Topic: foo_lastfm_radio (Read 262370 times) previous topic - next topic
  • nausea
  • Developer
foo_lastfm_radio
Reply #50
I've added a fix for crash when attempting to update tags.
I'm not sure how this will work with foo_playback_custom, as a current side effect when editing tags on a playing file is that the "ticket" becomes invalid (as foobar2000 closes and reopens the file).
foo_lastfm_radio
Reply #51
thanks for the update nausea
  • wojtek
foo_lastfm_radio
Reply #52
Thank's for the fix - now foobar doesn't crash, however I'll stick with option "update only files in library" in playcount_mod (lesser evil)
http://foobar2000.pl/ :: unofficial polish forum
  • wojtek
foo_lastfm_radio
Reply #53
Oh btw, do you have any plans to implement the track ban and love features from LastFM in the future? That would make the awesomness grow even bigger
I'd also be very happy to see love/ban feature implemented (and available for hot-key binding ;] ).
  • MusX
foo_lastfm_radio
Reply #54
is it possible to stream specific track from last.fm?
we have full track available to listen or just only 30 sec. anyway I would like to listen it in foobar or even make repeat on that track
example:
http://www.last.fm/music/Radio+Bagdad/_/Magister
tried to paste that song in different ways
lastfm://artist/Radio+Bagdad/_/Magister
lastfm://track/Radio+Bagdad/_/Magister
lastfm://music/Radio+Bagdad/_/Magister
and many others but nothing helps
just realize that I can stream full tracks that are able to download cause there are direct path to mp3 file - tracks are not scrobbling in that way.
BUT What about files which are full but unable to download and 30 seconds samples?
  • Last Edit: 17 September, 2008, 01:03:52 PM by MusX
my last.fm profile:
http://www.last.fm/user/MusX
  • Jleagle
foo_lastfm_radio
Reply #55
I think you have to pay to play a single song of your choice.
  • MusX
foo_lastfm_radio
Reply #56
no, I'm able to listen it in flash player for free, so the audio is steal-able
Moderation: Removed full quote cascade.
  • Last Edit: 17 September, 2008, 04:04:50 PM by foosion
my last.fm profile:
  • Jleagle
foo_lastfm_radio
Reply #57
Im talking about non-downloadable full length songs, that use the ticket system.
  • Last Edit: 17 September, 2008, 04:05:10 PM by foosion
  • MusX
foo_lastfm_radio
Reply #58
don't really know what is ticket system but if I'm able to listen music via flash player that means foo_lastfm_radio could pretend flash player and stream music I think...
  • Last Edit: 17 September, 2008, 04:05:24 PM by foosion
my last.fm profile:
  • mobyduck
foo_lastfm_radio
Reply #59
I'm experiencing a little problem: song length always seems wrong (shorter than the actual duration).
Perhaps a last.fm problem but I'd like to make sure I'm not the only one seeing this.
Alessandro
  • halabund
foo_lastfm_radio
Reply #60
I have two questions:
1. Can it cause problems with scrobbling if the official Last.FM client is running in the background and scrobbling the tracks?  (I didn't notice anything like duplicate scrobbling, but I still wonder ...)
2. Is is possible to display the artwork from Last.FM (in a standard way)?  (I don't know if foobar2000 allows for specifying separate artwork sources.)
EDIT: I noticed Q2 was already asked.
  • Last Edit: 18 September, 2008, 09:22:52 AM by halabund
  • wojtek
foo_lastfm_radio
Reply #61
Is it possible to get rid of window which pop-up while updating playlist? Info only in console would suffice IMHO...
  • halabund
foo_lastfm_radio
Reply #62
It does not pop up when fb2k is minimized.
  • wojtek
foo_lastfm_radio
Reply #63
That's correct in general, but if you use foo_titleformat (which i've starded to use today) it does pop up
  • nausea
  • Developer
foo_lastfm_radio
Reply #64
New and improved version 0.4 is available. Check the original post for details.
It won't as foo_lastfm_radio doesn't scrobble.
I think I agree, and will look at this for future versions. Maybe.
I think this feature belongs in foo_audioscrobbler, but yes it would be nice to have...
  • Last Edit: 21 September, 2008, 05:34:29 AM by nausea
  • Hamallainen
foo_lastfm_radio
Reply #65
I must say WOW for the album art support.
It work really well with CUI here.
foo_lastfm_radio
Reply #66
thanks for the update, nice too see this is a great plugin
  • halabund
foo_lastfm_radio
Reply #67
Any track can be loved, but only those can be banned that are played through Last.FM radio.  The scrobbler (I think) has no way of knowing whether a track was played from Last.FM or a local file.  (But I may be wrong about this.)  If this is indeed the case then it is up to the radio player to implement the ban feature.
However, I (personally) don't care about the ban feature at all.  I could count on a single hand the number of times I used it.  The love feature (which I do use) I can access through the official scrobbler even when foo_lastfm_radio is used.
  • Last Edit: 21 September, 2008, 12:53:55 PM by halabund
  • nausea
  • Developer
foo_lastfm_radio
Reply #68
Thanks for the info. I'll bear that in mind.
  • _oao
foo_lastfm_radio
Reply #69
thanks for the update!
album art works great with the default UI
  • livedead13
foo_lastfm_radio
Reply #70
just had to say thank you. this is a great component!
  • TomBarlow
foo_lastfm_radio
Reply #71
Thanks for the update. Is there any way to get the album art into the Album Art Panel or do I have to use the inbuilt artwork system? The new inbuilt system is a bit limited for me.
foo_lastfm_radio
Reply #72
I'm using the Ibiza config and I'm not getting artwork being displayed anywhere, either in the EL Playlist or in the album list, what am I doing wrong?
  • halabund
foo_lastfm_radio
Reply #73
I believe that you have to use the built-in artwork system.
The very purpose of the built-in system is to allow for components to interoperate this way: one component can provide a new source of artwork, and another component can use it seamlessly, without having to have specific support for the first component.
  • ycz22
foo_lastfm_radio
Reply #74
