Topic: No playback of Ogg files encoded by Reaper (Read 6539 times) previous topic - next topic
  • Dandruff
Playback of Ogg files rendered by Reaper doesn't work in Foobar2000 (0.9.5.5)!
Foobar2000:
View -> Console: "Decoding failure at 0:00.000 (Unsupported format or corrupted file)"
I've tried many different encoding settings but none of them worked. Reaper itself can decode the file(s). Any ideas?
FIXED (Reaper 2.45pre3)
http://forum.cockos.com/showthread.php?t=24770
  • Last Edit: 16 August, 2008, 04:14:24 AM by Dandruff
  • Synthetic Soul
  • Global Moderator
VideoLan doesn't like it much either.  It will play it, but it thinks that it is 3 seconds long and 499kb/s.  It also has weird clicks and pauses when played.  As part of the Messages output, it also reports:
ogg warning: couldn't find any ogg logical stream
MPC recognises it as 10 seconds as per foobar, and appears to play it OK - that is if the clicks and pauses are supposed to be there (which it seems like maybe they are now).
I'm on a horse.
  • Dandruff
Yes, they are.
I also can confirm your findings. VLC plays it but is reporting wrong duration. Only Media Player Classic seems to do the job "properly" ...
  • Last Edit: 16 August, 2008, 04:15:21 AM by Dandruff
  • kjoonlee
Buggy encoder.
Processing file "reaper.ogg"...
New logical stream (#1, serial: 00152eca): type vorbis
Vorbis headers parsed for stream 1, information follows...
Version: 0
Vendor: Xiph.Org libVorbis I 20050304 (1.1.1)
Channels: 2
Rate: 48000
Nominal bitrate: 499.821000 kb/s
Upper bitrate not set
Lower bitrate not set
Negative or zero granulepos (0) on vorbis stream outside of headers. This file was created by a buggy encoder
Vorbis stream 1:
    Total data length: 198155 bytes
    Playback length: 0m:10.173s
    Average bitrate: 155.818600 kb/s
Logical stream 1 ended
Testing was done with ogginfo. BTW, running it through vorbiscomment fixed it.
Both ogginfo and vorbiscomment for Windows can be downloaded at RareWares.
http://www.rarewares.org/ogg-tools.php
  • Dandruff
@kjoonlee: thanks for testing this! hope it will help the reaper developers ...
  • jarsonic
I think Justin's going to fix it in the next release of Reaper; he's aware of it now.
  • Dandruff
Cool, thanks!
  • Dandruff
FIXED in Reaper 2.45pre3
http://www.landoleet.org
  • seaeye
hey - can you give more details about running them "through" vorbiscomment? i haven't found any option to remove / rewrite comments, but probably i'm looking at a wrong place.
thanks in advance.
a
  • kjoonlee
Oh. I just added a random comment with vorbiscomment.
  • seaeye
that made the trick! thank you!
