Topic: bug? playback becomes muted... (Read 2819 times) previous topic - next topic
Hola,
I've recently experience a strange error in foobar...
When I start playing a track, and try to seek in it somewhere, the music suddenly becomes mute (playback still going on) When I touch the volume slider, the volume quickly becomes normal again - another seek, and becomes muted again.
Also, when I exit while playing, I get an error (unrelated)
Any tips? Thanks....
It looks like foo_audioscrobbler is the problem. Are you using a version from here: http://www.hydrogenaudio.org/forums/index....=44320&st=0 or from the official site?
The one you point to is an old version - I've tried with that, with no results (also tried to remove it). I'm using the one the Last.fm client provides (2.1) but it doesn't seem to affect my problem... - it seems the error message is unrelated to this.
It's not so much an "old version" as it is a different version. Try using this version, it's working without any problems for me (and for a lot of other users).
As I've said, I already tried to use both, but the seek problem remained...
What output mode are you using?
