Topic: TrackInfoMod Alignment (Read 3620 times) previous topic - next topic
Hi Guys
I'm looking for some help on how to align text in trackinfomod (only just started using it).
Lets say I've currently got this:
Artist: some artist
Title: some title
Album: some album
Comment: some comment
How would I align the above text the following two ways:
1.
Artist:.......some artist
Title:.........some title
Album:......some album
2.
......Artist: some artist
........Title: some title
.....Album: some album
In the above examples the alignment is slightly off but you get the idea.
Any help would be appreciated.
made more than one for every row
one label (artist) second label (some artist)
simple
Hi
Thanks for the reply.
But my titleformatting knowledge in general is pretty basic and I have no prior experience with trackinfomod so it wasn't of much help.
Can anyone provide some example code on how to do the above alignments. I'd be able to work off that.
For what it is worth, I suggest splitting the task into two sections. First the labels then the data. You can then draw each of the labels using a textbox with either left or right justification and then draw each of the data using left justification.
For Example 1:
// Labels
$alignabs(0,0,40,10,left,)[Artist]:
$alignabs(0,10,40,10,left,)[Title]:
$alignabs(0,20,40,10,left,)[Album]:
// Data
$alignabs(40,0,100,10,left,)%album artist%
$alignabs(40,10,100,10,left,)%title%
$alignabs(40,20,100,10,left,)%album%
For Example 2:
// Labels
$alignabs(0,0,40,10,right,)[Artist]:
$alignabs(0,10,40,10,right,)[Title]:
$alignabs(0,20,40,10,right,)[Album]:
// Data
I need a little help with an alignment issue:
Latest foobar 9.5.3, columns ui with one trackInfoMod window.
Please understand that my programming skills are very, very superficial.  I am trying to learn as I really like foobar.
I am trying to export my config file from my desktop to my laptop.  Foobar was originally configured on my desktop at 1600x1200 screen resolution.  When displayed on my laptop which has a max resolution of 1200x800, everything is shifted way to the right.  There is one thing I need help with:
I draw a box, color it, etc:
$drawrect(0,0,1000,0,pencolor-158-35-0 brushcolor-255-255-255 blur-200)
The 1000 value is the new width that was changed from 0 to fit the lower resolution screen.  This worked ok.
My next line of code prepares to center and set fonts for what's coming:
$align(center,middle)$font(,30,,SYSCOL-20)
then I go into if statements checking for tracks, etc.
My problem is that the align function does not center my text into the box I just drew with the drawrect.  It's still shifted to the right, and for the life of me I can't figure out why. I tried alignrel with same results.  What am I doing wrong?
Any help would be highly appreciated!!
Ok I figured out the above problem.  All I had to do was to use the $alignabs(X,Y,w,h,H,V) function PROPERLY.
Cheers!
