by reading the two documents, the CRC32 values shown in the .accurip report do match the CRC values in the log for every track.
Is this some bug in CueTools? Has CueTools somehow become confused on this particular comparison? What is going on here?
Below are the full .accurip report and .log.
.accurip report
[CUETools log; Date: 02/06/2011 9:31:03 AM; Version: 2.0.9]
[CTDB TOCID: TdM8HPYZNBzW2K9i4Rxd8q7hDRE-] disk not present in database.
[AccurateRip ID: 0013ddc8-00918ae5-770d7809] found.
Track  [ CRC    ] Status
01    [e485c1f8] (17/60) Accurately ripped
02    [5c99a1ef] (17/59) Accurately ripped
03    [53b76232] (17/62) Accurately ripped
04    [88c50190] (17/60) Accurately ripped
05    [e3566cab] (17/61) Accurately ripped
06    [054a1dbf] (17/62) Accurately ripped
07    [8cafe5ba] (17/62) Accurately ripped
08    [2205f363] (17/60) Accurately ripped
09    [e29ccfac] (17/59) Accurately ripped
Offsetted by -664:
01    [e29e85e0] (02/60) Accurately ripped
02    [ff76a437] (00/59) No match
03    [dffd9922] (02/62) Accurately ripped
04    [c9f6d8d0] (00/60) No match
05    [5d9065db] (02/61) Accurately ripped
06    [2cc4bd7f] (02/62) Accurately ripped
07    [f105bc7a] (02/62) Accurately ripped
08    [68293fc3] (00/60) No match
09    [05d63d34] (00/59) No match
Offsetted by 331:
01    [863e09f3] (02/60) Accurately ripped
02    [609e5a3e] (02/59) Accurately ripped
03    [1f8680a4] (02/62) Accurately ripped
04    [0ffb3268] (04/60) No match but offset
05    [58876795] (02/61) No match but offset
06    [0bd38b07] (02/62) Accurately ripped
07    [dee95922] (02/62) Accurately ripped
08    [e1c23bf7] (02/60) Accurately ripped
09    [67078253] (04/59) No match but offset
Offsetted by 367:
01    [ea962457] (35/60) Accurately ripped
02    [5c6a4612] (37/59) Accurately ripped
03    [99765bbc] (37/62) Accurately ripped
04    [76db3188] (37/60) No match but offset
05    [4590994d] (36/61) No match but offset
06    [59e0f167] (37/62) Accurately ripped
07    [40cc0502] (37/62) Accurately ripped
08    [fccca867] (37/60) Accurately ripped
09    [4dfcaf47] (36/59) No match but offset
.log
Exact Audio Copy V0.99 prebeta 5 from 4. May 2009
EAC extraction logfile from 1. June 2011, 18:51
Herbie Hancock / Takin' Off
Used drive  : HL-DT-STDVD-ROM DU10N  Adapter: 0  ID: 1
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 102
Overread into Lead-In and Lead-Out          : No
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 320 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Program Files\a Accessories\Exact Audio Copy\Flac\flac.exe
Additional command line options : -V -5 -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" %s
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  7:07.72 |        0    |    32096
        2  |  7:07.72 |  5:25.48 |    32097    |    56519
        3  | 12:33.45 |  6:10.42 |    56520    |    84311
        4  | 18:44.12 |  6:47.40 |    84312    |  114876
        5  | 25:31.52 |  6:55.58 |    114877    |  146059
        6  | 32:27.35 |  6:27.50 |    146060    |  175134
        7  | 38:55.10 |  6:34.17 |    175135    |  204701
        8  | 45:29.27 |  5:32.00 |    204702    |  229601
        9  | 51:01.27 |  6:27.28 |    229602    |  258654
Track  1
    Filename C:\Rip\01 - Watermelon Man.wav
    Pre-gap length  0:00:02.00
    Peak level 89.6 %
    Track quality 100.0 %
    Test CRC 82FBCB38
    Copy CRC 82FBCB38
    Accurately ripped (confidence 17)  [E485C1F8]
    Copy OK
Track  2
    Filename C:\Rip\02 - Three Bags Full.wav
    Peak level 87.2 %
    Test CRC F88E3C98
    Copy CRC F88E3C98
    Accurately ripped (confidence 17)  [5C99A1EF]
    Copy OK
Track  3
    Filename C:\Rip\03 - Empty Pockets.wav
    Peak level 89.5 %
    Track quality 99.9 %
    Test CRC B3BB9AC3
    Copy CRC B3BB9AC3
    Accurately ripped (confidence 17)  [53B76232]
    Copy OK
Track  4
    Filename C:\Rip\04 - The Maze.wav
    Peak level 90.6 %
    Test CRC BA3FCC92
    Copy CRC BA3FCC92
    Accurately ripped (confidence 17)  [88C50190]
    Copy OK
Track  6
    Filename C:\Rip\06 - Alone and I.wav
    Pre-gap length  0:00:01.06
    Peak level 83.9 %
    Test CRC 71E0C6B3
    Copy CRC 71E0C6B3
    Accurately ripped (confidence 17)  [054A1DBF]
    Copy OK
Track  8
    Filename C:\Rip\08 - Three Bags Full [bonus alt. take].wav
    Peak level 93.1 %
    Test CRC EA5530EF
    Copy CRC EA5530EF
    Accurately ripped (confidence 17)  [2205F363]
    Copy OK
Track  9
    Filename C:\Rip\09 - Empty Pockets [bonus alt. take].wav
    Peak level 95.3 %
    Test CRC CE06ED2E
    Copy CRC CE06ED2E
    Accurately ripped (confidence 17)  [E29CCFAC]
    Copy OK
8 track(s) accurately ripped
1 track(s) canceled
Some tracks could not be verified as accurate
There were errors
End of status report
EAC extraction logfile from 1. June 2011, 19:19
Read mode              : Secure
Quality                        : High
Add ID3 tag                    : No
Track  5
    Filename C:\Rip\05 - Driftin'.wav
    Peak level 92.1 %
    Track quality 99.7 %
    Test CRC 73266BBC
    Copy CRC 73266BBC
    Accurately ripped (confidence 17)  [E3566CAB]
    Copy OK
Track  7
    Filename C:\Rip\07 - Watermelon Man [bonus alt. take].wav
    Peak level 90.5 %
    Test CRC 67E5854C
    Copy CRC 67E5854C
    Accurately ripped (confidence 17)  [8CAFE5BA]
    Copy OK
All tracks accurately ripped
No errors occurred
Reply #1389
CUETools gets confused by "nonstandard" logs, I think it's normal, you can't expect it to be able to parse any kind of weird track order and combination.
Reply #1390
What Goratrix said. The log file is being read in order from top to bottom, not by track number. The tracks are listed out of order so they don't match up. If tracks 5 and 7 were where they belong, everything would be fine.
korth
Reply #1391
Ah, okay, that makes sense if that's how CueTools reads the log. Thanks for explaining that, and thanks to Goratrix. Very helpful.
Reply #1392
I saw some discussion about this somewhere else. How can all the tracks return "(0/0) No match but offset" ?
IIRC that is either due to past aggressive cleanup of the AR database (?) or, more likely, when only two conflicting rips have been submitted to the DB and thus await resolution by a third one.
I have a small number of rips that return such a "(0/0) No match but offset" or "(0/0) Rip not accurate"... which sounds a bit counterintuitive indeed.
Short update on this puzzling "issue", I just noticed one case where all tracks but one are verified as accurately ripped (confidence 2/2), the faulty (?) one shows as "0/0 No match". Seems quite weird.
Reply #1393
Hi, I have a problem.
I recently ripped some CDs without creating a cue file or log (for testing).
Checking the tracks with Cuetools i see this :
[AccurateRip ID: 0010d9b6-0092b069-9809ab0b] found.
 01    [ddbaf796] (00/26) No match
 02    [1b6d1bd2] (00/25) No match
 03    [49fa7b44] (00/26) No match
 04    [e3aa907f] (00/27) No match
 05    [ad26832d] (00/27) No match
 06    [1f61e1e9] (00/26) No match
 07    [e89cac08] (00/26) No match
 08    [b4e3847b] (00/26) No match
 09    [8f2c09c6] (00/26) No match
 10    [a5fd5554] (00/26) No match
 11    [d7e5383d] (00/26) No match
Offsetted by 97:
 01    [5c886412] (26/26) Accurately ripped
 02    [5947ff85] (25/25) Accurately ripped
 03    [3fd968b6] (26/26) Accurately ripped
 04    [2d13494a] (27/27) Accurately ripped
 05    [2e7772e4] (27/27) Accurately ripped
 06    [d4f7cae4] (26/26) Accurately ripped
 07    [ff712985] (26/26) Accurately ripped
 08    [668cd35d] (26/26) Accurately ripped
 09    [c297e9bc] (26/26) Accurately ripped
 10    [28fcfb1e] (26/26) Accurately ripped
 11    [ac5e13c7] (26/26) Accurately ripped
 --  98,8 [D0DB84E6] [946F787A]
 01  98,8 [360A85C1] [4BD6A120]
 02  94,4 [3B05C5A4] [3F9A9D2C]
 03  98,8 [CA35FC88] [5C05F1BB]
 04  98,8 [B9B96159] [06AC6F45]
 05  96,6 [6D2BDD22] [17B5A1AD]
 06  96,6 [3CE8E6DC] [12D0F567]
 07  97,7 [7D2E17CA] [D80DA5D3]
 08  97,7 [97FBAFFA] [A43B733B]
 09  98,8 [7AB9CBDB] [5BF4A851]
 10  98,8 [1B9D17AF] [3AE6C26B]
 11  98,8 [0026DCEA] [1ADB9BB2]
Now I have created with Cuetools the correct cue file (+97 offsetted), then burn and re-rip with EAC (last beta 1.02) to verify the integrity.
EAC does not find any tracks correct (CRC data from AccurateRip database) :
Exact Audio Copy V1.0 beta 2 from 29. April 2011
EAC extraction logfile from 5. June 2011, 2:20
Sammy Hagar and the Wabos / Livin' It Up
Used drive  : TSSTcorpCDDVDW SH-S223C  Adapter: 0  ID: 0
Read mode : Burst
Read offset correction                      : 697
Used interface                              : Installed external ASPI interface
Used output format : Internal WAV Routines
Sample format      : 44.100 Hz; 16 Bit; Stereo
        1  |  0:00.00 |  2:56.72 |        0    |    13271
        2  |  2:56.72 |  4:20.38 |    13272    |    32809
        3  |  7:17.35 |  3:34.15 |    32810    |    48874
        4  | 10:51.50 |  4:39.30 |    48875    |    69829
        5  | 15:31.05 |  3:41.25 |    69830    |    86429
        6  | 19:12.30 |  2:18.07 |    86430    |    96786
        7  | 21:30.37 |  3:37.10 |    96787    |  113071
        8  | 25:07.47 |  4:23.43 |    113072    |  132839
        9  | 29:31.15 |  4:21.27 |    132840    |  152441
      10  | 33:52.42 |  4:24.35 |    152442    |  172276
      11  | 38:17.02 |  2:58.48 |    172277    |  185674
Track  1
    Filename E:\ Sammy Hagar and the Wabos (2006) - Livin' It Up\01. Sam I Am.wav
    Peak level 98.8 %
    Extraction speed 14.9 X
    Test CRC 5F6459E7
    Copy CRC 5F6459E7
    Cannot be verified as accurate (confidence 26)  [908F7E1E], AccurateRip returned [5C886412]  (AR v2)
    Copy OK
Track  2
    Filename E:\ Sammy Hagar and the Wabos (2006) - Livin' It Up\02. Living on a Coastline.wav
    Peak level 94.4 %
    Extraction speed 20.3 X
    Test CRC 40CFCCDB
    Copy CRC 40CFCCDB
    Cannot be verified as accurate (confidence 25)  [6B9F2E0C], AccurateRip returned [5947FF85]  (AR v2)
    Copy OK
Track  3
    Filename E:\ Sammy Hagar and the Wabos (2006) - Livin' It Up\03. Mexico.wav
    Peak level 98.8 %
    Extraction speed 21.9 X
    Test CRC 2F1CE7EC
    Copy CRC 2F1CE7EC
    Cannot be verified as accurate (confidence 26)  [1A43DF57], AccurateRip returned [3FD968B6]  (AR v2)
    Copy OK
Track  4
    Filename E:\ Sammy Hagar and the Wabos (2006) - Livin' It Up\04. The Way We Live.wav
    Peak level 98.8 %
    Extraction speed 23.6 X
    Test CRC 689321A8
    Copy CRC 689321A8
    Cannot be verified as accurate (confidence 27)  [F346154E], AccurateRip returned [2D13494A]  (AR v2)
    Copy OK
Track  5
    Filename E:\ Sammy Hagar and the Wabos (2006) - Livin' It Up\05. I Love This Bar.wav
    Peak level 96.6 %
    Extraction speed 25.0 X
    Test CRC 772E3055
    Copy CRC 772E3055
    Cannot be verified as accurate (confidence 27)  [19EFCB2A], AccurateRip returned [2E7772E4]  (AR v2)
    Copy OK
Track  6
    Filename E:\ Sammy Hagar and the Wabos (2006) - Livin' It Up\06. One Sip.wav
    Peak level 96.6 %
    Extraction speed 26.0 X
    Test CRC 31918E26
    Copy CRC 31918E26
    Cannot be verified as accurate (confidence 26)  [361532C3], AccurateRip returned [D4F7CAE4]  (AR v2)
    Copy OK
Track  7
    Filename E:\ Sammy Hagar and the Wabos (2006) - Livin' It Up\07. Rainy Day Woman #12,#35.wav
    Peak level 97.7 %
    Extraction speed 27.1 X
    Test CRC 624C4D70
    Copy CRC 624C4D70
    Cannot be verified as accurate (confidence 26)  [7A79873F], AccurateRip returned [FF712985]  (AR v2)
    Copy OK
Track  8
    Filename E:\ Sammy Hagar and the Wabos (2006) - Livin' It Up\08. Halfway to Memphis.wav
    Peak level 97.7 %
    Extraction speed 28.4 X
    Test CRC BAEA4D87
    Copy CRC BAEA4D87
    Cannot be verified as accurate (confidence 26)  [074514C6], AccurateRip returned [668CD35D]  (AR v2)
    Copy OK
Track  9
    Filename E:\ Sammy Hagar and the Wabos (2006) - Livin' It Up\09. Sailin.wav
    Peak level 98.8 %
    Extraction speed 29.7 X
    Test CRC 6761AA6F
    Copy CRC 6761AA6F
    Cannot be verified as accurate (confidence 26)  [7304C855], AccurateRip returned [C297E9BC]  (AR v2)
    Copy OK
Track 10
    Filename E:\ Sammy Hagar and the Wabos (2006) - Livin' It Up\10. Let Me Take You There.wav
    Peak level 98.8 %
    Extraction speed 31.0 X
    Test CRC 070ECDFD
    Copy CRC 070ECDFD
    Cannot be verified as accurate (confidence 26)  [5613D63A], AccurateRip returned [28FCFB1E]  (AR v2)
    Copy OK
Track 11
    Filename E:\ Sammy Hagar and the Wabos (2006) - Livin' It Up\11. Some Day.wav
    Peak level 98.8 %
    Extraction speed 32.0 X
    Test CRC 3067D159
    Copy CRC 3067D159
    Cannot be verified as accurate (confidence 26)  [F3E4844A], AccurateRip returned [AC5E13C7]  (AR v2)
    Copy OK
No tracks could be verified as accurate
You may have a different pressing from the one(s) in the database
No errors occurred
==== Log checksum E7C0D84CE375C7EA0A055F4332ABFD5B95257FD60C77469B46C7080A217A9C48 ====
I can recreate the exact cue file without using the audio CD ?
I have to set something else?
I have to re-rip each disc again?
Thanks in advance  .
Edit : Added log.
Reply #1394
Your cue file was correct from begining. You just have shifted audio data in wave file. CUETools can shift data in wave file so image become "accurate". And you did it. You don't need write image back to CD. If really want to burn CD and rip it again, you need to set write offset in your burning software, or data will be shifted again and you also don't get "accurate" copy.
Reply #1395
I noticed a minor inconvenience while verifying multiple folders. If the disc directory contains more than one cue file (flac.cue;wav.cue), the same disc will be verified several times, one for each cue. Maybe the local database may be able to skip this redundant checks? (if "skip recently verified" is selected).
Reply #1396
Any clue when the new version is coming (I thought it was planned for end of May) ? The AR update of June is up & I would like to update my "not present in database" rips but I would prefer using an updated CT (Specially for the HDCD detection bug). If the implementation of AR V2 is too long, just push it back to next version ...
Reply #1397
ARv2 support (without pressings) is already implemented. I will try to release 2.1.2 within a week. Sorry for the delay, but i got a bit distracted with CTDB plugin, web site update and switch to cloud hosting.
CUETools 2.1.6
Reply #1398
Ok, thks for the quick anwser. I'm gonna wait then.
