Topic: [Not My Release] ELPlaylist (Read 537620 times) previous topic - next topic
Reply #750
Hi can anyone tell me how to add a progression bar to the currently playing track?
something like this
[a href="http://img37.imageshack.us/i/44749240.jpg/" target="_blank"]
Reply #751
Hi all.
I want to make foobar look like this: http://yuo.be/columns.php (picture of the albumart in a column). I've downloaded it but I can't figure out how to do it (yes I'm a noob). Anyone?
Reply #752
well you don't want to be using ELPlaylist for that.
just follow the instructions on that page on how to install columns UI and select one of the presets on startup. if you missed that dialog, goto file>preferences>display>columns UI>main tab>quick setup.
Reply #753
Wow... this completely changes the view of the player, any ways to do this without this new view? I liked standard more.
Reply #754
you can try EsPlaylist. that will let you have album art in the playlist inside default UI.
http://foo2k.chottu.net/#esp
after installing the component, you'll need to switch back to default UI in the display preferences and then use "enable layout editing mode" found on the "view>layout" menu to replace the standard playlist.
Reply #755
Thanks for the tip, very cool addon  . But as default it shows all the albums, and no tracks. I want to see all the tracks, with an albumart beside, like in the picture. Is this possible in EsPlaylist?
EDIT: When I clicked an album the view got fine, no worries. Thanks for this tip on EsPlaylist.
Reply #756
something like this
can this be done in ng playlist?
Thanks in advance for any help guys
You can do this in el_playlist by creating a background image whose size is determined by the ratio of played/total seconds. You would put this in the "Per Second" tab of the el_playlist settings. I'm not at my desktop right now so I can't give you specific code, but it is definitely possible.
In pseudo-code it is going to be something to the effect of:
if(track is playing,background object width = [(seconds played)/(total seconds)]*total line width,else display nothing)
Reply #757
Hello all,
Having a bit of a problem having my album art show up for every album if it has 3 tracks/songs or less. I was assuming it would be in the Group Header for the ELPlaylist Settings, but not seeing it anywhere.
Here is the code if someone wants to take a look at it and see if I maybe missed it?
$puts(art.size,$mul(%ART.ROW%,%el_row_height%))
$puts(group.text,$ifequal(%el_group_depth%,0,$ifgreater(%el_direct_item_count%,0, %album artist% - ,),)%el_group_format%)
$puts(effect,$ifequal(%ON.SHADOW%,1,glow:0:48-48-48:3 offset:1:2,))
//$font(Segoe UI,9,)
///////Group Info///////
$puts(group.left,$if($or($and($greater(%el_direct_item_count%,0),%el_is_collapsed%),$greater(%ON.ART.IN.GROUP%,0))
                    ,$add($mul(%ART.MARGIN%,2),$get(art.size),2),%ART.MARGIN%))
$puts(group.left,$add($get(group.left),$mul(%el_group_depth%,20)))
$drawstring($get(group.text),
            $get(group.left),0,$sub(%el_width%,$get(group.left)),%el_height%,%GROUP.TEXT.COLOUR%,vcenter nowrap elipchar hq mempos, glow:0:%GROUP.GLOW.COLOUR%:0 offset: 1:1)
///////Group Line///////
$setcoordinate(1,$add(10,$getlastpos®),$div($add($getlastpos(t),$getlastpos(b)),2),$sub(%el_width%,9),$add($div($add($getlastpos(t),$getlastpos(b)),2),1))
$if2($drawthemerect(,,,,listview,7,0),$drawrect(,,,,0-64-128,,))
//$drawrect(,,,,0-64-128,,)
$setcoordinate(0)
///////Album Art///////
//$ifgreater(%el_direct_item_count%,%ART.ROW%,
$if(%el_is_collapsed%
    ,$imageabs(0,0,$get(art.size),$get(art.size),%el_group_first_path%,artreader noexpansion nodisplay,) //dummy call
    $setworldtransform(1)
    $puts(art.size2,$min($get(art.size),$add(%el_height%,-$mul(%ART.MARGIN%,2))))
    $puts(art.top,$div($sub(%el_height%,$get(art.size2)),4))
    ,$puts(art.top,$add($select(%ON.ART.IN.GROUP%,%el_row_height%),%ART.MARGIN%))
    $puts(art.size2,$get(art.size))
    $setworldtransform($add(2,-%ON.ART.IN.GROUP%))
$imageabs(%ART.MARGIN%,$get(art.top),$get(art.size),$get(art.size2),%el_group_first_path%,artreader,,,$get(effect))
Screenshot:
Can post more information if anyone has any idea how to fix this.
Thanks in advance!
Reply #758
^^ a guess: try minimum row number of group ( in the grouping tab). In your case this should be 5
Reply #759
This is what mine is showing:
$el_direct_item_count%//$max($add(%el_item_count%,0),$add(%ART.ROW%,%ADD.ART.ROW%))
Reply #760
hi all, how can i get the name of playlist that is active then show it
Reply #761
Hello all,
I'm not great at scripting with maths functions, so wonder if there's someone who might be able to give me an idea on whether or not I'd be able to achieve the following with ELPlaylist.
I'd like to add together the bitrates of all the items in a group, creating the sum total, then divide the total by the number of items in the group, giving the average bitrate of an album for example. I know that this can be done using custom tags, but I'd like to see if there is a more elegant solution by using foobar2000's maths functions.
Any ideas?
Reply #762
Afaik you can't get added/average values over group, unless the info is available through fields like %el_sum_length%.
Would like this function also.
Reply #763
Hey guys, I recently got this: http://mhe84.deviantart.com/art/Mnlt2-Mod-...ar2000&qo=3
It uses ELPlaylist on the playlist, and I was wondering, how would I go about making it show the song queue instead of the tracklist album that's playing when I click on the Playlist bar?
Reply #764
DELETED
Reply #765
I have a problem. I want to display bigger artwork in popup, but some of the images are properly displayed others are not (showed on pictures). They are poorly rendered. How could I fix it ? I use artreader option.
The good one.
The undesired one.
Reply #766
Use pictures with a better quality or an higher resolution.
Reply #767
They are much bigger then the size of the popup.
Ok, got it to work.
Reply #768
can I change the value of el_row_height?
Thanks for help!
Reply #769
settings>grouping>row height
Reply #770
I've made a very simple ELPlaylist config which I need to save so that I don't have to reconfigure everything when I format.
How do I go about doing this?
Also, I can't seem to get the foobar library to work with ELPlaylist, I want to use the Media Library to load my music so that it updates on the fly. I can only see music in the list when i drag the folder in.
Any ideas?
Cheers
Reply #771
how can you possibly miss the export button that's at the bottom of the settings dialog??
you probably want to look at using autoplaylists if you want playlists to update automatically as you add files to your library. to start, look at library>album list, right click all music and select create autoplaylist
you can of course create more advanced autoplaylists using the filter option or just by selecting certain nodes in album list.
Reply #772
I managed to get the media library working fine, I just wanted to make sure about the exporting... I've worked on this for the past few hours and really didn't want to cock it up by losing it (which I did earlier by mistake).
The only thing I don't get about Columns UI and ELPlaylist is that when I try and add volume etc below my playlist it puts it on the side of my playlist rather than below.
Cheers
Reply #773
to put panels on top of one another, you want to be using a vertical splitter as the "parent" of the playlist/volume control. sounds like you're using a horizontal one....
Reply #774
Hey guys, I am modifying a script and am having issues adding some text.
I'd like to add the album release year, here's a screenie which will explain what I'm after:
At the moment I have:
$puts(group.artist,%album artist%)
$puts(group.date,%date%)
$puts(group_margin_left,$sub(%el_width%,110))
$puts(title_margin_left,$add($add($get(art_margin_left),$get(art_size)),20))
// ARTIST
$font(%font%,12,)
$drawtext($get(group.artist),$get(title_margin_left),1,$get(group_margin_left),$sub(%el_height%,16),%white%,vcenter end_ellipsis)
$drawtext($get(group.artist),$get(title_margin_left),0,$get(group_margin_left),$sub(%el_height%,16),20-20-20,vcenter end_ellipsis)
// YEAR
$font(%font%,12,)
$drawtext($get(group.date),$get(title_margin_left),1,$get(group_margin_left),$add(%el_height%,16),%white%,vcenter end_ellipsis)
$drawtext($get(group.date),$get(title_margin_left),0,$get(group_margin_left),$add(%el_height%,16),119-119-130,vcenter end_ellipsis)
I've tried adding a numeric value in the text after (title_margin_left) but the text either doesn't move or disappears completely.
Any help appreciated, cheers.
