Topic: My Columns UI config · FooSune (Read 175570 times) previous topic - next topic
New version on August 16th. This is FooSune v.1.2
Change log (v.1.2):
- Replaced album art image by an Artwork view panel that has more features and supports embedded images
- Changed artwork path in ElPlaylist. (now no one should have porblems with artwork not displaying, and images should not get cut off)
- Added a playlist switcher, on the left side panel
- Added a playlist dropdown that you can use instead of the playlist tabs. You can now switch between them, or use neither
- Fixed "open directory" button
- Fixed issue with group headers not showing when there is only one track inside the group.
- Changed the "sort by fields" button back to the regular "sort by" dialogue.
[a href="http://img411.imageshack.us/img411/8206/11355941ie8.png" target="_blank"]
Otherwise, keep reading just a little bit.
LYRICS
Now, I'm pretty obsessive about lyrics, and I haven't found a component/program with an extensive enough database. So I combine minilyrics, with songmeanings.net (which has the most lyrics, I think) But I got tired of going to the site, searching for the song, creating the text file, naming it, etc... so I automated the process, to some point. This is what these 4 buttons are for. If you have a Lyrics-OCD like me, you might like how I do it, so I'll explain:
sune
thanks for this great config I will try it tonight
Can you say me which visual style do you use?
It's called amok. It's on deviantart, but I don't think I got it there, cause that one has an inner white border around the window that mine doesn't... Maybe a different version. I can't remember where I downloaded the one I use
Thanx Sune, and again great work, i like it
just a remark/request, could you change the path needed for images cause as many users of foobar, i switch often configs and it would be practice if path could be :
~foobar-directory~/images/fooSune/
and not
i think it is more clear for everyone.
What do you think about ?
and not
Shorten up the quote, that would be a great idea, Sune if you get the chance, i renamed everything, /images2
took a while lol, nice config though.
*The open directory button seems broke, at least it does NOT work for me.
just a question why you don't use the filter of Column_ui instead of foo_browser ?
okey.
This one is AWESOME! But I second the two recommendations above.. A seperate image-directory would be great and just using the Filter-function of columnsUI would make sense too. Esp. because Browser-plugin isn't developed anymore...
Another small hint: wouldn't it be possible to just use trackinfo_mod and not both the mod and the original? Would be cool. Thanks alot for this one!
By the way: you might take a look at the plugin "LyricsGrabber". It searches Lyrics on LyricWiki and works directly within foobar...
Sweet! :D:D:D
I was wandering if you were going to post it hehe
It works amazingly but the album art isn't showing up =[ any ideas?
when i importing fcl file i get a error..
"Illegal operation:
Code: C000001Dh, flags: 00000000h, address: 0146738Eh
Call path:
entry=>app_mainloop=>Create splitter host
Code bytes (0146738Eh):
0146734Eh:  CC CC 32 C0 C3 CC CC CC CC CC CC CC CC CC CC CC
0146735Eh:  CC CC C2 04 00 CC CC CC CC CC CC CC CC CC CC CC
0146736Eh:  CC CC 32 C0 C2 04 00 CC CC CC CC CC CC CC CC CC
0146737Eh:  CC CC 83 EC 28 8B 11 66 0F EF C0 B8 FF FF FF 7F
0146738Eh:  66 0F D6 44 24 20 89 44 24 20 89 44 24 24 8D 04
0146739Eh:  24 50 8B 42 54 6A 00 6A 24 66 0F D6 44 24 0C 66
014673AEh:  0F D6 44 24 14 66 0F D6 44 24 1C 66 0F D6 44 24
014673BEh:  24 FF D0 50 FF 15 DC F1 47 01 8B 44 24 2C 8B 4C
Stack (0012EBA0h):
0012EB80h:  F043D798 8057A001 BBE30000 00000001
0012EB90h:  F043D9DC 0000003B 00000083 007838B0
0012EBA0h:  004A2DF8 5A73E4C3 003CFFF0 01879ED0
0012EBB0h:  00000000 01879ED0 0012EBA4 01879ED0
0012EBC0h:  0012EBF4 004A52D0 01291067 0012EBE0
0012EBD0h:  0000000D 0000000D 0000000D 000000D4
0012EBE0h:  00000000 7FFFFFFF 00000000 7FFFFFFF
0012EBF0h:  01292610 0125CE54 0000000D 0000000D
0012EC00h:  00000000 00000001 458EFA15 01259D80
0012EC10h:  0125CC10 0012ECC0 00000013 7E428EAB
0012EC20h:  00000005 004F6F70 0125CCD8 00000000
0012EC30h:  00000000 00000000 406C2000 00000000
0012EC40h:  00000000 00000000 00000000 00000000
0012EC50h:  00000000 00000000 00000000 00000001
0012EC60h:  00000000 0012EC80 0000001B 012A3F64
0012EC70h:  01259878 00000012 00000012 00000002
0012EC80h:  0012EC90 0012ECDC 0129EEE3 00000001
0012EC90h:  01293011 0125CC10 0012ECB0 00000000
0012ECA0h:  0171B950 01259898 0171CFC8 00000014
0012ECB0h:  00000000 00000000 000000E1 000000E8
Registers:
EAX: 7FFFFFFF, EBX: 0000000E, ECX: 014A6518, EDX: 014801C8
ESI: 00000001, EDI: 000000C7, EBP: 0125CE54, ESP: 0012EBA0
Crash location: "foo_uie_wsh_panel", loaded at 01460000h - 01494000h
Loaded modules:
foobar2000                      loaded at 00400000h - 0052B000h
ntdll                            loaded at 7C900000h - 7C9AF000h
kernel32                        loaded at 7C800000h - 7C8F6000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F02000h
Secur32                          loaded at 77FE0000h - 77FF1000h
GDI32                            loaded at 77F10000h - 77F59000h
USER32                          loaded at 7E410000h - 7E4A1000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D7000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
COMDLG32                        loaded at 763B0000h - 763F9000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
foo_abx                          loaded at 00A60000h - 00A91000h
foo_albumlist                    loaded at 00AA0000h - 00B0C000h
foo_browser                      loaded at 00B20000h - 00B59000h
foo_cdda                        loaded at 00B80000h - 00BC1000h
foo_converter                    loaded at 00BF0000h - 00C57000h
foo_cwbowron                    loaded at 00C80000h - 00CAA000h
gdiplus                          loaded at 4EC50000h - 4EDF6000h
foo_dsp_std                      loaded at 00CE0000h - 00D29000h
foo_fileops                      loaded at 00D50000h - 00D96000h
foo_freedb2                      loaded at 00DC0000h - 00E00000h
foo_input_std                    loaded at 00E20000h - 00F4D000h
foo_rgscan                      loaded at 00F70000h - 00FCB000h
foo_run                          loaded at 00FF0000h - 0101E000h
foo_uie_albumlist                loaded at 01040000h - 01083000h
foo_uie_elplaylist              loaded at 010B0000h - 01114000h
foo_uie_lyrics                  loaded at 01140000h - 0119F000h
WININET                          loaded at 771B0000h - 7725A000h
CRYPT32                          loaded at 77A80000h - 77B15000h
MSASN1                          loaded at 77B20000h - 77B32000h
OLEAUT32                        loaded at 77120000h - 771AB000h
WINMM                            loaded at 76B40000h - 76B6D000h
SYNCOR11                        loaded at 6BD00000h - 6BD0D000h
foo_uie_panel_splitter          loaded at 01270000h - 012B8000h
foo_uie_quicksearch              loaded at 012C0000h - 01306000h
foo_uie_trackinfo                loaded at 01330000h - 0135E000h
foo_uie_trackinfo_mod            loaded at 01380000h - 013D6000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_uie_vis_peakmeter_spectrum  loaded at 01400000h - 0143F000h
foo_uie_wsh_panel                loaded at 01460000h - 01494000h
foo_ui_columns                  loaded at 015D0000h - 016F9000h
foo_ui_std                      loaded at 01720000h - 017F5000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_unpack                      loaded at 01820000h - 0184D000h
appHelp                          loaded at 77B40000h - 77B62000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
VERSION                          loaded at 77C00000h - 77C08000h
cscui                            loaded at 77A20000h - 77A74000h
CSCDLL                          loaded at 76600000h - 7661D000h
browseui                        loaded at 75F80000h - 7607D000h
SETUPAPI                        loaded at 77920000h - 77A13000h
ntshrui                          loaded at 76990000h - 769B5000h
ATL                              loaded at 76B20000h - 76B31000h
NETAPI32                        loaded at 5B860000h - 5B8B5000h
USERENV                          loaded at 769C0000h - 76A74000h
shdocvw                          loaded at 7E290000h - 7E401000h
CRYPTUI                          loaded at 754D0000h - 75550000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
SXS                              loaded at 7E720000h - 7E7D0000h
jscript                          loaded at 75C50000h - 75CCD000h
xpsp2res                        loaded at 02350000h - 02615000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 004A2DF8h, location: "foobar2000", loaded at 00400000h - 0052B000h
Address: 004A52D0h, location: "foobar2000", loaded at 00400000h - 0052B000h
Address: 01291067h, location: "foo_uie_panel_splitter", loaded at 01270000h - 012B8000h
Address: 01292610h, location: "foo_uie_panel_splitter", loaded at 01270000h - 012B8000h
Address: 7E428EABh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+0000018Bh)
Address: 004F6F70h, location: "foobar2000", loaded at 00400000h - 0052B000h
Address: 012A3F64h, location: "foo_uie_panel_splitter", loaded at 01270000h - 012B8000h
Address: 0129EEE3h, location: "foo_uie_panel_splitter", loaded at 01270000h - 012B8000h
Address: 01293011h, location: "foo_uie_panel_splitter", loaded at 01270000h - 012B8000h
Address: 01290CD5h, location: "foo_uie_panel_splitter", loaded at 01270000h - 012B8000h
Address: 0129ED71h, location: "foo_uie_panel_splitter", loaded at 01270000h - 012B8000h
Address: 0161C1A0h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B203Ch, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B3684h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B0664h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 01010000h, location: "foo_run", loaded at 00FF0000h - 0101E000h
Address: 016A016Eh, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 0161D3FAh, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 7E418B26h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 0166D410h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 7E4188D1h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7E4188DAh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 7E44048Fh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 0166D5A6h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E42BDF1h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "UserLpkPSMTextOut" (+000001CCh)
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+00000169h)
Address: 7E428EA0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000180h)
Address: 7E428EB0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000190h)
Address: 7E42CE7Ch, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "SetLayeredWindowAttributes" (+0000006Ah)
Address: 7C90E453h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 015D0000h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B3D00h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 7E428E53h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000133h)
Address: 7E42E389h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetScrollInfo" (+000003A7h)
Address: 7E42E34Fh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetScrollInfo" (+0000036Dh)
Address: 7C910202h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C919CA7h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+00000127h)
Address: 7C919DCDh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+0000024Dh)
Address: 7C919D8Ah, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+0000020Ah)
Address: 7C90E900h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "strchr" (+00000113h)
Address: 7C910208h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9101BBh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 7C9100A4h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C915219h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "bsearch" (+00000046h)
Address: 7C91540Bh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "bsearch" (+00000238h)
Address: 7C910098h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C910021h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C91003Dh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 016B3D4Eh, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 7C9157A1h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlHashUnicodeString" (+00000164h)
Address: 7C91532Ah, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "bsearch" (+00000157h)
Address: 7C915722h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlHashUnicodeString" (+000000E5h)
Address: 7C9155CDh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFindActivationContextSectionString" (+000000DCh)
Address: 7C910040h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7E419951h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IsChild" (+00000243h)
Address: 7C910303h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000025Fh)
Address: 015D0108h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 7C910308h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000264h)
Address: 7E4199E4h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IsChild" (+000002D6h)
Address: 7E419A12h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IsChild" (+00000304h)
Address: 7E41A303h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "ClientThreadSetup" (+000002F9h)
Address: 7E419A18h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IsChild" (+0000030Ah)
Address: 7E41A31Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "ClientThreadSetup" (+00000310h)
Address: 7E41A33Bh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "ClientThreadSetup" (+00000331h)
Address: 004E004Ch, location: "foobar2000", loaded at 00400000h - 0052B000h
Address: 7E419D60h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "UnregisterClassW" (+000002BCh)
Address: 7E471270h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E410000h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7C91017Bh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7E42E442h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetScrollInfo" (+00000460h)
Address: 016D3A6Ch, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 7C9101C0h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 01676250h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 7E41A3D3h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "RegisterClassW" (+00000039h)
Address: 7E42D0D6h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "CreateWindowExW" (+00000033h)
Address: 0166D291h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 015FC764h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016D50B0h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016D5098h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 0162FBA2h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016D2954h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 0169FE50h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 0162ED90h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B4D34h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B3694h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016D50C4h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 0162C17Ah, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016D5A04h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 0169FF38h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 0162C283h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 0162C28Ch, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B0788h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B0654h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 01669008h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016D355Ch, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B0A48h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B0A58h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B7B20h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B4D28h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 0166911Ch, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016A3002h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 0166534Fh, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 7E42BBF7h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DrawTextExW" (+000007E2h)
Address: 7E42B415h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DrawTextExW" (+00000000h)
Address: 016B87B4h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 7E42BC14h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DrawTextExW" (+000007FFh)
Address: 016B878Ch, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B8804h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B87DCh, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016B1550h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 01000003h, location: "foo_run", loaded at 00FF0000h - 0101E000h
Address: 016A175Fh, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016656FCh, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 0164FF20h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 016A2018h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 0164FFC5h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 7E423D3Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 7E423D5Ch, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 016A3AE8h, location: "foo_ui_columns", loaded at 015D0000h - 016F9000h
Address: 7E423CE4h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "EnumDisplaySettingsA" (+0000027Dh)
Address: 7E423D08h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "EnumDisplaySettingsA" (+000002A1h)
Address: 7E423B30h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "EnumDisplaySettingsA" (+000000C9h)
Address: 7E418816h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E41882Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+00000163h)
Address: 7E42927Bh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetParent" (+0000016Ch)
Address: 7E4292E3h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "SendMessageW" (+00000049h)
Address: 773F7354h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0000B4A4h)
Address: 773F7436h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0000B586h)
Address: 773F973Bh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0000D88Bh)
Address: 773F8EB4h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0000D004h)
Version info:
foobar2000 v0.9.5.5
UNICODE
Windows 5.1
Additional info:
Default User Interface 0.9.5  (foo_ui_std)
Track info panel 0.8  (foo_uie_trackinfo)
Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]  (foo_uie_trackinfo_mod)
ABX Comparator 1.3.3  (foo_abx)
ReplayGain Scanner 2.0.8   (foo_rgscan)
Startup Actions 0.0.2 [Jul 23 2007 - 08:27:55]  (foo_cwbowron)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
CD Audio Decoder 2.1.3  (foo_cdda)
File Operations 2.1  (foo_fileops)
ZIP/GZIP reader 1.0  (foo_unpack)
Album List 4.3  (foo_albumlist)
Converter 1.1.2  (foo_converter)
WSH Panel (uie) 0.7.2  (foo_uie_wsh_panel)
Standard DSP Array 1.0  (foo_dsp_std)
Run services 0.3.4  (foo_run)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
freedb Tagger 0.6  (foo_freedb2)
ELPlaylist 0.5.1.1(beta)  (foo_uie_elplaylist)
RAR reader 1.1  (foo_unpack)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]  (foo_browser)
Album Art Browser 0.0.5 [Jul 23 2007 - 08:27:55]  (foo_cwbowron)
foobar2000 core 0.9.5.5  (Core)
Columns UI 0.3 beta 2 preview 11e  (foo_ui_columns)
Panel Stack Splitter 0.3.4(alpha)  (foo_uie_panel_splitter)
Lyric Show Panels 0.3.1.1  (foo_uie_lyrics)
Peakmeter Spectrum Visualisation 0.2.0.0 beta  (foo_uie_vis_peakmeter_spectrum)
please help me with this problem
grrr ... use codebox please for long list like this!
so, your problem is due to that your CPU doesn't handle some instructions used by the component WSH Panel :
"Illegal operation:
maybe it is too old, what's the model of your CPU ?
btw, you can't use this config until you change to a newer CPU.
bye and remember to use codebox /codebox anchors please (you can edit your post above to add this anchors please, thanx by advance)
All fine so far, thanks for this cool conf.!
The only strange behavior are the tabs at the bottom:
Thank you very much, my foobar looks great now, thanks to you!
But... I've got one problem... The artwork doesn't work...  Any idea how to solve this problem?
I'd like to know as well =]
I've figured it out myself...
And for the big album art in the left corner you need to name the album art *directory name*.jpg where *directory name* is the name of the directory of the album, in where the picture is...
You need to go to Preferences/Display/Columns UI/Layout
Then select from above the second Panel Stack Splitter and choose Configure, then choose cover, in the left upper corner... Then you see this in the textbox below:
//change image path here if your cover pics don't show
$puts(img_path,$replace(%path%,%filename_ext%,Folder.jpg))
Though you don't see Folder.jpg but something like %directoryname%.jpg, but I've changed it to Folder.jpg... You can change it to whatever you want...
Well, then go back to Preferences/Display/Columns UI/Layout
Select the first Panel Stack Splitter from above and choose Conigure
Select ELPlaylist and choose Configure
Then, at the tab Track list go down in the textbox until you see:
/////-------------------------- Cover Art (and dummy)
In this line:
$puts(img_path,$replace(%path%,%filename_ext%,cover.jpg))
You can change cover.jpg in whatever you want
At the tab Group Header you see the same kind of line, you can change it again in whatever you want
And finally go to the tab general\
You can delete the line with _art_path_
And add it again:
To do that you have to press 'new'
And fill in this:
Name to be replaced: _art_path_
Replaced with: $replace(%path%,%filename_ext%,)cover.jpg in which you can replace cover.jpg for whatever you want
I hope it's all clear, but my english is not that good, and i'm also not great at explaining
But...
I have another problem
The 'Open Lyrics File' button doesn't work, and I can't get it to work, I've tried several things... can anyone help me?
THANKS!!!!!!
Now it looks so funking awesome! Thanks Sune as well
^^ I just read that last post, I'm glad you guys figured it out, but I actually changed it for v 1.1 and you don't really have to so all that
I used to use 2 sizes of images before, so I kept that for my config, thinking ElPlaylist would run very slowly with big image files. But now I realise that it writes to the memory only the size it displays, so it doesn't matter what the size of the image is.
So now I use the same path for all 3 places where it shows images, but you may possibly have to change it. See first post
and not
I think it's a very good idea. Done. The path is now images/FooSune
by the way, falstaff. thanks for your compliments. I like your ibiza congif a lot too. I downloaded it and took some ideas from it (mainly for the playback order buttons, using panels. I was going crazy trying to make them without cwb_hooks). So thanks
I have no idea why it doesn't work. In a clean installation it works for me. Anyone else has this problem?
Because I have been using browser and an old version of columns ui for ages, and I hadn't really looked into that feature. But now that I've tried it, I see that Filter does not allow to hide the headers, and this bugs me a lot. However, If you want to use filter, go to columns ui > layout, and in the panel splitter where there are 3 browser panels, add another 3 filter panels. Go to the splitter settings and give those new panels the same dimensions as the previous three. Don't forget to check "forced layout" in all of them. Then, delete the 3 browser panels, and you can remove foo_browser from your components
I use the original only because it automatically scrolls the playing track text at the top, and the other one for other stuff that can't be done with the original. I don't think it's too important having both of them
that's because "multiline tabs" is checked. If you download the new version it should be fixed. Or just change it yourself in columns ui preferences, under Playlist switcher
Great config. I got the albumart working thanks to Arrie, but I now have a question.
On my single songs, I added the albumart into the tags because I do not want to put every single single song in a folder. Is there anyway to make it show embedded art?
Did you follow the instructions exactly as they are? you could maybe post or pm me the steps you followed and maybe I'll be able to tell if something's wrong
I don't think so  You could, however, save all the artwork for singles into one folder, and point to that folder if the track playing is a single. If you want to do this I can help you tomorrow, gotta go
  I'd appreciate it very much if you could help me with that. Thank you.
Does anyone know how to change the album year on the left panel in to genre's?
Big thanks for the update and the insight in your decisions..! I'm quite sure you also have a reason not to you the ColumnsUI Artwork View feature, but Trackinfo Mod..? Do you think it would be possible to include the Artwork View-feature instead, because it also supports embedded artwork what is quite cool
Did you take a look at lyrcisgrabber-plugin? Guess you'll like it, though LyricWiki isn't the best database. But it looks like the plugin is designed to implement other sites soon (when u look at the options..)
One final word to the Albumart.. Maybe I've overseen something, but why don't you use the _art_path_ variable that's defined in ELPlaylist general? I'd setup the variable there to something like that (all in one single line.. I had to chop it here to be easier to read!):
$if3($findfile($replace(%path%,%filename_ext%,%directoryname%.jpg)),$replace(%path%,%filename_ext%,folder.jpg)),
$findfile($replace(%path%,%filename_ext%,*.png)),$findfile($replace(%path%,%filename_ext%,*.jpg)),
$findfile($replace(%path%,%filename_ext%,*.gif)),$findfile($replace(%path%,%directory%\%filename_ext%,*.jpg)),
$findfile($replace(%path%,%directory%\%filename_ext%,*.png)),
$findfile($replace(%path%,%directory%\%filename_ext%,*.gif)))
This makes it way more flexible - noone will have to fiddle in the code anymore I guess
Of course it would then be necessary to also use this variable in Tracklist and Group Header such as:
$puts(img_path,%_art_path_%)
This has also the advantage that everyone just has to change the variable and not the code in both tabs..
Just right click on the browser-panel and select Splitter Settings.
On the bottom change "Year" to "Genre" but more important on the top activate the second "Browser" entry and choose configure-button on the upper right. You can then choose the content of the filtering. If you want to add additional filters go to preferences/Browser Panel
Sorry for all the questions but I have one last one.
How do I get it so when I open it up it shows the browsers on the right hand side instead of album artwork?
Sorry again, but it would be awesome if someone could tell me
Doesn't matter have figured it out now
you mean the left side, I guess
and on startup it should show both the browsers, and the artwork below them. It doesn't in your foobar?
anyway, if you right click the black tab buttons, and go to splitter settings, there you see a list with: cover, info, lyric show, browsers, album list.
info, lyric show, and album list are set to "hide panel on startup". browsers and cover art isn't. If you want to change which ones are hidden when you start you can do it there
edit: good
the album art is not in a trackinfo mod panel, it's in the panel slplitter itself.  I hadn't really looked into the new columns_ui, but I think it's a good idea for people that use embedded art. (so, Mr.Broly, if you wait just a little bit I'm going to look into it and probably make v.1.2 with embedded art working)
and about the image path.. you haven't overseen anything, as I said (and underlined ), I have made this for myself, mostly, and the idea of sharing the config came later, so I was not really taking into account everyone's possible needs. besides, I'm not really a foobar code expert, so I just went the easy way.: one image path, and if it doesn't work for you, I'll help you change it
but I take suggestions  , and yours are very good, so I'll try to make those changes for next version
thanks for your input
