Topic: Columns UI appearance (Read 1508384 times) previous topic - next topic
  • aeidein
Reply #1775
I toggle panels with hotkeys: http://i.imgur.com/r3rRv.jpg
I've kinda run out of things to do with it.. unless anyone knows how to make a custom seekbar (one with time elapsed/remaining on the left/right)  or custom volume slider with Columns?
also, is it possible to hide the titlebar?
  • ojdo
Reply #1776
Look at WSH Panel mod. Both functions can be accomplished by some lines of code. I think both functions are even part of the example scripts available on the Google Code homepage.
  • Last Edit: 16 February, 2012, 08:40:36 AM by ojdo
  • sortitus
Reply #1777
After shuffling things around for a couple weeks, I've settled on this minimal setup. Pretty straightforward NG Playlist with album artist groups, a handful of autoplaylists and the search function instead of a library browser, and icons for nearly every feature I ever use. Tabless freedom!  Now to see if I can find a non-terrible sans font that will let me ditch the stars for half full diamonds...
Reply #1778
With NGPlaylist
Hello Xin-Hong, which is the font you are using in playlist? Thanks.
  • Solynth
Reply #1779
Here's my ugly Foobar at the moment. I'm happy with the layout, but I just want to get rid of the ugly Windows elements like the scrollbars and columns headers and replace them with a custom design.
I've seen this done before without people having to change the way their Windows looks with Windows Blinds and such. Does anyone know how?
  • kt748
Reply #1780
I came to Foobar from the Zune software's album art-centric system which was a huge breath of fresh air compared to the ubiquitous iTunes music-collection-as-excel-spreadsheet convention.  I also wanted very much to avoid too many components or any scripting in order to keep things as 'light' as possible.  After a few months of tinkering, I'm pretty happy with my layout:
browse:
filter:
playlist:
now playing:
minimized:
  • Last Edit: 21 February, 2012, 07:21:04 PM by kt748
  • Xin-Hong
Reply #1781
With NGPlaylist
PT Sans Narrow
Reply #1782
I'm curious about how the extra line of information under the group titles was done (with Disc 1, Disc 2, genre, country, etc.).
Is this just some standard Columns UI scripting that I've not seen before, or is something else at play here?
Can someone tell me what can be used to get filtering tabs like the one in the picture above with artist genre etc?
Reply #1783
lettuceman44, it's just a tab stack splitter with different filters in it...
Reply #1784
I guess I'm really nooby, but every time I place a tab filter, its always artist? How do I change it?
  • marc2003
  • Developer
Reply #1785
right click the header.
Reply #1786
Well.......err
This is awkward now.
  • MacStew
Reply #1787
fooxgen3-alpha2
  • robollama
Reply #1788
Does anyone know how to hide the artist/album/genre filter captions?
  • Last Edit: 04 March, 2012, 10:35:10 PM by robollama
  • bigonroad
Reply #1789
Anyone want to point me to a nice tutorial, or wiki page on how to really use Columns UI.
How I replace things with images, etc.
A few more sample layouts with detailed instructions would be cool, because then I could pick that apart and work it out...
Bless,
Chris
  • robollama
Reply #1790
Anyone know if it's possible to change this?
I would love to use it but with the theme I'm making it sticks out like a sore thumb. I really need to change the colors or a search bar that I can change.
  • nickdc
Reply #1791
Try using quicksearch plugin.
  • robollama
Reply #1792
Perfect! Thanks a ton
  • Emka
Reply #1793
Here is what I used to work on for quite some while (without any scripting abilities) and what I have been using for several months now:
I made it with the additional components Playlist Organizer, EsPlaylist (Hidden, Auto Hide) and Biography View.
  • Last Edit: 08 March, 2012, 11:49:32 AM by Emka
  • C3POwen
Reply #1794
An update to my previous post a few months ago.
Since then, I've updated the group display and added Dynamic Range tags automatically by using the plugin from here so that it displays the correct image on the right.
  • derty2
Reply #1795
C3POwen,
I assume your playlist viewer is NG Playlist.
I have the foo_dynamic_range component installed; can you explain the steps of how you make that Dynamic Range image automatically appear in the playlist viewer display.
  • chiwou
Reply #1796
I don't think its NG playlist, hence the size of the header and the graphics I assume its el playlist
  • emte
Reply #1797
C3POwen,
I'd also like to know how you these DR images appear automatically.
  • marc2003
  • Developer
Reply #1798
it's ELPLaylist. each group header and row for each playlist item is like a blank canvas and you can position text and images anywhere you like.
  • C3POwen
Reply #1799
C3POwen,
As chiwou and marc2003 both correctly said, it is indeed ELPlaylist that I'm using.
As for the Dynamic Range images, these are first created using the "Copy DR value/logo" function within the component after it has run, and I then created a .png of each value by pasting the logo into an image editing program. As the DR component can write the dynamic range to the files as tags, I use this as the basis for a small script to show the correct value, on a per album basis. The component actually writes two tags per file: %dynamic range% and %album dynamic range%, which are both purely whole numerical values. The script I use is this:
$if(%album dynamic range%,$imageabs($sub(%el_width%,52),49,42,42,skins\dynamicrange\DR%album dynamic range%.png,),)
The script is just a simple $if argument, which checks for the album dynamic range tag in the file and displays the relevant image, as long as it is named correctly. If there is no album dynamic range information, it doesn't display anything at all, but that can always be modified.
More information on the $imageabs function can be found here.
I've included links to the images that I created, in both the default blue and the modified grey that I use in the skin:
- DR images (blue)
- DR images (grey)
At the moment I've only got images covering a range between 1 and 20, as I don't have any music that has a higher range than that.
