Topic: Help solving streaming problem (not add-in related)... (Read 2606 times) previous topic - next topic
Searched far and wide within this forum and elsewhere for a solution but thus far have come up empty.
Here's the deal:
I have foobar2k (version 0.9.4.2 to be exact) set up at work but cannot play streaming media (shoutcast/pls/m3u streams).
Relevant background:
I route foobar through Proxomitron to change the user agent and supply credentials to the proxy server and can listen to an mp3 file I uploaded to my own web page (hosted by google) so I have established that foobar can, in fact, access the internet and play a non-streaming mp3 file therein.
Within foobar, I have disabled dynamic track titles and have no add-ons added on.
In the registry, I have verified that...
   the MIME content database includes entries for both audio/scpls and audio/x-mpegurl; and
   they are both mapped to .pls and .m3u filetypes respectively; and
   both filetypes are, in turn, associated with foobar.
However, when I click on a pls or m3u link in IE or add it as a location directly into foobar, foobar launches (if from IE link), gives it a mighty try but eventually fails.  The console provides the familiar Unable to open item for playback (Service Unavailable (503)):.
When I click on this triplej link (http://abc.net.au/streaming/triplej/triplej.m3u), here is the complete (but redacted) proxomitron log:
+++GET 3681+++
Using Proxy - bcproxy.myCompanyDomain.com:80
GET [de-obfuscated]http://www.triplej.net.au/img/layout/gnav_btn1_forum.gif HTTP/1.0
Accept: */*
Referer: [de-obfuscated]http://www.triplej.net.au/img/layout/gnav_btn1_forum.gif
Accept-Language: en-us
User-Agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0; .NET CLR 1.1.4322; InfoPath.1)
Host: www.triplej.net.au
Cookie: blah, blah, blah
Connection: keep-alive
Proxy-Authorization: Basic *****
+++RESP 3681+++
HTTP/1.1 200 OK
Date: Fri, 28 Mar 2008 15:13:29 GMT
Server: Apache
Last-Modified: Sun, 10 Feb 2008 02:47:41 GMT
ETag: "99ffe6-2a8-d8db4d40"
Accept-Ranges: bytes
Content-Type: image/gif
Content-length: 680
Proxy-Connection: Keep-Alive
+++CLOSE 3681+++
+++GET 3682+++
GET [de-obfuscated]http://abc.net.au/streaming/triplej/triplej.m3u HTTP/1.0
Accept: */*
Referer: [de-obfuscated]http://abc.net.au/streaming/triplej/triplej.m3u
Host: statse.webtrendslive.com
Cookie: ACOOKIE= blah, blah, blah
Proxy-Authorization: Basic *********
+++GET 3683+++
Accept: blah, blah, blah
Host: abc.net.au
+++RESP 3682+++
HTTP/1.1 200 OK
Date: Fri, 28 Mar 2008 15:49:36 GMT
Server: Microsoft-IIS/6.0
P3P: CP="NOI DSP COR NID ADM DEV PSA OUR IND UNI PUR COM NAV INT STA"
Pragma: no-cache
Expires: -1
Cache-Control: no-cache
Content-type: image/gif
Content-length: 67
Set-Cookie: blah, blah, blah
+++RESP 3683+++
HTTP/1.1 301 Found
Location: http://www.abc.net.au/streaming/triplej/triplej.m3u
Connection: close
Date: Fri, 28 Mar 2008 15:49:37 GMT
+++CLOSE 3682+++
+++CLOSE 3683+++
+++GET 3684+++
GET [de-obfuscated]http://www.abc.net.au/streaming/triplej/triplej.m3u HTTP/1.0
Referer: [de-obfuscated]http://www.abc.net.au/streaming/triplej/triplej.m3u
Host: www.abc.net.au
If-Modified-Since: Tue, 01 Nov 2005 11:03:16 GMT
If-None-Match: "31054e-26-e712c500"
+++RESP 3684+++
HTTP/1.1 304 Not Modified
Content-Type: audio/x-mpegurl
Last-Modified: Tue, 01 Nov 2005 11:03:16 GMT
ETag: "31054e-26-e712c500"
Cache-Control: max-age=299
Expires: Fri, 28 Mar 2008 15:54:37 GMT
Date: Fri, 28 Mar 2008 15:49:38 GMT
+++CLOSE 3684+++
+++GET 3685+++
GET [de-obfuscated]http://www.abc.net.au/streaming/triplej.asx HTTP/1.0
Accept: */*
Referer: [de-obfuscated]http://www.abc.net.au/streaming/triplej.asx
+++RESP 3685+++
HTTP/1.1 200 OK
Pragma: no-cache
Expires: -1
Content-length: 67
+++CLOSE 3685+++
+++GET 3686+++
GET http://202.6.74.107:8060/triplej.mp3 HTTP/1.1
Host: 202.6.74.107
Accept: */*
+++RESP 3686+++
HTTP/1.1 503 Service Unavailable
Pragma: no-cache
Content-Type: text/html; charset=utf-8
Proxy-Connection: close
Connection: close
Content-Length: 810
+++CLOSE 3686+++
If you have read this far, thank you.
If you know how to resolve the problem, I'll mail you a bud lite :-)
I'm out of ideas and hope the collective wisdom here can help out a poor n00b.
Yeah, I could just click on the WMP link instead but... well... nah.
Does it work if you put the proxy details into foobar and add the stream directly (http://202.6.74.107:8060/triplej.mp3) with File -> Add Location...?
