Does anyone know of a native Linux media player that supports cue sheet playback, either as a standard feature or with the help of a plug-in or extension?
Me too. Still on XP but when everybody goes Vista, I will stick with Ubuntu. (The wife-only-uses windows symdrom). I have read somewhere that Amarok support cuesheets, but then again I am not sure and I don't know any player that does the cuesheet thing. I hate FB2k because it's really got a hold on us - once you discover its power is unlikely you are going to leave. My solution would be keeping FB2k strictly to make file management operations under WINE. But NOT as a player for Linux. It is true that Linux doesn't have a FB2K killer yet, but I really hope this will change soon. So my hint is: do everything file-related stuff like cuesheets, converting and replaygain on FB2k, but use another play to actually play the organized files. For now!Reports of reading cue sheets in amarok:http://amarok.kde.org/forum/index.php/topic,7675.0.html
Some total purists with terabytes of hard drive to burn might prefer WAV+CUE, but in my opinion, image files of some type are the only way to go for an accurate archive. I must be in a minority.
Not accurate enough if:1) Your drive does not do both lead-in and lead-out 2) You ripped a CD without correcting the offsets.3) Last but not least, checked your CD against AccurateRip database.
QuoteSome total purists with terabytes of hard drive to burn might prefer WAV+CUE, but in my opinion, image files of some type are the only way to go for an accurate archive. I must be in a minority. ermm.gifNot accurate enough if:1) Your drive does not do both lead-in and lead-out 2) You ripped a CD without correcting the offsets.3) Last but not least, checked your CD against AccurateRip database.Anyway I am glad you sorted this out
I've tried Foobar2000 in Linux through WINE and it works - sort of. Sadly, Foobar2000 is unstable in that operating environment, prone to freezes and crashes with unacceptable frequency.
I personally cannot think that anyone would want to archive CDs any other way but with FLAC+CUE. Some total purists with terabytes of hard drive to burn might prefer WAV+CUE, but in my opinion, image files of some type are the only way to go for an accurate archive.
Does anyone know of a native Linux media player that supports cue sheet playback, either as a standard feature or with the help of a plug-in or extension?1. Amarok >= 1.2.42. Audacious3. xmms with the mp3cue plugin:http://brianvictor.tripod.com/mp3cue.htmCharles
... "the replaygain is enabled by default and is read only for now" ... "Now in svn revision 967 if you set the Crossfade fade out time to 0 it will play in gapless mode ..."
I just started using deadbeef this weekend and I like it. I’m not sure why I have so many problems with various players dropping audio on my Linux box, but deadbeef is rock steady. It even played the .iso.wv file (with all the track info from the cuesheet) that I downloaded in response to this thread. Very nice!Of course, it’s not really a complete foobar replacement because it doesn’t have all the database stuff or audio conversion capability, but it seems like a very robust, lightweight player.
Reduce disk IO : get rid of atime
