Topic: Columns UI appearance (Read 3321647 times) previous topic - next topic
0 Members and 14 Guests are viewing this topic.
Reply #350
@jeremija
Yes, it is ELPlaylist, and the code is very very simple (and will mostly stay as it is, except text in group header. i think about changing $drawtext/ex with $drawstring to use glow-options)
I haven't had any idea how to code ELPlaylist, so i asked falstaff if i can modify his curacao one.
I learned a lot from it, but then wrote my own (the layout is still leaned on curacao though), because curacao respects too many things i'd never need (last.fm and playback statistics) and as i mentioned earlier, i want to keep my setup as light as possible.
I don't know if this is the right place for it, but if you're interested in, here is the code:
Track List
// Background
$enabledraw(%el_is_valid%)
$if(%el_isplaying%,
$drawroundrect(0,0,$sub(%el_width%,1),$sub(%el_row_height%,3),2,2,0-0-0-0,%__BG_COL__%-64,)
$gradientrect(1,1,$sub(%el_width%,2),$sub(%el_row_height%,3),%__BG_COL__%-$if(%el_selected%,128,96),25-40-51-$if(%el_selected%,128,96),),
$drawroundrect(0,0,$sub(%el_width%,1),$sub(%el_row_height%,3),2,2,%__BG_COL__%-$if(%el_selected%,24,0),%__BG_COL__%-$if(%el_selected%,48,24),))
// Per Track
$font(Tahoma,10,bold)
$if(%el_isplaying%,
$drawtext($char(9835),5,1,16,16,128-128-128,right top)
$drawtext($char(9835),4,0,16,16,255-255-255,right top),)
$font(Segoe UI,8,)
$drawtext([$num(%tracknumber%,0)],0,2,72,%el_row_height%,%__TL_TXT__%,right top)
$font(Segoe UI,8,bold)
$drawtextex([$upper(%track artist%) $char(9679) ]%title%,86,3,$sub(%el_width%,210),%el_row_height%,%__TL_SHADOW__%,right top end_ellipsis)
$drawtextex([$upper(%track artist%) $char(9679) ]%title%,85,2,$sub(%el_width%,210),%el_row_height%,%__TL_TXT__%,right top end_ellipsis)
$font(Segoe UI,8,)
$drawtextex($repeat($char(9734),5),$sub(%el_width%,100),2,56,%el_row_height%,%__TL_SHADOW__%,left top)
$drawtextex($repeat($char(9733),%rating%),$sub(%el_width%,100),2,56,%el_row_height%,%__TL_TXT__%,left top)
$drawtext(%length%,$sub(%el_width%,44),2,39,%el_row_height%,%__TL_TXT__%,right top)
Group Header
//Background
$drawroundrect(0,0,$sub(%el_width%,1),$sub(%el_height%,3),3,3,%__BG_COL__%-$if(%el_isplaying%,96,48),%__BG_COL__%-$if(%el_isplaying%,128,96),)
//Per Group
$font(Segoe UI,12,bold)
$drawtextex([$upper(%album artist%)],$add($mul(%el_height%,2),2),5,$sub(%el_width%,$add($mul(%el_height%,2),6)),22,%__GH_SHADOW__%,right top end_ellipsis)
$drawtextex([$upper(%album artist%)],$mul(%el_height%,2),3,$sub(%el_width%,$add($mul(%el_height%,2),6)),22,%__GH_TXT__%,right top end_ellipsis)
$drawtextex([%album%],$add($mul(%el_height%,2),2),23,$sub(%el_width%,$add($mul(%el_height%,2),6)),22,%__GH_SHADOW__%,right top end_ellipsis)
$drawtextex([%album%],$mul(%el_height%,2),21,$sub(%el_width%,$add($mul(%el_height%,2),6)),22,%__GH_TXT__%,right top end_ellipsis)
$font(Segoe UI,8,normal)
$drawtext(%el_item_count% $ifequal(%el_item_count%,1,Track,Tracks) $char(8226) %el_sum_length%,$add($mul(%el_height%,2),1),45,$sub(%el_width%,$add($mul(%el_height%,2),6)),16,%__GH_SHADOW__%,right top)
$drawtext(%el_item_count% $ifequal(%el_item_count%,1,Track,Tracks) $char(8226) %el_sum_length%,$mul(%el_height%,2),44,$sub(%el_width%,$add($mul(%el_height%,2),6)),16,$if(%el_isplaying%,255-255-0,192-192-0),right top)
$drawtext([%genre%][ $char(8226) $if(%release date%,%release date%,%date%)],$add($mul(%el_height%,2),1),59,$sub(%el_width%,$add($mul(%el_height%,2),6)),16,%__GH_SHADOW__%,right top)
$drawtext([%genre%][ $char(8226) $if(%release date%,%release date%,%date%)],$mul(%el_height%,2),58,$sub(%el_width%,$add($mul(%el_height%,2),6)),16,$if(%el_isplaying%,128-192-255,64-128-192),right top)
//Album Art
$drawroundrect(6,6,$sub(%el_height%,15),$sub(%el_height%,15),2,2,%__BG_COL__%-128,255-255-255-48)
$imageabs(8,8,$sub(%el_height%,18),$sub(%el_height%,18),%__FOO_PATH__%NoCover.png)
$imageabs(8,8,$sub(%el_height%,18),$sub(%el_height%,18),%path%,artreader)
$if(%el_isplaying%,
$imageabs(%el_height%,6,$sub(%el_height%,14),$sub(%el_height%,14),%__FOO_PATH__%GroupPlay.png),
Per Second is still clean (i wanted to have it available for the group header. Do you have an idea how to do this?)
Popup (Background) and Popup (Track) are default, because i don't use it...
Field definitions:
http://xs.to/xs.php?h=xs433&d=08484&am...ield_def804.png
Reply #351
@jeremija:
I Like your last config and hope it will be release soon because it seems to be light and useful
Reply #352
this is my foobar =)
all i know about foobar2000 i've learned here, so thx for you all =)
Reply #353
Here is some update again
Reply #356
Nice config, but it's only the image uploaded there
Reply #357
here's my
Reply #358
...fancy pancy
I like things to be simple
Reply #360
upgrading
here my new foobar =)
Reply #361
my first skin with CUI Panel Stack Splitter + elplaylist
Reply #362
@tedgo:
thank you for posting your elplaylist settings, the only thing i needed was how the rating stars were made. i didn't know about the $repeat function
here is my first elplaylist setting made from scratch (my other settings were modified default settings)
Reply #363
@jeremija:
very nice config - especially the EL playlist.
can you share this one?
Reply #364
Here's mine. Really simple and uncluttered with a few wsh_panels (volume and seekbar) and track_info_mod panels (album art and Track info.
Thanks to those who posted config info, it's been quite helpful getting my foo the way I want it.
Reply #365
Here's mine, it's pretty basic but packs a lot of function in a small size:
Reply #366
Extra clean. Now if only I could turn the menu bar and playlist order dropdown into buttons...
Reply #367
actually you can create buttons for the playback order  and put the menu back to the toolbar and add a button for show/hide toolbar
Reply #369
great... thank you very much.
greets
Reply #372
@tedgo:
in your config, how come you don't have gray splitters?
are those normal splitters from CUI, or is it panel stack splitter?
Reply #373
@jeremija
It is Panel Stack Splitter
Actual Screenshots (named my config DarkOne 1.1):
