Topic: speex files won't play in v0.9.5.5 (Read 2888 times) previous topic - next topic
I've encoded several speex clips and found that foobar v0.9.5.5 is not outputting audio.
It correctly shows info, bitrate, duration, even the playback slider moves when I hit Play.
But there is no audio nor visualisation.
I've tried 2 different versions of speexenc.
Winamp speex plugin plays the same files correctly.
Can anyone confirm this?
Confirmed.
File Name : test32.spx
Folder Name : C:\Documents and Settings\Neil\Desktop\Bloc Party\Intimacy
File Path : C:\Documents and Settings\Neil\Desktop\Bloc Party\Intimacy\test32.spx
Subsong Index : 0
File Size : 967KB (991 212 bytes)
Last Modified : 2008-09-18 14:56:22
Duration : 3:29.490 (6703682 samples)
Sample Rate : 32000 Hz
Channels : 2
Bitrate : 38 kbps
Codec : Speex
Encoding : lossy
Tool : Encoded with Speex speex-1.2beta3
I'm on a horse.
This problem will be fixed in the next update, thanks for the report.
We are the bork. Your software bugs will be added to our own. Resistance is futile.
