Topic: [Not My Release] ELPlaylist (Read 537729 times) previous topic - next topic
Reply #625
Just make an autoplaylist with everything in your library.
Yeah, but when I double-click on a song/album to play, I want it to be sent to a playlist specified for library contents, not play from the library.  I really, really hate the iTunes-esque way of using a playlist for the library.  I only want my playlist to be populated with the list of songs I want to play.
edit: In the new version you can right click in an empty area and select browse library
Great news!
Reply #626
Is there a way in ELPlaylist to enable/disable showing the micro images of the cover in the playlist by a command that could be assigned to a button? I didn't find, it didn't exists or I didn't search well? I used to have a big coverart on the left of my config and I want the playlist without the images, bu some times I need it to find if some album are without coverart.
Reply #627
You can't assign it to a button (unless it toggles two separate elplaylists), but you can do it with grouping presets:
$if($strstr('No Covers preset name',%el_preset_name%),,
All your image code
Reply #628
@ssenna
Thanks for the new version with support for embedded album art
Now i have a little problem with the artreader options:
I display the artist picture in the popup window. But using the artreader with %el_group_first_path% and artreader_artist displays the artist picture from the first entry in a group only.
Not very convenient for samplers...
Since this happens in ELPlaylist only, is there any possibility to change this behaviour?
Maybe with an additional path like %el_file_path% or simply %path% to enable artreader for the file and not the group?
Reply #630
Bad news for EsPlaylist lovers:
Google translate:
What is important is, HDD crashed and no longer the source of recently.
Perhaps after this, component upgrade can be difficult.
(EsPlaylist is not taking it back up yet, no longer whole.)
http://foo2k.chottu.net/
Google translate:
Library tree is what hurts the most ...
Reply #631
ouch.
but not keeping offsite backups of work you've spent hours/days/weeks/months on is a little bit negligent to say the least.
Reply #632
I'm sorry to hear that . I guess marc2003 has a point though :/
Reply #633
how to configure so that to display CD by CD of a multiple CDs album ?
Currently, tracks displayed in
01
02
10
01
02
03
10
I like to grouped by CD# too.
Reply #634
falstaff posted a tutorial, first post on page 25
Reply #635
"Fortunately, I could salvage the program sources."
Great news!
Reply #636
Google translate
Software that could recover was Recuva
Reply #638
"Playback/Play" (not "Default Play") for "double click" action on item doesn't work correctly:
It just restarts currently playing track
Reply #639
I have some problems displaying album art using the new artreader support. Here are the artreader settings:
D:\Foobar 1.0\foobar2000\Biography\image\album\$replace(%album artist%' - '%album%,/,_,:,_,\,_,.,_,#,_).*
front.*
cover.*
folder.*
Elplaylist settings:
// Cover
     $enabledraw(1)
     $setworldtransform(2)
     $drawrect($sub(%COVER.PADDING.LEFT%,1),$sub(%COVER.PADDING.TOP%,1),$add(%COVER.SIZE%,2),$add(%COVER.SIZE%,2),,180-180-180)
     $imageabs(%COVER.PADDING.LEFT%,%COVER.PADDING.TOP%,%COVER.SIZE%,%COVER.SIZE%,%el_group_first_path%,artreader))
    $setworldtransform (0)
Most of my album art is located in the first folder (it's the cache folder for biography view), but it doesn't always show with the built-in artreader in elplaylist (sometimes it does). It did always show before, when I didn't use the artreader feature. Is this a problem in my artreader settings, elplaylist settings or in either component?
Reply #640
Today i tried some stuff with subgroups for multiple disk albums and i have to say, i don't find it very usable.
If you don't have your albumcover in groupheader only, it gets very complicated, especially if you have albumart drawn in groupheader and tracklist (like i have).
It also does not function very well with atuocollapse. Subgroup headers are always visible, even if parent group is collapsed. Defining 0 rows for collapsed subgroups makes it impossible zu access discs other than the first.
any advice?
maybe something i didn't think of?
i think what would be necessary is an own $setworldtransform mode for subgroups. Or maybe one could just use tracklist lines for subgroups...
Also autocollapse needs special settings for el_group_depth>0
What do you folks think?
or ssenna?
Reply #641
Eh, sorry to ask such a silly question, I hope this hasn't been answered many times. I did try to find an answer from some pages!
How do I install this? I have Columns UI, I think I read that I need it or what?
EDIT: Found it, but now I can't launch the properties/configuration/what's-it-called. Oh well.
Reply #642
hello to all
i'm not new to foobar, but new to version 1.0.
i was sticked with v0.9.4.5... yup!since 2007... with panelUI
3 simple questions for ELPlaylist:
1-
Is there a way to "connect" group by (context menu) and a preset?
Can ELPlaylist selects automatically a defined preset according to a "group by"?
If not, what is the use of different presets?
Ex: i want to use a preset when i group by album, showing album art, and use another preset when sorting by artist, using artist art. And having different display for group header and infos.
2-
AFAIK, we can't change global fields definitions with buttons,
like set:pvar:value:1 in panelUI
so is there another way to manage them, or do we have to go to settings/fields definition tab, to manually change them?
Ex: i have a global field that return if i want to display albumart or not.
3-
what do return this
$puts(text,$ifequal(%el_group_format%,%album% %discnumber%,%album% %discnumber%,%album%)
$drawtext($get(text),.....)
in fact i want to display the discnumber if i use discnumber in group mode, but dont want to display it in other group format.
for the moment i cant figure how it works. I suppose that %el_group_format% is compared to the result of %album% %discnumber% and not the string itself.
Sorry for my last question; it seams not very "understandably"...
cheers to all.
Reply #643
Does anybody else experienced the problem that the popup field doesn't show up on a secondary display? If I have foobar on my secondary monitor the popup stays on the edge of the first. Only the y-position changes according to the selection/hover.
Nice component, great possibilities, thanks for developing it.
sometimes it is the best, not to say anything
Reply #644
sorry for this huge post, but i just give myself some answers or complement of ask to better point the help i asked
(i could not edit my previous post, like in time. did i missed something?)ok "edit" is limited in time...
hello to all
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]
1-
Ex: i want to use a preset when i group by album, showing album art, and use another preset when sorting by artist, using artist art. And having different display for group header and infos.[/size]
i've made my artwork depends on my "group by"
it shows artists image when grouped by "artist" otherwise, it shows front image.
// * ALBUM ART *
$enabledraw(1)
$ifgreater(%el_direct_item_count%,$sub(%ART.ROW%,1),
$setworldtransform($add(2,-%ON.ART.IN.GROUP%))
$if($strcmp(%el_group_format%,%album artist%),
$imageabs($get(art.left),$get(art.top),$get(art.size),$get(art.size),$findfile($get(artist.artpath),$get(noartist.artpath)),nokeepaspect,,,$get(effect))
$imageabs($get(art.left),$get(art.top),$get(art.size),$get(art.size),$findfile($get(front.artpath),$get(folder.artpath),$get(noalbum.artpath)),nokeepaspect,,,$get(effect))
but i still can figure what is the use of presets. could anyone show me an exemple of using different presets?
[!--sizeo:2--][span style=\"font-size:10pt;line-height:100%\"][!--/sizeo--]2-
Ex: i have a global field that return if i want to display albumart or not.[/size]
anyone has attempt to change a Global Field definition with a button kind action?
3-
what do return this
ok, i found what does not work:
i can use this:
$if($strcmp(%el_group_format%,%album artist%),,
$drawtext($get(album.txt),....)
to display only album artist if i group and sort by artist
but this doesn"t work, due to the '|'
$puts(album.txt,
    $ifequal(%el_group_format%,%album% | %discnumber%,
    %album%   $if(%discnumber%,'(Disc '%discnumber%')',),
    %album%)
any idea to show 'disc 1/2' and 'disc 2/2' when grouping by %album% | %discnumber%
but not show this information when grouping only by %album% ?
bye bye
Reply #645
on the grouping tab, you have a "group by" name. you can access this in the script pages with %el_preset_name%
$if($strcmp(%el_preset_name%,Preset1),....
Reply #646
I started using foobar, but I dont like how it displays playlist. Can it display palylist like winamp? I mean item index, playing mark, artist, track name, duration. If there is no info in tag, I need that foobar instead artist and track name change it to filename. Is it possible?
Reply #647
ELplaylist is made for you, sure it can do all of that ... some skills to titleformatting required and functions brought with ELP to grab from the txt help file
Reply #648
@ figo,
in the standard default UI playlist right click the column headers to turn off the columns you don't want. also, on the columns list, you'll see an option called "more" click on this and you can set up your own custom column showing just the information you want. see "title formatting help" on the help menu for more details.
you really don't want to be using this component do it.
Reply #649
I know that I can turn off columns. As you said I need create script which displays playlist item. I'm very lazy to read and understand syntax. I hope there is users of such script
