Topic: MP3 Organizers (Read 3384 times) previous topic - next topic
MP3 Organizers
I was reading a thread about peoples favourite music organizers. After not knowing how to use foobar correctly i installed a few and they were okay. Im so glad i took a few minutes to learn how to use the built in file organizer, its awesome. Its easier and better than any other program i have seen, just takes a small amount of time to initially setup.
The text patterns are easy to learn and you can get help here in no time. I struggled at first because the file operation features wernt installed by default.
Thanks to PredUK for answering a message with more help than expected! I now have my whole library perfectly organized.
MP3 Organizers
No worries, glad I could help. Like you said, it takes a small while to set up, but there's nearly always someone on these forums to help, it's part of the reason I like foobar. You get so much freedom, and if you don't understand it there's people to help you.
Before I used foobar, I was using Mp3Tag to tag the albums, the manually moving to folders. Since I discovered the rename/move feature of f2k, I haven't used those programs ones.
