Topic: Columns UI appearance (Read 1520775 times) previous topic - next topic
  • emte
Reply #1800
I was thinking of making these images display in different colours but I don't know how to make them dependent of genres. Wanted to make the same classification as on the page of the pleasurize foundation.
  • aeidein
Reply #1801
Do you have to manually scan each album with the DR component?
  • C3POwen
Reply #1802
I guess you could do this if you had different versions of the DR images, sorted out into different folders, and then used a combination of $if functions, but it might over-complicate things. You could always use the colour scheme from the Unofficial DR Database, as you'd only need one set of DR images.
You do, and you need to ensure that it is set up to write the values as tags in the selected files.
You can set this in File > Preferences > Advanced > Tools > Dynamic Range Meter > Write DR meta data tags
  • emte
Reply #1803
Yeah, I have these images grouped into three categories and it is divided on the website, but I can't implement the division into foobar. In other words, I can't make one set apply only to specified genres and, and likewise with the others. Tried $if functions but nothing comes out of this.  If I don't find a way to make it, I may stick to the unofficial scale.
  • Last Edit: 12 March, 2012, 11:51:00 AM by emte
  • C3POwen
Reply #1804
You may be able to get it working using something like this:
$if($and(%album dynamic range%,$or($stricmp(%genre%,classical),$stricmp(%genre%,soundtrack))),$imageabs(x,y,w,h,skins\dynamicrange\HIGH\DR%album dynamic range%.png),)
$if($and(%album dynamic range%,($or($stricmp(%genre%,alternative),$stricmp(%genre%,pop),$stricmp(%genre%,rock))),$imageabs(x,y,w,h,skins\dynamicrange\LOW\DR%album dynamic range%.png),)
You should then be able to use the $or function to specify more genres. If anyone has a more elegant solution, then please feel free to suggest.
  • Abraxas
Reply #1805
My first config ever
  • chiwou
Reply #1806
nice and where is the download?
  • Abraxas
Reply #1807
Well, as it is my first try I have there real mess in code. Some absolute paths. I don't even know how to properly put it all together for download.
  • sollniss
Reply #1808
DUI kind of style which focuses on usability rather than fanciness.
The very act of observing, influences what happens.
Reply #1809
You can just pack your whole folder, the experienced users will figure all the necessaries out.
I like yours.
mad messy misanthropist morbid mused
  • MDMA
Reply #1810
I suggest you use a portable copy of foobar, then its just a case of zipping up your foobar2000 directory if you want to share it with someone, they can then run it 'straight out the box'
btw might I say its a slick config, another request for you to share it!
  • Last Edit: 14 March, 2012, 02:14:30 PM by MDMA
  • Abraxas
Reply #1811
Thank you for tips. I'll release it as soon as I finish all small tweaks. Also there will be at least 4 color themes available (green, blue, fire, glamour). I hope to finish it later today.
  • tdisbd
Reply #1812
slate 1.0 with dockable panels
  • Falstaff
Reply #1813
nice
  • Falstaff
Reply #1814
trying my WSH CoverFlow script in my Slate config:
  • BiTeLSE
Reply #1815
Fancy! Composition with your skin is impressive. I'm curious how it will work compare to other cover flows plugins. I don't use any because loads are too high for me. Or should I say: to my PC
EDIT:
Heh, just saw beta version on dA. Time to test.
  • Last Edit: 17 March, 2012, 12:09:25 PM by BiTeLSE
  • prateek88
Reply #1816
[quote name='Falstaff' date='Mar 17 2012, 16:25' post='789767']
wow....looking forward for the release.... , scrollbar in addition would be a nice idea
  • Falstaff
Reply #1817
horizontal scrollbar already added, just turned off of this preview. More screenshots here + get the script (beta) : http://fav.me/d4t4lh7
  • SenzaCoil
Reply #1818
  • MacStew
Reply #1819
Will download this with pleasure
  • robollama
Reply #1820
A skin I made has no borders around the filters on my computer, but whenever anyone installs it they get these white borders:
What do I need to do so that when people install it they don't have the borders?
  • tdisbd
Reply #1821
not finished yet
Reply #1822
not finished yet
THIS WILL BE VERY GOOD !
Reply #1823
Looking forward to downloading your config too
  • Corey
Reply #1824
Guys, how can I learn to solve this problem, don't know what to do, to sort this ones in correct order : ) noob here alert!!
