Topic: [Not My Release] ELPlaylist (Read 537734 times) previous topic - next topic
Reply #500
Why cant you Middle-Click scroll with ELPlaylist?
Have lots of music on some playlists and thats the fastest way to scroll..
Reply #502
Well i would like to click the mousewheel and scroll up and down, Like you can on IE or Firefox...
Reply #504
How would i change that?
Reply #505
hey, I got fiew questions
1.
I am planning on associating titleformat script for different "group by.."
I would like to have a button to use the elplaylist "groupe by" couldn t find anything like "command:context menu/..... /group by" to place it in a Pss
2.
Couldn t find any function to set or reset global into Elplaylist. Using field definition to set my colors so I would like to be able to create a button to change colors so change the globals. Is this possible? couldn t find any function button in elplaylist so I guess it should be in a Pss but then I dont thing globals are link between both components.
If it isn t possible to do it throught global any kind of solution would be welcome
thanks for any tips
my project on elplaylist  not sure wich color I would end with )
Reply #506
@malouito
It looks like you are using a modified DarkOne script.
I made a mistake in its field definitions...
Please do the following:
It worked ! I just had to change another setting I hae changed by myself. Thanks
Reply #507
v0.6.5.6b(2009/09/05) released
Hi Ssenna,
the new Refresh All context command is perfect thanx a lot, but could you make it available too for Panel STack Splitter in $imagebuttons ot $textbutton for CONTEXT:'Refresh All' ???
would be very usefull,  thanx by advance and keep the good work
Why not applying ths 'Refresh All' after any track change ???
would be better i think and more logical.
what about Ssenna ?
Reply #508
Hey developer,
Would it be possible to add %el_isplaying% support for popup?
Reply #509
forget that
what about Ssenna ?
but do not forget the command 'Refresh All' for Buttons in PSS please
Reply #510
I tried EL Playlist again today after a few months, and I'm surprised it's now real fast and light-weight, and it shows embedded album art without having to change options. Even better, album art displaying has a very good performance as well. The developer has done a very good job.
Album art could be displayed a little sharper, though. If you directly compare it with Columns UI Playlist album arts of the same size, CUI has a sharper image.
Reply #511
is there an option like $eval() in graphical browser?
if not, could it be inplemented?
i think it's quite easier to draw rectangles and images with a simple $eval() function, rather than using multiple $add() and $mul() functions...
Reply #512
Is there any way to use the playlist with a keyboard?  I can scroll up and down the playlist, but pressing 'enter' doesn't play the selected item, which seems odd.  I also can't map any keys to to the Play context menu action (well I can, but it doesn't work).  Surely there must be a way?
Edit:
OK, it seems I was falsely blaming the EL Playlist - sorry!  It turns out it's because I'm using the 'Tabbed Panel Stack Mod' component to house the playlist, and that's causing it to not respond to the 'enter' key.  Damn - I was using that so I can hide the tabs (using keyboard shortcuts to switch tabs).  Back to square one...
Reply #513
Hey there, first thanks to the dev for this awesome component !
I'm trying to set the double click behavior to add the selected song to a default playlist. Using foo_utils I now have a context menu item that is "add to Playlist:" where I can select any playlist I want and I can also bind a keyboard shortcut with a specified playlist.
The problem is in the ELPlaylist settings under behavior I only have "Edit Other/Add to Specified Playlist" which seems to do nothing and I can't specify what playlist I want...
Anyone could help me please ?
Reply #514
hi! does anybody know why images in track list are cuted to a number of tracks height in group, even there are added empty tracks?
looks like:
$setworldtransform(2)
$imageabs(5,5,100,100,$get(art_path),nokeepaspect,)
and minimum row number of group is set to 8,
groups looks like there are 8 tracks, but picture is still cutted to height of real tracks..
Reply #515
SO stupid! Ive forgot about $enabledraw(1)
Reply #516
Is there something like %foobar2000_profile_path% for ELPlaylist?
Reply #517
it´s not needed (I asked the same thing here
just start the path with the first folder (e.g. images\whateveryouwant ) like it was in track info panel afair...
Reply #518
No, not the foobar2000 root path but the profile path.
Its only the same on portable foobar2000 installations.
Reply #519
i've done the same request to Ssenna recently, he said he was too busy for now, but, maybe he will check out this request in october (middle of the month), i keep hope
Reply #520
Would be great
You know i use your file creation script for current_date but don't want to save it to the foobar2000 path (could "conflict" with UAC) but in the profile folder.
But i've no clue how to tell ELPlaylist automatically the profile path on different systems...
Reply #521
Would be great
We are at the same state ...
Reply #522
@tedgo
Just change the permissions (full control -> everyone) of the "images" or whatever folder you are dealing with.
<insert signature here>
Reply #523
@xbullethammer
I know, it is easy for me.
But i want to share my config with others and would've to tell everybody to give full control to a specific folder in my user guide.
Since many users won't read the user guide, i guess there might be every tenth request: "oh my god, i got a script error..." (when i want to create the file in the foobar path or one of its subfolders).
That for i want to create it in the profile path
And of course need a way to make ELPLaylist to recognise the profile path for finding this created file
Its easy for portable installations (a variable on field definition tab with the value ./) but not for standard installations.
My dream would be that ELPlaylist could trace the console. So i could give the current date with wsh panel mod to the console and ELPlaylist could grab it
Or even better: ELPlaylist (or any other plugin, maybe foo_playcount) offers a current date by itself on startup.
Reply #524
heya, bumping this in hope of finding a way to fix my problem
Would there be another way to add that "add to xx playlist" in the context menu ? I'm starting to consider doing my own extension or modifying the foo_utils extension do have that, but I haven't done anything like that before, would it be feasible ?
Thanks again for your help !
