Topic: Song fingerprinting tools (Read 47763 times) previous topic - next topic
  • musicmusic
  • Developer
I found an old copy of libFooID and decided to try and put it to some use. How is another question..
Anyway I came up with a little component that allows you to calculate FooIDs and save them to the file, as well as compare the FooID of two files. Some downloads below:
FooID binary (put this in your foobar2000 folder)
foobar2000 component version 0.3 (experimental)
foobar2000 component version 0.2 (experimental)
libFooID source
Update: Garf has restored the Foosic homepage now
I am not sure how this is useful.. Maybe finding matches within a set of files would be more useful (?) If someone actually downloads this have fun : P
  • Last Edit: 15 March, 2009, 10:31:59 AM by musicmusic
  • Nemphael
Eager to try this. I've tried to get this working, but I can't. I've put the FooID folder in foobar2000 as specified and I slipped foo_biometric into components. Upon starting Foobar, I get an error:
Failed to load DLL: foo_biometric.dll
I'm using fb2k 0.9.5.4. Do I need to do something with the source code?
As for a suggestion: Would it be possible to generate an ID (As I suppose FooID means fingerprint) from the fingerprints so we can use other search utilities to search for matches as well?
It would also be useful to compare one file against, or compare fingerprints within, a set of files.
EDIT: Nevermind the error. Merely a mistunderstanding.
  • Last Edit: 08 August, 2008, 06:34:51 PM by Nemphael
  • musicmusic
  • Developer
Hello,
Check that FooID.dll is in the same folder as foobar2000.exe. (OK, seems you have solved this now.)
If you run the save command it will save the fingerprint in the FINGERPRINT_FOOID field. But to compare two fingerprints you need to interpret the data, so plain text searching won't achieve anything. So maybe some APIs would be useful if anyone would actually use them
If you save the fingerprints first the compare command will use those instead of recalculating the fingerprint (that command doesn't save them).
Agree on the usefulness of comparing one file against a set or finding matches within a set.. The main obstacles are probably creating the UI for these things
  • Nemphael
I doubt it, but would it be possible to compare fingerprints and find song with similar acoustic characters? Kind of like MusicIP's Mixer (earlier Music Magic Mixer), although I reckon they use another technique than fingerprint information for this.
  • Last Edit: 08 August, 2008, 08:41:51 PM by Nemphael
  • foosion
  • Moderator
The libFooID documentation contains information on how to do this (see copy of FooID documentation on archive.org). Note that this is intended to identify different encodings or maybe even performances of the same song, it is not designed to be able to - say - correlate two songs containing violins.
  • Last Edit: 09 August, 2008, 06:44:13 AM by foosion
  • hesher
This is genius! Where can i find more information about it?? I'd love to be able to "fingerprint" my mp3 library! (i know i have duplicates of alot of files)
  • Nemphael
I've tried running it to compare some files and I'm surprised at how well some of my acoustic vs. non-acoustic performances get a rather high score, despite notable differences in drums, electric guitar and some audience (3 Doors Down's Kryptonite 3:55 vs. Kryptonite (acoustic) 3:59 = 35%).
But I keep wondering - would it be possible to have a slider of some sort to change thresholds to, say, include less similar live/acoustic/instrumental performances?
  • musicmusic
  • Developer
Hi.. if you want to know more about FooID foosion's link can tell you more, or a little bit of general information is available on Wikipedia.
Currently you can only compare two files at a time with the component.. something for multiple files will be added later.
I can get about 33% on different songs by the same artist, although they are slightly similar. But anyway I am not sure how significant or useful these low scores are.. testing on many files may give some answers.
for the two file compare it is not particularly useful, but for multi-file commands yes I was probably going to do that, as it would only return tracks within the set thresholds. As for whether changing the thresholds would have any useful effect, that is another question.. for reference the levels are currently set at:
no: 0 <= i < 50
maybe: 50 <= i < 75
yes: 75 <= i <= 100
where i is the given percentage
  • musicmusic
  • Developer
Version 0.2 released:
  • 'Save fingerprints to files' uses multiple threads where multiple CPU cores are available
  • Added multiple file 'Compare Files' command. Note: Generally the minimum threshold should not be set below 50% (and especially not 0% ) If you are happy to tag your files with the fingerprints it is a good idea to run the save command first.
With the new multiple file mode I was able to do some more testing. My observations about match levels are below:
75-100%: Correct matches or slight variations of the same track (extra featured artist or other slight difference in vocals)
50-75%: Generally different versions of the same track (extra featured artist etc.), and a few correct positives.
0-50%: matches don't seem to be of any useful significance
  • Last Edit: 15 August, 2008, 10:40:55 AM by musicmusic
  • Nemphael
I tried your new version and like the new mass comparison. I've noticed, though, that every match will show up twice. For instance, "Track a" will match "Track b", but at the same time "Track b" will match "Track a". Is this behavior intended?
  • Garf
  • Developer (Donating)
Hey,
great that someone found a nice use for libFooID.
I will try to bring back the libFooID site. The fingerprint server probably will not come back. The resource usage on the server is just too big.
  • musicmusic
  • Developer
It's kind of intended.. Song b may match some other songs that song a does not. It could group them all together but it somewhat reduces the quality of information provided, so I have not.
Hey,
Hi Garf  Yes I surprised myself and found a few duplicates in my library  Yes it would be nice to get the libFooID site back
Whilst I was looking around on the net, I found some discussion of an oddity in regress.c. On line 66, it does this test:
if (ssyy <= 0.0f + EPSILON)
and sets *r, but it then divides by ssyy and sets *r again. Basically, the test does nothing. It seemed there was a missing else statement so I changed that (in the downloads above also), but it would be nice if you could confirm..
  • Last Edit: 15 August, 2008, 07:39:48 AM by musicmusic
  • Nemphael
After trying to remove some duplicates, I have a suggestion. The window notifying the user about duplicates isn't really useful, as you can only go to one file at the time. I see how this is useful, but it doesn't allow the user to compare the files himself on a grand scale. How about making a "duplicate-sorted" playlist with the results?
  • musicmusic
  • Developer
What about being able to play the tracks directly from the results window (double click) instead? That I will add anyway. Maybe a delete command on the shortcut menu as well.
Otherwise yes I could add a button to flatten the tree into a playlist, but the resultant playlist may be slightly confusing.
  • MartDann
I think all of your suggestions could be very usefull.
For example: I could make a run over my complete Music Lybrary, put all doubles in playlist und check this playlist later when i have time.
  • mpioner
musicmusic
Maybe you can make local version foosic.com?
  • Nemphael
With the ability to generate FooID fingerprint and possibly have a local Foosic database; what about making a database component to pick up where foo_custominfo left? It's a component I really wish further development in. FooIDs should allow the database to match up files and data which could allow, for instance, play count update of multiple song (released on multiple albums?), songs moved with Explorer or similar.
  • Last Edit: 26 August, 2008, 09:29:12 AM by Nemphael
  • 2E7AH
so, this component is only for finding duplicates among songs.
even if i set min threshold to 25, i'll only get songs which have a similar length, although not all tracks with similar length + some are without any audio similarities!?
i don't know the contents of fingerprint data (424 hex num: 3rd, 4th and 5th are length i guess) and i don't know those "algorithms" from foosion link + some kind of limitation to song length, but isn't there a way to code option about finding similar tracks in means of audio (music) content or something other than just looking for duplicates?
with no means to disrespect the work on this components, but for most duplicates search scripts are sufficient (and faster).
  • Last Edit: 02 September, 2008, 10:14:39 AM by 2E7AH
  • odyssey
I second this request, simply because I don't wanna delete all duplicates, but maybe I'll mark a track or do other stuff with it.
  • musicmusic
  • Developer
You are not supposed to set it to 25 (for anything other than testing). See my table in post #8.
I had a few duplicates under different song titles - how are you going to find that with a text search ?! Fingerprinting has other potential uses also which aren't exploited here. Maybe you don't find it useful but at least I do
  • odyssey
I had planned to use php's similar_text() to find duplicates  But still a fingerprint is more reliable.
  • Last Edit: 20 October, 2008, 03:51:06 PM by odyssey
  • musicmusic
  • Developer
I meant completely different.
  • 2E7AH
i've read the posts, but i was playing with the component so i post some of that
my library and my incomes are quite neat, so it's subjective matter anyway.
fingerprinting is time consuming.
perhaps i should have asked only my main question: isn't there a way to code option about finding similar tracks in means of audio (music) content or something other (not depending on track's length)?
i've read the posts #4 & #5
can you explain, if it isn't too much trouble?
  • Nemphael
This is what foo_biometrics does - it creates fingerprints of audio data and compares them. It has a quick match of +-30 seconds, I believe (Could be extended, could it not? Any benefits from this, you think?), as it intends to identify duplicates tracks rather than to extract certain elements. If I'm not mistaken, foo_biometrics is built from FingerPrint.java, which to me looks more like a duplicate finder than an audio comparator.
  • Last Edit: 21 October, 2008, 07:11:08 AM by Nemphael
  • OCedHrt
Hey,
What kind of load are we looking at?
