Topic: export/import tags into eac (Read 2516 times) previous topic - next topic
  • stephentw
I've got some stuff in mp3 which I'm about to re rip from CD's to flac, the tags on the mp3s are fine and I don't want them to get messed up with the freedb downloaded ones cos it took me ages to correct them the first time around.
I noticed in EAC theres an import tags option but I've never had any sucess with it. Is there a way I can use something like mp3tag to export my old mp3 tags to files then use eac to import them before I rip the CD? If so how do I go about it?
I've done a search but can't seem to find anyone asking similar, hope this is the right forum
  • greynol
  • Global Moderator
Hold up.  Are these data CDs with mp3 files, or are they audio CDs where the mp3s have been decompressed back to PCM format prior to burning?
I am not familiar with such a function.  Can you tell me where it is located within EAC?
It isn't, but once we figure out exactly what are on these CD-Rs of yours, maybe we can get this rectified.
  • Last Edit: 09 July, 2008, 02:11:59 PM by greynol
  • stephentw
They're not CDR's with data/mp3's on they're original CD's with audio on them  but I also already have mp3 versions of the CD's with perfect tags which I want to use when making the new flac's.
The thing I thought would work is in Tools> Rename from id3 tags (I presumed that would let me use some previous files to rename the current CD before I start the rip). Or I noticed some things in the database menu I thought might work? Just kinda stabbing in the dark here though.
