Topic: Converting CD to single Flac file - help! (Read 4687 times) previous topic - next topic
  • edem
I'm a musician and I would like to offer Flac downloads of my albums.
However, I don't want to sell separate tracks so I'm trying to convert a whole CD to a single Flac file.
I'm using xAct (for Mac OSX) and so far I can't seem to work out how to do it (I can only encode each separate track to a flac file).
Is it possible to convert the whole Cd into one single Flac file? And if so, can someone tell me how to do it?
Thank you
  • thundat00th
it is possible
do you have a wave editor (eg. Audacity) line up the tracks with that program, and export it to wave, then convert to flac, or just export to flac
thats one way to do it, i dont know if audacity has a mac build but i think it does
  • Last Edit: 25 September, 2008, 03:16:43 PM by thundat00th
My $.02, may not be in the right currency
  • edem
it is possible
Thank you! I do have Audacity so I will try it!
  • edem
it is possible
Sometimes I find that when I try to edit a track on Audacity it slightly looses it's quality. Is that possible?
Also, I was wondering if you think it's a good idea to offer the download of the whole album or maybe, even if you have to buy the whole album, whether it would be better to download it track by track?
Thanks again.
  • thundat00th
it may sound worse when you play it back in audacity, thats because it takes some shortcuts for realtime playback, so you can play multiple tracks if you were mixing different insturments together, but once you export it, it should sound the same
personally, individual tracks would easily be my choice
i would also put a zip file with all the tracks in that zip file (or .rar file or other compressed file) in addition to individual tracks
  • Last Edit: 25 September, 2008, 10:30:50 PM by thundat00th
Take a look at this link
http://wiki.hydrogenaudio.org/index.php?title=EAC_and_FLAC
The 2 softwares you need are EAC and FLAC 1.2.1
EAC rips the CD accurately, without errors.
FLAC 1.2.1 is to compress the WAV file to FLAC format.
In EAC, you can configure whether you want to rip the CD as a single file or as individual tracks.
However, if you do have the original WAVs, you can skip the EAC step and download FLAC 1.2.1 directly to compress your file.
  • Last Edit: 27 September, 2008, 05:08:35 AM by Boiled Beans
  • greynol
  • Global Moderator
Are you going to tell the guy how to get EAC running on a Mac?
  • edem
Thank you for all your suggestions!
So you would offer two options - to download individual tracks (even if you buy the whole album) and also put all the tracks in a zip file?  Would you put them in a zip file as .aiff/.wav or as flacs? And  wouldn't that affect the  quality? Thank you again.
  • thundat00th
probably flac, i wouldnt want to download wav. files, even zipped wav. files, and no it would not effect quality
i also want to clarify that im mostly just guessing on the playback in audacity, but its probably something like that, either that or your just imagining the difference
  • Last Edit: 27 September, 2008, 11:32:47 PM by thundat00th
  • kjoonlee
Off topic, but... are you sure?
  • thundat00th
huh, i didnt know about that, but i would still rather have the flac files for the tags
  • chornobyl
Sad but yes this is possible.
The dafault Audacity settings set default sample format to FLOAT32 while your flac files where probably INT16, and when you exporting back to flac it converts float32 to int16 and uses DITHERING.
So if you simply whant to stick files together in LOSSLESS manner swich off dither for this purpose.
