Topic: Sorty by Date Modified, Album,Track No (Read 9803 times) previous topic - next topic
  • squapp
I would like to sort my playlists by date modified so that my newest additions are on top of the playlist. Therefore I added a %last_modified% column in Foobar 0.9.5.4 . When I click on that column the playlist is sorted by date modified and albums, but the track numbers are not in order.
How can I have both track numbers and date modified sorted ?
  • smkk
ALL SORT DESCENDING BY %last_modified%
should do the trick.
Though you might want to give Playback Statistics a try, it adds a proper %added% tag and other statistics. %last_modified% changes every time you change a tag or something, the %added% tag will be static.
  • Last Edit: 03 August, 2008, 05:34:23 PM by smkk
  • squapp
Thanks for the answer, but the tracks still are not in order when applying
. That is due to the tracks' date modified are not in order, meaning e.g. track 1 has 9:33:01 , while track 3 has 9:33:00 so that track 3 is put before track 1.
