CUETools versions 1.9.5 through 2.1.5 (current)
Reply #441 – 2009-06-18 18:44:33
I still can't manage to make it work as expected. I ripped a CD with a pregap of 00:08:00 and a data track of 00:08:00, with Confidence 3 in EAC to separate tracks and created a cue-file with current settings. Verifying in CUETools to write AR tags, but it doesn't recognize it, even when it asks for the log-file. Neigher can I make it recognize it when I enter the values manually. I tried to verify this using dummy files with same lengths as in a log that you sent me. There were no problems:[Verification date: 18.06.2009 21:31:09] [Disc ID: 002a53cf-01dc7ff5-ec12aa10] Pregap length 00:08:00. CD-Extra data track length 00:08:00. Track Status 01 (00/03) No matches 02 (00/03) No matches 03 (00/03) No matches 04 (00/03) No matches 05 (00/03) No matches 06 (00/03) No matches 07 (00/03) No matches 08 (00/03) No matches 09 (00/03) No matches 10 (00/03) No matches 11 (00/03) No matches 12 (00/03) No matches 13 (00/03) No matches 14 (00/03) No matches 15 (00/03) No matches Track [ CRC32 ] [W/O NULL] [ LOG ] -- [420F3D4E] [00000000] W/O NULL 01 [A1985E48] [00000000] [68B186E3] 02 [EE896089] [00000000] [88E98B88] 03 [57954675] [00000000] [AACB27CD] 04 [070B9517] [00000000] [F515831E] 05 [B7E0B086] [00000000] [7A5E2521] 06 [7CED5E61] [00000000] [E8D30054] 07 [1E83BC5D] [00000000] [9657E354] 08 [E13DDE0D] [00000000] [234B0B5E] 09 [B8003064] [00000000] [7188AB89] 10 [257CA442] [00000000] [0A9E261D] 11 [EE309B70] [00000000] [28A5C491] 12 [75A0DDB5] [00000000] [159B3C57] 13 [FF89AFE7] [00000000] [1383FD33] 14 [EF48FB28] [00000000] [109FBFB4] 15 [B2F6DF81] [00000000] [969C92FE] Can you please compare your files length with the log? Foobar2000 can show you the file's length in samples. The length from log is calculated like this: (End sector + 1 - Start sector) * 588. e.g. the first track should have length (34486+1-600)*588==19925556 samples. My current hypothesis is that EAC made some tracks shorter, when it failed to rip them. I will add a check for that in the next version i guess.
