Topic: [TROLL] Wisdom of switching to AAC (Read 8423 times) previous topic - next topic
I've recently began using AAC when I read the ISO papers and thought they sounded promising, as well as the long run of years I've seen and dismissed several posts as bullshit on random forums about how it was someday supposed to replace MP3.
It had its trial with me last week and proved itself useful after all. It looks to me HQ is now finally possible at 96 kbps. On the other hand, the MDCT technique appears to be still in development, as I've noticed distinct characteristics from resulting compression artifacts at really low bitrates, especially for sharp samples such as bells, chimes etc. that MP3 renders better at the same bitrate--not that I'd actually encode as low as 32 kbps so, meh.
Where AAC really starts to stink when it comes to compatibility. So far, Winamp nor WinXP can recognize the metatags and I haven't come across one .mp4/.m4a virtually anywhere, so I wouldn't expect LimeWire/Ares to recognize MP4 files as audio.
To spare you from further bullshitting, I just got a couple questions:
1. Is there a driver patch to fully integrate AAC encoding into Windows XP or does SP3 already fix this?
2. Why do I not see a command for resampling? LAME allows low bitrates while retaining a bigass resolution.
3. Is keeping stereo an option for bitrates as low as 32? LAME features this. I don't see it on Nero.
And before I switch to AAC and start converting all my shit, is there ANYTHING significant I should know before doing so? Vague question, I know, but it really pisses me off when I start using a format and later regret for being such a tightass for not waiting 2 months for that major upgrade that now discerns noise from the song and replaces it with a pseudorandom seed, thus allowing more leeway for the legitimate audio samples quality-wise on lower bitrates. AAC was built in 1997--there is NO excuse for a said intelligent encoder to not exist in 2008. For all I know there could be a successor as we speak (exact same reason I'll wait for Blu-Rays to be replaced by tapestry media.)
I'm a scene ripper, so it's important that I receive any astute opinion about the wisdom of switching to AAC. I'm prepared to deal with AAC audio being a pain-in-the-ass to multiplex with video, as much as engineering MKV-contained content is a bitch to do with Avisynth.
I have only two suggestions. First, sourcing the encodes from MP3 will smooth out AAC distortions at low bitrates. Second, PsyTel is clearly the best choice among encoders for development stability.
I was very impressed by  HE-AAC. It  performs extremely well for low bit rates, compared to AAC (LC).
But according to this listening test (http://www.rjamorim.com/test/64test/results.html) AAC-HE at 64kbps is still inferior to  LAME Mp3 at 128kbps.
Yes and with HE-AAC I hear ttsshhhkkkk artifact all the time. There could be serious issues on low volume parts, synth music etc . Maybe it sounds cool for 64k but and 96k LLC is a better option. But is 96k vs 128k space saving really attractive when we are forced to use less compatible codecs ? Even worse is that you can get not bad at all quality with Lame -V6 or even -V7 for outdoor use.
For video use HE-AAC and mp3 alternatives are attractive for obvious reasons if we don't look at compatibility. Again 96k is too close to Lame -V7, But at 24~80k there is a clear advantage of AAC over Mp3.
Axon, 'you trying to take the piss by giving me that garbage? The latest PsyTEL build is dated early 2002 and even this site's wiki confirms its uselessness and inferiority to Nero.
Source encodes from MP3? What bitrate for 22 KHz? Nero seems to underestimate the required quality bitrate for a non-44 sample rate.
No codec can provide CD-quality at 64 kbps. 76 minimum.
I don't require 96 for everything, hell, I can tolerate some of 'em on 56 and linear forms of music such as tracks from old consoles as low as 24 depending on the relative complexity. It encodes distinctive audio more intelligently than MP3; MP3 is utterly fucking retarded when it comes to 8-bit tracks. Hell, compressing the WAV with WinRAR gets a way smaller size.
You tell me.
Yeah, I stick to 64-80 casually, 96 for complex/kickass trance tracks and 128 when I wanna be a real autistic dickwipe that bitches about not experiencing hallucinations of a cock-craving Sailor moon without the presence of those inaudible elements in raw waveform :/
If you suffer from a form of Tourettes and genuinely can't help constantly swearing, then I apologise for embarrassing you. If this isn't the case, then can you please stop it. I don't visit this forum to read filth, I come here to learn something.
Cheers, Slipstreem.
It's my opinion that AAC is almost useless today, because it is designed to delive acceptable quality at low bitrates and gives little to no improvement in the transparent range. Some people will disagree. But today when we have 8 MBit surround mixes on audio DVD, ain't it a bit stupid to argue about 80 and 96 kBit for stereo?
I prefer not to discuss releasing scene further on this board due to hostility from the administrators.
Let's assume you preserve content for a relatively small group of people (household), or do unpopuar content that's not subject to copyright. Now you pick 64 kBit/s for stereo because you deem the artifacts acceptable for you. But the person next to you might disagree. Is it morally right to assume that the other person should acquire the source, do all the processing and save to standard 192 kBit/s, when it could be done properly only once in the first place?
HE-AAC and MP3Pro at 64 kBit is a joke. Those 56 kilobits are not enough to store 22k-24k transparently in the first place. Now we expect the added fake HF to do magic? Everything said here applies equally to video.
Try not to state opinion as fact (I sometimes do this as well, I have tried not to though).  Technically speaking, no lossy encoder can ever achieve CD quality.  There are some encoders that can achieve perceived CD quality at 64kbps for some people.  Did you ABX the formats often used at low bitrates (HE-AAC as an example) to determine that or did you just make that statement?
Actually, Apple's tagging standards have slowly become the "standard" for AAC.  Many other applications (including WinAmp) and portable players can read and write Apple compatible AAC tags.  Even crappy P2P programs such as LimeWire have been able to recognize mpeg-4 AAC audio tracks.  The popularity of the iPod and iTunes have pushed AAC onto people rather quickly.  I can now walk into Best Buy and find 14 out of 21 portable players that will work with AAC, 7 out of 12 standard DVD players, three out of three current generation consoles, and 13 out of 22 car CD decks.  All of those numbers are real as I was trying to point out to a friend how popular AAC has come.  It is as compatible as mp3 but I would say that it is about as compatible as WMA or slightly less.  Now there is a difference between raw AAC and AAC files in a mpeg-4 container.  You won't find much compatibility (if any) with raw AAC files but mpeg-4 AAC audio file compatibility has drastically increased over the years.  That and Apple's tagging system has gained compatibility.  I have a Xbox 360, Wii, 30GB Zune, and a 4GB Creative Zen that will all read Apple AAC tags just fine.
If you suffer from a form of Tourettes and genuinely can't help constantly swearing, then I apologise for embarrassing you. If this isn't the case, then can you please stop it. I don't visit this forum to read filth, I come here to learn something. sad.gif
Then GTFO my heterosexual thread.
I didn't ask about 5.1, and IMO surround-sound is fuckin' pointless, especially when most of my audio is natively on stereo, plus surround-sound can be easily simulated with software/hardware tweaks. As for generic stereo, the second channel is 90% identical to the first, and that redundancy should be recognized by modern encoders, AAC is a good start.
All my future releases will be encoded at 128 kbps but I'll probably be using -q 0.35 which lets some content like South Park go as low as 56 kbps. Whether people disagree or not with the perceived quality, I'll only assume they're human. If you're an autistic assgoblin, maybe you should play with your toys instead or find a loli to wank off to.
No, I tested 'em on this picture to see how the bitrate affects the visual trippiness. 32 and 64 so goddamn boring man, just streaks of grey goat shit, 128 was w1n and below 76 is where the phail begins.
No but seriously, what the hell do you think I was doing? I directly reported all over this goddamn thread what my experience was with different bitrates. Just as MP3 128 kbps retains (perceived) CD-quality except isolated songs with high-freq cymbals that are better encoded at 192, I found 76 kbps to be equivalent to LAME 128.
2.XX can't, and neither can Windows, unless I missed something.
'Dunno why I have never seen an MP4 being shared on the net. I'm usually skeptical about new formats and only conform to popularity and mass-compatibility but since AAC is obviously superior to MP3, I'm willing to move on if their tags can be recognized.
Moderation: TOS #9 violation removed.  Combined with the the TOS #2 violations, it seems like someone didn't bother to read the r00lez  before posting.
The sound of low quality video releases (mostly anime) is often done in AAC. It is generally accepted that soundtrack and spoken word is somehow less important. Music at 170-200 kBit does not benefit from AAC. There is one filesharing resource where M4A was explicitly forbidden recently.
Insulting people is not a way to garner positive attention here on HA.  I suggest that you refrain from calling people homosexual as an insult (even if you don't come outright and say it).
Well, I didn't see any ABX results and a image comparison is not the best way to judge audio quality (I hope that was a joke).  That is why I asked.  I come on these boards (and other boards) and see other people make statements about audio quality without doing any blind ABX tests.
Xpenguin17, even though you have been warned by one of our moderators already, let me tell you again that if you don't adjust your tone to a more grown-up level and generally adhere to our rules, you will not stay much longer on this forum.
P.S. After an extremely childish PM, he is now banned.
Thank god. Although I must admit, I do not troll very often, but trolling him was just so much fun.
Are all scene guys that insecure nowadays?
"The Scene" has strict encoding rules, ones which don't allow the decisions he was making.  (Unless something has changed since I last looked at their rules)
Creature of habit.
Winamp 2.95 is 5 years old.  What do you expect?  Modern versions (e.g. anything in the last 4 years) reads iTunes-style MP4/M4A tags just fine.
