Topic: WavPack support in ImgBurn 2.4.1.0 (Read 9621 times) previous topic - next topic
  • DARcode
  • Members (Donating)
WavPack 5.1.0 -b384hx6cmv / qaac 2.63 -V 100
  • GeSomeone
Thank you.
I'll quote the WavPack hi-lights from your change log:
  • Added: Support for burning APE/FLAC/WV files with an embedded CUE sheet as if they were normal image files.
  • Added: Support for 'WavePack' files (*.wv) in the 'Create CD CUE File' window.
  • bryant
  • Developer (Donating)
Yes, DC, thanks for this!
I will have to play around with ImgBurn a little and add it to the list of WavPack supported apps (it looks pretty nice).
David
  • bryant
It looks like some people are having trouble with this over on the Reaper forums. Has anyone else seen this (I haven't had a chance to try it yet):
http://www.cockos.com/forum/showthread.php?t=19859
  • jeffster
FWIW, I got that same error message as in the thread you linked to.
Also had other errors while testing, and in the only Wavpack burn that completed successfully there was a dropout (a few seconds silence) near the beginning of the first track on playback (lucky I'm using cd-rw's for testing).
It made me wonder if the DS filter could be buggy, since similar tests with flac files were okay.
I wasn't a fan of decoding and burning on-the-fly before this, and now will probably just decode to wav first in the future, for peace of mind. Otherwise I like ImgBurn.
  • Last Edit: 06 April, 2008, 04:52:53 AM by jeffster
  • DARcode
Version 2.4.2.0 is out and it includes the following fix:
Fixed: WavPack files were not being decoded during burning, they were being read as if they were PCM/RAW audio files.
  • gl.tter
Author of -Wavpack4Wavelab- and -CheckWavpackFiles-
  • gl.tter
Are there any plans to rip straight to Wavpack + cue?  And does the ImgBurn audio ripping engine compare to EAC in accuracy?
