Topic: foo_lastfm_radio (Read 383923 times) previous topic - next topic
foo_lastfm_radio
Reply #250
@lynkS
in playback statistics custom  > playback statistics update timing  >select: disable (do not update)
I am from germany
foo_lastfm_radio
Reply #251
Since 22.4.09, as previously announced, last.fm radio is no longer free for users outside UK, USA and Germany and subscribers.
We all have just "30 songs trial", after that, radio is not available.
Is there any plans for adding the proxy option in the future?
Or maybe a creating a plugin for Spotify? Because that service has more music to offer.
Disregard the constabulary.
foo_lastfm_radio
Reply #252
still works for me... although i am a not a subscriber and i live in austria
foo_lastfm_radio
Reply #253
Have you listened to more than 30 tracks? (;
foo_lastfm_radio
Reply #254
yes i have... and besides:
1. Only subscribers will be allowed to stream using API applications unless you negotiate a separate deal with us - we need to get the money to cover royalties.
foo_lastfm_radio
Reply #255
Yeah, i hope this plugin will be still updated, because i'm subscriber myself, and i just don't like last.fm software.
foo_lastfm_radio
Reply #256
this is a great plugin! I never bothered with last.fm til now.  thanks!
I can't figure out the custom lastfm:// url format though.  Say I want to play the music on this page
http://www.last.fm/music/Various+Artists/Best+Of+2008
what do I need to enter as the custom url?  thanks
foo_lastfm_radio
Reply #257
No plan for a proxy on this component ?
foo_lastfm_radio
Reply #258
Unable to resume decoding at 1:02.145 (Unsupported format or corrupted file):
"FOO_LASTFM_RADIO://play.last.fm/user/3b0f8ac6fa4bb260bdb5d9b16308298c.mp3LASTFM"
I am always getting this error. I am using foobar 0.9.6.1 and Curacao config. Solution, anybody?
i also used to get that issue, but thanks to the post after this, it's fixed
thanks again for the great plugin, i hate the last.fm default application and use 2.0->5.1 upmix method, so this was way important for me
as a subscriber i've listened more than 40 songs (using xchange 2.0 config), and still works fine
foo_lastfm_radio
Reply #259
Sorry for the double post, but i forgot to ask something:
My foobar2000 freezes for 2-3 seconds as soon as a new song from last fm starts, it starts to play, but gui freezes, but after a couple of seconds it's back as it should be.
Is this normal? (does not happen in local media files)
foo_lastfm_radio
Reply #260
I think you can't play this url, as there is no radio. If you want to listen to that kind of music, click on the genre. Every genre has it's own radiostation. You can add those very simple:
Here is a page from one of the genre's of the music of your url: Classic Rock
Go to File > Open last.fm radio station > custom station > choose global tag in this case and enter classic rock. There you go. As you can see you can use more presets, like artists or neighbours stations and stuff. Works easy and like a charm.
foo_lastfm_radio
Reply #261
Do you still have to be from USA, UK or Ger to listen to last.fm radio without subscription?
P.S.: I'm from Ger and subscriber, but I think this last.fm behaviour is a cheek for all the other people - only my 5 Cent.
foo_lastfm_radio
Reply #262
I'm french, i'm not a subscriber, and I can't access the radio anymore with foobar, if I want to listen to the radio I use Ultra surf which is some kind of proxy which doesn't need any configuration.
Yes, I think it would be great for us, outsiders.
EDIT: Actually there is no need for that just have to fill in the proxy in networking in foobar.
Using ultrasurf you just have to run ultrasurf and use
localhost:9666
in foobar2000
Sorry for the bad english, I'm french .
foo_lastfm_radio
Reply #263
Hi, can you please help me how to add custom radio with long URI to my favourite stations in preferences? The URI editbox has limit to 35 characters. I know, that I can use "file/add location", but I would like to have it in context menu.
and thank you for this great plugin.
foo_lastfm_radio
Reply #264
First of all, let me say that this might very well be the best plugin of all times. Totally love it !!! Thanks for the hard work...
Now, i need some help with the cover art thingy, i'm stuck...
I'm using this skin for foobar2k (http://harun87.deviantart.com/art/fooPss-108019546) and i would like to show the cover art of the song being played in the "Album Art" panel in PSS.
The first thing i tried was to retireve it with $info(lastfm:imageurl). I added this line to the sources list of the "Album Art" panel but i realized it doesn't get images from the web
$if($stricmp($left(%path%,3),FOO),$replace($replace($info(lastfm:imageurl),http?,http:),?,/))
I then tried to use the advanced options to cache the image and then have AA open it from the local drive but i counldn't get it to save the image to disk in the first place.
Can someone help me ?? How do i configure this to save the cover art file to disk ??
Thanks in advance
foo_lastfm_radio
Reply #265
Thanks in advance
I replaced the "Album Art" panel with an "Artwork View" panel and configured this entry in ColumnUI's Artwork Sources
At least it shows a picture...
foo_lastfm_radio
Reply #266
could someone explain me the difference between Your personal Last.fm radio and Your playlist Last.fm radio ?
foo_lastfm_radio
Reply #267
I think that the personal radio is based on your listenings (your last.fm library) and the playlist radio is based on your playlists.
foo_lastfm_radio
Reply #268
i don't have playlists. i only use the library and the playlist radio seems to play almost the same mix like my library / personal radio. is this the correct reaction for that constellation?
are there subpages on last.fm where i can find the webview for the streams?
lastfm://user/<user>/personal
lastfm://user/<user>/playlist
foo_lastfm_radio
Reply #269
For showing albumart from last.fm radio I use $if($stricmp($left(%path%,3),FOO),$info(lastfm:imageurl),$replace(%_path%,%_filename_ext%,)folder.jpg), this works to pass album art to an external program (samurize in this case), so I think it will work for the different columns panels too.
foo_lastfm_radio
Reply #271
i don't understand your answer.
I dont want to create a playlist or something similar. I only want to know what music is played, if i play "Your playlist Last.fm radio" in comparison to what is played if i play "Your personal last.fm radio".
foo_lastfm_radio
Reply #273
i read all entries and doesnt get the answer, cause this all is only related to my library radio or playlist radio for created playlist, which i dont have :-)
foo_lastfm_radio
Reply #274
Support for multi-tag stations would be awesome. Almost as awesome as Last.fm's introduction of them in the first place.
