Topic: ov_open_callbacks (Read 3669 times) previous topic - next topic
  • MB2
ov_open_callbacks
I ran into a problem I find hard to understand.
To make my application read files from memory I thought it would be suitable to use ov_open_callbacks instead of ov_open (wich is limited to files stored on the harddis - and not in a packer form example).
But I found that when I used that logic, the ov_open_callback function would give me a
OV_ENOTVORBIS error code, although the very same file worked fine under ov_open.
I checked the buffer length, that was ok.
  • Last Edit: 20 September, 2008, 03:19:48 AM by MB2
  • Saoshyant
ov_open_callbacks
I recommend that you look for help in the vorbis-dev mailing list at xiph.org.  Best of luck.
Join //spreadopenmedia.org to promote Vorbis, FLAC, Speex, etc
  • Yirkha
  • FB2K Moderator
ov_open_callbacks
The source code is open, nothing is stopping you from debugging why you get OV_ENOTVORBIS back yourself. Or don't programmers work like that anymore nowadays?
