Topic: foo_httpcontrol (Read 704209 times) previous topic - next topic
  • Chipicui
foo_httpcontrol
A question:
How do you filter a folder to enqueue (for example)... only mp3 files?
actually I retrieve the list of foobar supported playable files for that. hmm, weird, looks like the extensions restriction I pass to foobar process_locations_async is not making any effect, and I overlooked that. additional filter of incoming filenames added, version 0.6 re-uploaded...
Damn ...that's fast!
How I'd wish to have 1/4 of your programming skills man!
Thank you very much... everything's working ok now!
  • Last Edit: 31 March, 2008, 03:18:43 PM by Chipicui
foo_httpcontrol
I got the plugin to crash foobar several times by enqueuing a directory (in
the www file broswer)
does it happen during or after enqueuement process? can you try to add the same directory in foobar by File/Add Folder?
perhaps there is a specific file causing the crash, for example, in my system foobar crashes on attempt to enqueue any avi file, getting access violation in an external activex module.
I've uploaded the current version (just in case), please use it if you decide to spend a time on this problem.
Chipcui, thanks, but there's really nothing to wish for, believe me...
  • Last Edit: 31 March, 2008, 03:44:49 PM by oblikoamorale
  • Chipicui
foo_httpcontrol
a minor thing though;
I can reproduce the same crash reported above, while enqueueing directories. Foobar reports it as coming from foo_http...
It's my one and only issue with this wonderful plugin...
  • RainDawg
foo_httpcontrol
Excellent plugin.  I think this will fit nicely into a little idea I had to turn my iPhone into a foobar2000 remote control....something that I could use to change songs from the backyard during a party, or as part of a complex nerdy seduction scheme.
I do have two questions.
1- Is there a security risk with this component?  I see that I can browse through my entire computer.  Clearly with the plugin itself there is little that can be done with those information, but having an index of the entire contents of my discs strikes me as a bit unsettling, especially when that is being exposed to the world.  I realize that with a router this information is behind a firewall, which then restricts my intended use to Wi-Fi and using the "masked" IP address of my PC.
2- How difficult would it be to compress the webpage down to a viewport typically used in mobile webapps?  I only did a cursory look at the code in the html pages; I am wondering if I should head down that road and create a solution for those of us using the iPhone/touch or not.
  • foo_peter
foo_httpcontrol
that's fast!
tested Firefox 2.0.0.13
  • Last Edit: 31 March, 2008, 06:31:08 PM by foo_peter
foo_httpcontrol
Reply #30
if i were you, I wouldn't expose it to zeh whole internets without protecting it by proper means you noted, as it initially never been planned to be made bulletproof and used outside the trusted localnet. of course there might be unexpected vulnerability problems in my code or, for example, in the network library I use.
the only hardcoded thing in template file is the playlist by itself. the rest is up to you, downsize it as you wish.
anyway I guess playlist, even a small one, wouldn't be much of use on mobile phone screen...
2 all - currently I'm clueless about the crash. I enqueued my whole hdd a few times to no crashing luck.
  • steliyan
foo_httpcontrol
I got this error, when connect to http://localhost:8888/:
failed to read file: components/foo_httpcontrol_controls_tpl.html
No errors in the console, I copied all files in /components dir. Same error with Firefox and Internet Explore. Using v0.9.5.1 with default_ui.
  • Chipicui
foo_httpcontrol
My god!!!
(almost crying)... I can't believe it.... It's by far, the best "customer's service"    I've ever had...
Everything's working ok now... and I mean EVERYTHING, even in my Palm!!!.
Now I have the remote control I've been looking for so long!!!!
THANKS THANKS and THANKS AGAIN!!!!
Chipicui
foo_httpcontrol
Reply #33
please check that you have a proper working directory in foobar shortcut properties -- it should be pointing at foobar dir and nowhere else.
Chipicui - I'm glad I've been something remotely close to of use
  • steliyan
foo_httpcontrol
Reply #34
Thanks, that was the problem.
foo_httpcontrol
Reply #35
I guess this one is going to last for a real while now...
v0.62 03 Apr 2008
    add: usability improvements;
    fix: additional safety checks;
  • Chipicui
foo_httpcontrol
Reply #36
Many thanks...
We can change playlists!
Nice work!
  • AndyCar
foo_httpcontrol
Reply #37
v0.62 03 Apr 2008
I must say- Now I'm falling in love with this sexy plug-in
BTW, may be it's good idea to post info about this plugin here
(oblikoamorale, C'mon you must be russian too
foo_httpcontrol
Reply #38
couldn't resist fixing things I ran on by myself, sorry.
v0.63 05 Apr 2008
    add: clickable path in browser;
    add: previously played track is highlighted in playlist;
    fix: list of playlists wasn't always updated;
    fix: additional safety checks and fixes;
  • alphaex32
foo_httpcontrol
Reply #39
It would be awesome if someone made a template for this formatted for the iphone/ipod touch.
  • RainDawg
foo_httpcontrol
Reply #40
There is a very good chance that I will take exactly this project on, though not for the next few months.  I just recently purchased a house, so the majority of my time away from work will be tied up for the time being.  However, I just can get over how cool it would be to be able to change the music from anywhere in the house....just as a cool party gag .
So guaranteed that if someone else doesn't do a better job than I could before I get a chance to do some tweaking of the code, I'll do my best to build something that I think fits nicely on the screen.
  • alphaex32
foo_httpcontrol
Reply #41
Well, if you're planning to make a whole project of it, maybe a native iphone app would be the best way to go.
foo_httpcontrol
Reply #42
v0.64 08 Apr 2008
    add: basic http auth;
    add: preferences page moved to tools section;
    fix: too small seekbar;
    fix: some glitches and optimizations here and there;
  • Chipicui
foo_httpcontrol
Reply #43
Thank you!
It's getting better and better...
  • pIv
foo_httpcontrol
Reply #44
When current song highlighted with gray in playlist - around previous song box is drawing.
My suggestion highlight with color and box drawing only current playing song!
  • carmenm
foo_httpcontrol
Reply #45
Hi, i just tried this component and i like it a lot!!!!.
I found a little thing bugging me, if i am connected from the web:
- i start playing from the web
- playing start on my foobar, and the web interface refresh itself
- i pause from foobar
- foobar pauses itself but the web interface doesnt refresh itself!
The other thing is a feature request:
- possibility to draw the album art
I was thinking we might even be able to retrieve artist infos from last.fm .... (it would the last coolest feature )
Thanks for your great work!
foo_httpcontrol
Reply #46
you can modify the appearance or even get rid of previously played track indicator by editing the css section of foo_httpcontrol_controls_tpl.html.
cannot reproduce it. only if I understood the problem correctly, of course.
anyway, try this template file, I wonder if the situation improves?
regarding last.fm stuff.... well, maybe. some time, in distant future...
  • Last Edit: 09 April, 2008, 11:09:28 AM by oblikoamorale
  • pIv
foo_httpcontrol
Reply #47
Big thanks to you.  It is very good solution!
  • carmenm
foo_httpcontrol
Reply #48
i cant access the file.
To sum up my problem, is there a way for foobar on the "server" machine to force refresh of the webpage on the "client" machine when doing something like play or stop?
foo_httpcontrol
Reply #49
ah, I got it. well, there is no way web page would know about changed foobar state without reconnecting. so it is not a bug, really.
2all: there was a typo in 0.64 template file which led to unclickable playlist. typo is fixed, 0.64 re-uploaded.
