Topic: foo_lastfm_radio (Read 349323 times) previous topic - next topic
foo_lastfm_radio
Reply #227
Version 0.5.6b is up, and working again for myself. (The previous version still doesn't.)
Only new feature is that playback stops after 10 invalid tracks in a row to prevent the never-ending skips, but hopefully that won't be needed again...
foo_lastfm_radio
Reply #228
My god nausea, you are fast! Works here.
Is this something new?
Error retrieving Last.fm radio playlist: There is not enough content to play the station. Due to restrictions imposed by the music labels, a radio station must have more than 15 tracks; each by different artists.
foo_lastfm_radio
Reply #229
Here everything seems to work fine (0.9.5b) except for "recommended radio" (nothing happens).
*edit*
Nevermind, it works again.
foo_lastfm_radio
Reply #230
I've only stuck to one station (a friend's loved tracks) but it's been working for two hours just fine (with 0.9.5b), thanks!
foo_lastfm_radio
Reply #231
Working again with the new version (thanks for being so speedy!), but tracks aren't scrobbling anymore. Is there something else I need to do?
foo_lastfm_radio
Reply #232
Obvious answer: have you reinstalled (and put your credentials into) the normal last.fm plugin again?  Just tested, looks like the streamer doesn't record your scrobbles.
foo_lastfm_radio
Reply #233
Working again... not sure why I had to do this, because it was never necessary when upgrading before. But thanks for pointing out the obvious first thing I should have tried
foo_lastfm_radio
Reply #234
I don't manage to get the local direction of the album arts, could anybody help me to retrieve it ?
foo_lastfm_radio
Reply #235
My sincere apologies if this has been addressed before. Im not very good at searching.
I love the last.fm radio component however it doesn't seem to send the title / artist information to the msn now playing component. It works if i play local music. Any ideas?
EDIT: Nevermind. I tried another one ( http://www.hydrogenaudio.org/forums/index....showtopic=66346 ) and works great!
foo_lastfm_radio
Reply #237
As i understand it correctly it will effect all users outside US, UK and Germany.
Thanks god i'm in Germany...
foo_lastfm_radio
Reply #238
Surely this plugin will still work, except you might have to pay?
foo_lastfm_radio
Reply #239
only people outside uk, us and germany...
april fools anyone?
foo_lastfm_radio
Reply #240
The reason for choosing those three countries has been explained in the comments of that blogpost.
foo_lastfm_radio
Reply #241
I guess from now on this component desperately lacks a proxy functionality
foo_lastfm_radio
Reply #242
This news about the Last.fm Radio API may also be pertinent.
Last.fm has never had a public radio API, although we've tolerated third-party clients using the undocumented calls that our client uses. This is finally about to change - we're going to make a public, documented streaming API available to everyone who has an API account. There are a few limitations:
  1. Only subscribers will be allowed to stream using API applications unless you negotiate a separate deal with us - we need to get the money to cover royalties.
  2. You won't be allowed to use our API to stream to mobile phones. This is unfortunately a limitation of some of our licensing agreements. Again, we may be able to make an exception to this if you talk to us directly.
These changes should be made by the end of next week. Alongside this, we'll be shutting down the remainder of the old, undocumented streaming APIs over the next couple of weeks.
Anish
foo_lastfm_radio
Reply #243
I'll update the component when these changes happen. The new api doesn't seem to be too different from the current one. Shame about the subscription only though.
foo_lastfm_radio
Reply #244
The commands (context menu items) of the component show up empty in the columns ui buttons toolbar options.
Maybe this can be fixed?
foo_lastfm_radio
Reply #246
Since 1 April my foo_lastfm_radio doesn't work at all.
Anybody, any luck?
foo_lastfm_radio
Reply #247
Works for me without problem.
foo_lastfm_radio
Reply #249
Unable to resume decoding at 1:02.145 (Unsupported format or corrupted file):
"FOO_LASTFM_RADIO://play.last.fm/user/3b0f8ac6fa4bb260bdb5d9b16308298c.mp3LASTFM"
I am always getting this error. I am using foobar 0.9.6.1 and Curacao config. Solution, anybody?
