Topic: [Not My Release] ELPlaylist (Read 402685 times) previous topic - next topic
  • ZyroBlue
I am not so much into foobar coding..
$puts(img_path,%directoryname%,cover.jpg)//Set Album Image File Path
What will I have to put there in order to correctly recognize my AA named cover.jpg, residing in the same folder than the file?
  • Last Edit: 26 March, 2008, 01:44:46 PM by ZyroBlue
  • Keikonium
Change %directoryname% to %path%?
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
  • TomBarlow
Thanks Buktore.
btw, is anyone else noticing the groups occasionally collapse themselves randomly? It's happened to me a couple of times, no idea what's causing it.
Also, should it be possible to put panels in this playlist? I tried adding a seek bar using Power Panels, and it's not come up with [unknown function] or anything, but it's not working...
  • ZyroBlue
Thanks Buktore.
Accidentally double-clicked on a group? If you haven't changed the setting, this collapses it.
Not quite..This outputs full path, with the filename of the currently played item.
  • Last Edit: 26 March, 2008, 03:38:13 PM by ZyroBlue
  • buktore
$replace(%path%,%filename_ext%,cover.jpg)
So it become..
$puts(img_path,$replace(%path%,%filename_ext%,cover.jpg))
@Keikonium : I think you should delete "VERY easy to set up" Even though the default setting is quite nice, It's still need to edit the code a bit to make it work. And if one want to customize it, I don't see it to be more easy than SCPL which.. for someone with no experienced, it's a real pain.
EDIT: Ah... that "flicker" I mentioned earlier is because I draw EL panel on another track display. Now I just draw it in the main layout and that flicker is gone.
And, I just find a workaround for Vol. control multimedia key weirdness. I just set both of them to do something else.. like "Volume up" or something. (I use "Activate")
  • Last Edit: 26 March, 2008, 05:10:09 PM by buktore
  • TomBarlow
Nope, I just checked and it closes whenever I reach the end of a track and the next one starts playing. It only seems to happen when "hide all items when playlist is changed" is selected... in fact I've just found that when it is unchecked, and I right click and select "hide all", that when the end of a track is reached and the next one starts all of my groups OPEN! How infuriating! Anyone else getting this?
  • Falstaff
v0.2.5.1a still buggy
metahandle leaks message is no more systmetic on exiting, but i occured two different crashes wich on with another meta_handle leaks message...
i hope that it will be corrected soon, very good plugin.
  • Squeller
Reply #32
I must admit I agree with the criticism in TAGZ abuse. Coler codes with 4 numbers, additional commands and variables - It's pretty much following the concept of panels ui. b e eeep eeek  t ^    ^^^carrier lost. quitting.
  • Last Edit: 27 March, 2008, 04:44:00 PM by Squeller
  • Falstaff
new release : v0.2.6a     2008/03/27
# I can't reproduce the bug (with PanelsUI only?) reported by Falstaff.
# I'd like to get more information.(foobar2000's version, PanelsUI version, OS・・・, failure.txt)
i'm please to read that the developper read our topic about his promosing component
i'll post failure.txt in a next post, i hope this will help you to fix it.
i run foobar 0.9.4.5 under vista, panelsUI 0.14.9 (get it here : http://brett.free.fr/foobar/foo_ui_panels_0.14.9.zip )
bye
PS: Why the panel flash to white when changing track (double-click on a track or clicking next or previous button) ??
  • Last Edit: 28 March, 2008, 06:38:22 AM by Falstaff
  • Falstaff
Reply #34
i haven't reproduce the crash yet with new release 0.2.6a (it's maybe a good news)
here is my ELPlaylist in action :
[a href=\"http://xs.to/xs.php?h=xs225&d=08135&f=crash_elplaylist01306.jpg\" target=\"_blank\"]
it happens while clicking on the album list left panel to select the tracks rated 4 (see precedent screenshot of my config)
here is the dump :
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 020DC2FDh
Access violation, operation: read, address: 099A5CE8h
Call path:
entry=>app_mainloop=>on_items_removed
Code bytes (020DC2FDh):
020DC2BDh:  45 14 A8 03 0F 84 1B 01 00 00 A8 02 0F 84 89 00
020DC2CDh:  00 00 8B 77 40 E8 F9 1E FF FF 8B 45 14 8B B7 68
020DC2DDh:  01 00 00 8B 97 18 01 00 00 8B 52 08 D1 E8 24 01
020DC2EDh:  88 44 24 10 8B 45 0C 8D 8F 18 01 00 00 8D 04 40
020DC2FDh:  8B 44 C6 10 6A 01 50 FF D2 8B 44 24 10 8B B7 68
020DC30Dh:  01 00 00 8B 97 2C 01 00 00 8B 52 08 50 8B 45 0C
020DC31Dh:  8D 8F 2C 01 00 00 8D 04 40 8B 44 C6 10 50 FF D2
020DC32Dh:  80 BF 40 01 00 00 00 75 1B 8B 47 08 8B 50 54 6A
Stack (0012EAC4h):
0012EAA4h:  00000000 00000000 00000000 00000000
0012EAB4h:  00000000 00000000 00000000 00000000
0012EAC4h:  022F2298 0012ED7C 0012EB94 020DE943
0012EAD4h:  0012ED00 0012EAEC 97ADC2D3 000B07D4
0012EAE4h:  022F2298 0012ED7C 0012ED7C 753FE40B
0012EAF4h:  000B07D4 022F2298 0012EE74 0012EE74
0012EB04h:  0012EB18 77D55883 003C923C 00000000
0012EB14h:  00000000 0012EB2C 00000000 0012EB50
0012EB24h:  00000000 003C9220 0012EB40 0012EB40
0012EB34h:  00000000 0022B0F8 000B07D4 00D98DC0
0012EB44h:  0012EB60 7658F620 00D98DC0 FFFFFFEB
0012EB54h:  00000000 000B07D4 0000004E 0012EB9C
0012EB64h:  7658F6AA 00D98DC0 FFFFFFEB 7658F6B6
0012EB74h:  97AABB75 000B07D4 97ADC2DF 0012ED7C
0012EB84h:  0012EC60 020E71D9 FFFFFFFF 765D51BA
0012EB94h:  0000004E 020D0E69 000B07D4 0000004E
0012EBA4h:  00000064 0012ED7C 0012EC48 0000004E
0012EBB4h:  0012EBF8 00000000 0012ED74 00000001
0012EBC4h:  00000000 00000000 00000000 7658F8D2
0012EBD4h:  000B07D4 0000004E 00000064 0012ED7C
Registers:
EAX: 00012B97, EBX: 0012ED7C, ECX: 022F23B0, EDX: 020C1290
ESI: 09910020, EDI: 022F2298, EBP: 0012ED7C, ESP: 0012EAC4
Crash location: "foo_uie_elplaylist", loaded at 020C0000h - 020FD000h
Symbol: "foobar2000_get_interface" (+0000E5BDh)
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 77CF0000h - 77E17000h
kernel32                        loaded at 766E0000h - 767BB000h
COMCTL32                        loaded at 752F0000h - 7548E000h
msvcrt                          loaded at 76AD0000h - 76B7A000h
ADVAPI32                        loaded at 76B80000h - 76C46000h
RPCRT4                          loaded at 76C80000h - 76D43000h
GDI32                            loaded at 76D50000h - 76D9B000h
USER32                          loaded at 76570000h - 7660D000h
SHLWAPI                          loaded at 77EF0000h - 77F48000h
SHELL32                          loaded at 76EE0000h - 779EF000h
ole32                            loaded at 77AC0000h - 77C04000h
shared                          loaded at 10000000h - 10029000h
COMDLG32                        loaded at 767C0000h - 76833000h
IMM32                            loaded at 769D0000h - 769EE000h
MSCTF                            loaded at 779F0000h - 77AB8000h
LPK                              loaded at 76ED0000h - 76ED9000h
USP10                            loaded at 769F0000h - 76A6D000h
uxtheme                          loaded at 754C0000h - 754FF000h
DesktopControlPanel              loaded at 01910000h - 01925000h
foo_bubble_coverflow            loaded at 01AC0000h - 01B46000h
OPENGL32                        loaded at 6D1C0000h - 6D28B000h
GLU32                            loaded at 73290000h - 732B3000h
DDRAW                            loaded at 736C0000h - 737A5000h
DCIMAN32                        loaded at 73A20000h - 73A26000h
SETUPAPI                        loaded at 76840000h - 769CA000h
OLEAUT32                        loaded at 77C60000h - 77CED000h
dwmapi                          loaded at 73A00000h - 73A0C000h
gdiplus                          loaded at 749A0000h - 74B4B000h
foo_chronflow                    loaded at 01930000h - 01992000h
WINMM                            loaded at 74C70000h - 74CA2000h
OLEACC                          loaded at 74C30000h - 74C69000h
foo_cwb_hooks                    loaded at 01C20000h - 01C4E000h
foo_func                        loaded at 01D70000h - 01DC2000h
foo_infobox                      loaded at 01C60000h - 01C9E000h
foo_menu_addons                  loaded at 01DD0000h - 01E2D000h
libmmd                          loaded at 02370000h - 02621000h
MSVCR80                          loaded at 6D860000h - 6D8FB000h
foo_navigator                    loaded at 01D20000h - 01D51000h
foo_playcount_mod                loaded at 01CF0000h - 01D05000h
foo_playlist_manager            loaded at 01F70000h - 01FB4000h
foo_run                          loaded at 01FE0000h - 0200B000h
foo_uie_albumart                loaded at 02010000h - 0204D000h
foo_uie_albumlist                loaded at 02070000h - 020B3000h
foo_uie_elplaylist              loaded at 020C0000h - 020FD000h
foo_uie_graphical_browser        loaded at 6D700000h - 6D791000h
MSIMG32                          loaded at 757C0000h - 757C5000h
foo_uie_lyrics                  loaded at 02730000h - 02791000h
WININET                          loaded at 76610000h - 766DF000h
Normaliz                        loaded at 77E50000h - 77E53000h
iertutil                        loaded at 76A80000h - 76AC5000h
foo_uie_lyrics_art              loaded at 027A0000h - 0284A000h
mscms                            loaded at 73890000h - 738F2000h
WINSPOOL                        loaded at 737B0000h - 737F2000h
USERENV                          loaded at 76420000h - 7643E000h
Secur32                          loaded at 76400000h - 76414000h
icm32                            loaded at 6F500000h - 6F538000h
foo_uie_peakmeter                loaded at 02250000h - 02283000h
foo_uie_playlists_dropdown      loaded at 022B0000h - 022E9000h
foo_uie_powerpanels              loaded at 02310000h - 02333000h
foo_uie_quicksearch              loaded at 02B50000h - 02B96000h
foo_uie_vis_channel_spectrum    loaded at 02980000h - 029A8000h
foo_ui_columns                  loaded at 03570000h - 03636000h
foo_ui_panels                    loaded at 03640000h - 03706000h
foo_abx                          loaded at 02A00000h - 02A33000h
foo_albumlist                    loaded at 02C50000h - 02C97000h
foo_cdda                        loaded at 02CB0000h - 02CE5000h
foo_converter                    loaded at 02D80000h - 02DE9000h
foo_dsp_std                      loaded at 02E40000h - 02E81000h
foo_freedb2                      loaded at 02E90000h - 02ED0000h
foo_input_std                    loaded at 03DE0000h - 03EF8000h
foo_masstag                      loaded at 034E0000h - 03530000h
foo_rgscan                      loaded at 03870000h - 038B8000h
foo_ui_std                      loaded at 03A00000h - 03A56000h
foo_unpack                      loaded at 03530000h - 0355E000h
DSOUND                          loaded at 6F570000h - 6F5E0000h
POWRPROF                        loaded at 758A0000h - 758BA000h
CLBCatQ                          loaded at 77E60000h - 77EE4000h
MMDevApi                        loaded at 755D0000h - 755F7000h
WINTRUST                        loaded at 756F0000h - 7571D000h
CRYPT32                          loaded at 75EA0000h - 75F91000h
MSASN1                          loaded at 76000000h - 76012000h
imagehlp                        loaded at 76C50000h - 76C79000h
AUDIOSES                        loaded at 748A0000h - 748C1000h
audioeng                        loaded at 74750000h - 747B6000h
PSAPI                            loaded at 76560000h - 76567000h
AVRT                            loaded at 757B0000h - 757B7000h
dbghelp                          loaded at 71DC0000h - 71E9C000h
Stack dump analysis:
Address: 020DE943h, location: "foo_uie_elplaylist", loaded at 020C0000h - 020FD000h
Symbol: "foobar2000_get_interface" (+00010C03h)
Address: 753FE40Bh, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "UninitializeFlatSB" (+00004503h)
Address: 77D55883h, location: "ntdll", loaded at 77CF0000h - 77E17000h
Symbol: "RtlFreeHeap" (+0000007Ah)
Address: 7658F620h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "CreateCaret" (+000052D6h)
Address: 7658F6AAh, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7658F6B6h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "GetWindowLongW" (+00000037h)
Address: 020E71D9h, location: "foo_uie_elplaylist", loaded at 020C0000h - 020FD000h
Symbol: "foobar2000_get_interface" (+00019499h)
Address: 765D51BAh, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "DrawFrame" (+00000AB3h)
Address: 020D0E69h, location: "foo_uie_elplaylist", loaded at 020C0000h - 020FD000h
Symbol: "foobar2000_get_interface" (+00003129h)
Address: 7658F8D2h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "GetMessageW" (+00000093h)
Address: 7658F794h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "GetWindowLongW" (+00000115h)
Address: 020D0CF0h, location: "foo_uie_elplaylist", loaded at 020C0000h - 020FD000h
Symbol: "foobar2000_get_interface" (+00002FB0h)
Address: 7658F73Dh, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "GetWindowLongW" (+000000BEh)
Address: 76590A05h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "GetWindowThreadProcessId" (+0000016Dh)
Address: 76590AFAh, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "SendMessageW" (+00000049h)
Address: 75326B28h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "Ordinal393" (+00000323h)
Address: 752FE107h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "RemoveWindowSubclass" (+000004A9h)
Address: 752FE194h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "RemoveWindowSubclass" (+00000536h)
Address: 752FE533h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "RemoveWindowSubclass" (+000008D5h)
Address: 752FE67Ah, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "RemoveWindowSubclass" (+00000A1Ch)
Address: 7658A388h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "CreateCaret" (+0000003Eh)
Address: 77D499CEh, location: "ntdll", loaded at 77CF0000h - 77E17000h
Symbol: "KiUserCallbackDispatcher" (+0000002Eh)
Address: 77D49980h, location: "ntdll", loaded at 77CF0000h - 77E17000h
Symbol: "KiUserApcDispatcher" (+00000048h)
Address: 752FE7A1h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "RemoveWindowSubclass" (+00000B43h)
Address: 76585525h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "PeekMessageA" (+0000012Bh)
Address: 752FDF6Bh, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "RemoveWindowSubclass" (+0000030Dh)
Address: 7533239Ah, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "Ordinal414" (+0000035Bh)
Address: 03688920h, location: "foo_ui_panels", loaded at 03640000h - 03706000h
Symbol: "foobar2000_get_interface" (+00004C00h)
Address: 75332322h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "Ordinal414" (+000002E3h)
Address: 753322D7h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "Ordinal414" (+00000298h)
Address: 77D48584h, location: "ntdll", loaded at 77CF0000h - 77E17000h
Symbol: "NtFreeVirtualMemory" (+0000000Ch)
Address: 77D55B87h, location: "ntdll", loaded at 77CF0000h - 77E17000h
Symbol: "RtlAllocateHeap" (+000002E1h)
Address: 753FE0FBh, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "UninitializeFlatSB" (+000041F3h)
Address: 753FE0CFh, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "UninitializeFlatSB" (+000041C7h)
Address: 753FE0D3h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "UninitializeFlatSB" (+000041CBh)
Address: 753FE0B7h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "UninitializeFlatSB" (+000041AFh)
Address: 77D55955h, location: "ntdll", loaded at 77CF0000h - 77E17000h
Symbol: "RtlAllocateHeap" (+000000AFh)
Address: 77CF9834h, location: "ntdll", loaded at 77CF0000h - 77E17000h
Symbol: "RtlUpdateTimer" (+00000605h)
Address: 77D558A6h, location: "ntdll", loaded at 77CF0000h - 77E17000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7531F0ECh, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "DPA_DeleteAllPtrs" (+00001D71h)
Address: 7531F0B4h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "DPA_DeleteAllPtrs" (+00001D39h)
Address: 020DCFE8h, location: "foo_uie_elplaylist", loaded at 020C0000h - 020FD000h
Symbol: "foobar2000_get_interface" (+0000F2A8h)
Address: 10002F80h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::~uCallStackTracker" (+00000000h)
Address: 020EBD70h, location: "foo_uie_elplaylist", loaded at 020C0000h - 020FD000h
Symbol: "foobar2000_get_interface" (+0001E030h)
Address: 004DF5ACh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0364C27Dh, location: "foo_ui_panels", loaded at 03640000h - 03706000h
Address: 020EBD68h, location: "foo_uie_elplaylist", loaded at 020C0000h - 020FD000h
Symbol: "foobar2000_get_interface" (+0001E028h)
Address: 0364A70Eh, location: "foo_ui_panels", loaded at 03640000h - 03706000h
Address: 004A7243h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 03648C4Fh, location: "foo_ui_panels", loaded at 03640000h - 03706000h
Address: 03667211h, location: "foo_ui_panels", loaded at 03640000h - 03706000h
Address: 004C2F10h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002F40h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000000h)
Address: 020EBD90h, location: "foo_uie_elplaylist", loaded at 020C0000h - 020FD000h
Symbol: "foobar2000_get_interface" (+0001E050h)
Address: 036D803Ch, location: "foo_ui_panels", loaded at 03640000h - 03706000h
Symbol: "Scintilla_DirectFunction" (+00042A03h)
Address: 0040A7A0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040A7B5h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002F27h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 020E708Dh, location: "foo_uie_elplaylist", loaded at 020C0000h - 020FD000h
Symbol: "foobar2000_get_interface" (+0001934Dh)
Address: 020C8219h, location: "foo_uie_elplaylist", loaded at 020C0000h - 020FD000h
Address: 0044A7ACh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E14B4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E3600h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A7982h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00451EE2h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BDD00h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E14B5h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AAD92h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00452D58h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0207E639h, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Symbol: "foobar2000_get_interface" (+0000BC89h)
Address: 020A1360h, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Symbol: "foobar2000_get_interface" (+0002E9B0h)
Address: 02086A27h, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Symbol: "foobar2000_get_interface" (+00014077h)
Address: 020A0C24h, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Symbol: "foobar2000_get_interface" (+0002E274h)
Address: 0209E674h, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Symbol: "foobar2000_get_interface" (+0002BCC4h)
Address: 004DF188h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0209B460h, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Symbol: "foobar2000_get_interface" (+00028AB0h)
Address: 02089B88h, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Symbol: "foobar2000_get_interface" (+000171D8h)
Address: 76590528h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 0209B922h, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Symbol: "foobar2000_get_interface" (+00028F72h)
Address: 020713E7h, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Address: 02071270h, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Address: 765D9B20h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "DrawFrame" (+00005419h)
Address: 75325502h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "DPA_DestroyCallback" (+00000F12h)
Address: 7532551Bh, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "DPA_DestroyCallback" (+00000F2Bh)
Address: 753237CCh, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "ImageList_GetBkColor" (+00000759h)
Address: 7531190Ah, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "DPA_DeletePtr" (+0000006Ch)
Address: 7658A11Fh, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "RedrawWindow" (+0000000Ch)
Address: 75323110h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "ImageList_GetBkColor" (+0000009Dh)
Address: 753234FDh, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "ImageList_GetBkColor" (+0000048Ah)
Address: 753D76C1h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "Ordinal389" (+000025DCh)
Address: 75321765h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "DPA_DeleteAllPtrs" (+000043EAh)
Address: 7532131Ch, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "DPA_DeleteAllPtrs" (+00003FA1h)
Address: 7531F13Eh, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "DPA_DeleteAllPtrs" (+00001DC3h)
Address: 765906F6h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "CallWindowProcW" (+00000075h)
Address: 7659069Ch, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "CallWindowProcW" (+0000001Bh)
Address: 0208756Eh, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Symbol: "foobar2000_get_interface" (+00014BBEh)
Address: 0209B6B4h, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Symbol: "foobar2000_get_interface" (+00028D04h)
Address: 02087D26h, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Symbol: "foobar2000_get_interface" (+00015376h)
Address: 02087D02h, location: "foo_uie_albumlist", loaded at 02070000h - 020B3000h
Symbol: "foobar2000_get_interface" (+00015352h)
Address: 76590008h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "PeekMessageW" (+00000269h)
Address: 76590060h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 7657AF07h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "GetWindowTextLengthW" (+00000142h)
Address: 0042FF50h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.5
UNICODE
Windows 6.0
Additional info:
Masstagger 1.6  (foo_masstag)
FLAC Decoder 1.1.0  (foo_input_std)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
RAR reader 1.1  (foo_unpack)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
Channel Spectrum panel 0.06b2  (foo_uie_vis_channel_spectrum)
Graphical Browser rev014  (foo_uie_graphical_browser)
Menu Addons 0.4 (Intel SSE)  (foo_menu_addons)
Album List 3.2.0  (foo_albumlist)
Converter 1.0.1  (foo_converter)
foobar2000 core 0.9.4.5  (Core)
Seek Panel 0.1  (foo_uie_powerpanels)
Run services 0.3.2  (foo_run)
WMA Decoder 1.1  (foo_input_std)
Columns UI 0.2  (foo_ui_columns)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Play Count Mod 1.0.2  (foo_playcount_mod)
Playlist Manager 1.0.2  (foo_playlist_manager)
Coverflow pannel 0.2.0d  (foo_chronflow)
freedb Tagger 0.5.2a  (foo_freedb2)
Panels UI 0.14.9 beta [Jul 13 2007 - 14:05:55]  (foo_ui_panels)
Default User Interface 0.9acc  (foo_ui_std)
Cover Flow 0.18  (foo_bubble_coverflow)
Peakmeter Panel 0.0.4.2 beta  (foo_uie_peakmeter)
foo_func 0.2.1a  (foo_func)
ABX Comparator 1.3.1  (foo_abx)
Navigator 0.6  (foo_navigator)
Volume Panel 0.1  (foo_uie_powerpanels)
Lyric Show Panels 0.3.1.1b8 DEV [Sep 16 2007 - 08:44:03]  (foo_uie_lyrics)
CD Audio Decoder 2.1.1  (foo_cdda)
Lyrics Art Panel 0.053  (foo_uie_lyrics_art)
Album Art Panel 0.2.7.1  (foo_uie_albumart)
cwbowron's title format hooks 1.0.14 [Nov  1 2006 - 10:20:44]  (foo_cwb_hooks)
ELPlaylist 0.2.6(alpha)  (foo_uie_elplaylist)
Standard DSP array 1.0  (foo_dsp_std)
ZIP/GZIP reader 1.0  (foo_unpack)
Playlists Dropdown 0.6 alpha 4  (foo_uie_playlists_dropdown)
Special file info box v2.0.0  (foo_infobox)
  • Last Edit: 28 March, 2008, 07:07:28 AM by Falstaff
  • buktore
Reply #35
Maybe.. this? It's from my previous reply .
"Ah... that "flicker" I mentioned earlier is because I draw EL panel on another track display. Now I just draw it in the main layout and that flicker is gone."
For the report, PUI 14.12 + WinXP + Elplaylist = No crash yet.
REQUEST: Press ENTER to play selected track. I mean.. c'mon
After playing with it for a while.. Yeah.. the amount of TAGZ using is going through the roof, even more than SCPL. It's need some weird & more complex command just to draw some simple text.
But on the other side, compare it to SCPL, it's very fast. SCPL is slower than Half-life 2 on my PC when using transparent background + some images in it. Now I can draw font shadow (It's not practical in SCPL because it's so slow!) + a whopping amount of image + (semi) transparent background and it's still much faster to scroll around than SCPL.
Keep up the good work. It really promising.
  • Last Edit: 28 March, 2008, 07:22:59 AM by buktore
  • Falstaff
Reply #36
new crash :
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 025DC2FDh
Access violation, operation: read, address: 11201F60h
Call path:
entry=>app_mainloop=>on_playlist_switch
Code bytes (025DC2FDh):
025DC2BDh:  45 14 A8 03 0F 84 1B 01 00 00 A8 02 0F 84 89 00
025DC2CDh:  00 00 8B 77 40 E8 F9 1E FF FF 8B 45 14 8B B7 68
025DC2DDh:  01 00 00 8B 97 18 01 00 00 8B 52 08 D1 E8 24 01
025DC2EDh:  88 44 24 10 8B 45 0C 8D 8F 18 01 00 00 8D 04 40
025DC2FDh:  8B 44 C6 10 6A 01 50 FF D2 8B 44 24 10 8B B7 68
025DC30Dh:  01 00 00 8B 97 2C 01 00 00 8B 52 08 50 8B 45 0C
025DC31Dh:  8D 8F 2C 01 00 00 8D 04 40 8B 44 C6 10 50 FF D2
025DC32Dh:  80 BF 40 01 00 00 00 75 1B 8B 47 08 8B 50 54 6A
Stack (0012DA9Ch):
0012DA7Ch:  00000000 00000000 00000000 00000000
0012DA8Ch:  00000000 00000000 00000000 00000000
0012DA9Ch:  02922298 0012DE04 0012DB6C 025DE943
0012DAACh:  0012DE00 0012DAC4 B5D4954B 00060928
0012DABCh:  02922298 0012DE04 0012DE04 00000000
0012DACCh:  00060928 02922298 0012DEFC 0012DEFC
0012DADCh:  077BF2B0 00303B50 077BF2B0 0000002A
0012DAECh:  00002000 0012DD14 754CB2E8 01C4A660
0012DAFCh:  00000000 00000000 00000000 01C4A5A4
0012DB0Ch:  754CB34D 001307F6 00060928 00E323B8
0012DB1Ch:  0012DB38 7658F620 00E323B8 FFFFFFEB
0012DB2Ch:  00000000 00060928 0000004E 0012DB74
0012DB3Ch:  7658F6AA 00E323B8 FFFFFFEB 7658F6B6
0012DB4Ch:  B5C4E3AF 00060928 B5D49537 0012DE04
0012DB5Ch:  0012DC38 025E71D9 FFFFFFFF 765D51BA
0012DB6Ch:  0000004E 025D0E69 00060928 0000004E
0012DB7Ch:  00000064 0012DE04 0012DC20 0000004E
0012DB8Ch:  0012DBD0 00000000 00000000 00000024
0012DB9Ch:  00000001 00000000 00000000 7658F8D2
0012DBACh:  00060928 0000004E 00000064 0012DE04
Registers:
EAX: 000043E6, EBX: 0012DE04, ECX: 029223B0, EDX: 025C1290
ESI: 111E0020, EDI: 02922298, EBP: 0012DE04, ESP: 0012DA9C
Crash location: "foo_uie_elplaylist", loaded at 025C0000h - 025FD000h
Loaded modules:
DesktopControlPanel              loaded at 00390000h - 003A5000h
foo_bubble_coverflow            loaded at 01C70000h - 01CF6000h
OPENGL32                        loaded at 731A0000h - 7326B000h
GLU32                            loaded at 72B30000h - 72B53000h
foo_chronflow                    loaded at 01AD0000h - 01B32000h
foo_cwb_hooks                    loaded at 01A90000h - 01ABE000h
foo_func                        loaded at 01D00000h - 01D52000h
foo_infobox                      loaded at 01D60000h - 01D9E000h
foo_menu_addons                  loaded at 01FE0000h - 0203D000h
libmmd                          loaded at 02150000h - 02401000h
foo_navigator                    loaded at 02040000h - 02071000h
foo_playcount_mod                loaded at 01DB0000h - 01DC5000h
foo_playlist_manager            loaded at 02090000h - 020D4000h
foo_run                          loaded at 02100000h - 0212B000h
foo_uie_albumart                loaded at 02510000h - 0254D000h
foo_uie_albumlist                loaded at 02570000h - 025B3000h
foo_uie_elplaylist              loaded at 025C0000h - 025FD000h
foo_uie_graphical_browser        loaded at 6D540000h - 6D5D1000h
foo_uie_lyrics                  loaded at 02640000h - 026A1000h
foo_uie_lyrics_art              loaded at 02A30000h - 02ADA000h
foo_uie_peakmeter                loaded at 02700000h - 02733000h
foo_uie_playlists_dropdown      loaded at 02AE0000h - 02B19000h
foo_uie_powerpanels              loaded at 02B20000h - 02B43000h
foo_uie_quicksearch              loaded at 02B90000h - 02BD6000h
foo_uie_vis_channel_spectrum    loaded at 02B50000h - 02B78000h
foo_ui_columns                  loaded at 03460000h - 03526000h
foo_ui_panels                    loaded at 03630000h - 036F6000h
foo_abx                          loaded at 031C0000h - 031F3000h
foo_albumlist                    loaded at 03240000h - 03287000h
foo_cdda                        loaded at 03290000h - 032C5000h
foo_converter                    loaded at 03AB0000h - 03B19000h
foo_dsp_std                      loaded at 033F0000h - 03431000h
foo_freedb2                      loaded at 03800000h - 03840000h
foo_input_std                    loaded at 03E20000h - 03F38000h
foo_masstag                      loaded at 03A50000h - 03AA0000h
foo_rgscan                      loaded at 03B20000h - 03B68000h
foo_ui_std                      loaded at 03B90000h - 03BE6000h
foo_unpack                      loaded at 03C00000h - 03C2E000h
nvoglv32                        loaded at 69500000h - 69BB0000h
Address: 025DE943h, location: "foo_uie_elplaylist", loaded at 025C0000h - 025FD000h
Address: 754CB2E8h, location: "uxtheme", loaded at 754C0000h - 754FF000h
Symbol: "GetThemeBool" (+00000A62h)
Address: 754CB34Dh, location: "uxtheme", loaded at 754C0000h - 754FF000h
Symbol: "GetThemeBool" (+00000AC7h)
Address: 025E71D9h, location: "foo_uie_elplaylist", loaded at 025C0000h - 025FD000h
Address: 025D0E69h, location: "foo_uie_elplaylist", loaded at 025C0000h - 025FD000h
Address: 025D0CF0h, location: "foo_uie_elplaylist", loaded at 025C0000h - 025FD000h
Address: 76590817h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "ReleaseDC" (+0000007Ah)
Address: 765D29FFh, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "GetRawInputDeviceInfoA" (+00000116h)
Address: 76590A65h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "GetWindowThreadProcessId" (+000001CDh)
Address: 765907CCh, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "ReleaseDC" (+0000002Fh)
Address: 76588871h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "GetKeyState" (+000000AAh)
Address: 76584AB8h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "GetShellWindow" (+00000114h)
Address: 76589E6Bh, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "InflateRect" (+00000000h)
Address: 753322F3h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "Ordinal414" (+000002B4h)
Address: 752F8799h, location: "COMCTL32", loaded at 752F0000h - 7548E000h
Symbol: "ImageList_GetImageCount" (+00001407h)
Address: 77D308B5h, location: "ntdll", loaded at 77CF0000h - 77E17000h
Symbol: "RtlReAllocateHeap" (+000001B0h)
Address: 77D308C9h, location: "ntdll", loaded at 77CF0000h - 77E17000h
Symbol: "RtlReAllocateHeap" (+000001C4h)
Address: 7672C56Fh, location: "kernel32", loaded at 766E0000h - 767BB000h
Symbol: "HeapFree" (+00000014h)
Address: 00493F4Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7658598Dh, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "SendMessageCallbackW" (+00000099h)
Address: 025DCFE8h, location: "foo_uie_elplaylist", loaded at 025C0000h - 025FD000h
Address: 025EBD70h, location: "foo_uie_elplaylist", loaded at 025C0000h - 025FD000h
Address: 025EBD68h, location: "foo_uie_elplaylist", loaded at 025C0000h - 025FD000h
Address: 004BE0ACh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00403920h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040EB2Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 025EBD90h, location: "foo_uie_elplaylist", loaded at 025C0000h - 025FD000h
Address: 0364BEBDh, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 0363A2A7h, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 00452C89h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0364709Dh, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 03647130h, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 025E708Dh, location: "foo_uie_elplaylist", loaded at 025C0000h - 025FD000h
Address: 10002F72h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 025C8759h, location: "foo_uie_elplaylist", loaded at 025C0000h - 025FD000h
Address: 0044AF1Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 02BC85B8h, location: "foo_uie_quicksearch", loaded at 02B90000h - 02BD6000h
Symbol: "foobar2000_get_interface" (+00035C48h)
Address: 004DF100h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A7956h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045271Fh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A8200h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 02BC853Ch, location: "foo_uie_quicksearch", loaded at 02B90000h - 02BD6000h
Symbol: "foobar2000_get_interface" (+00035BCCh)
Address: 02B9D534h, location: "foo_uie_quicksearch", loaded at 02B90000h - 02BD6000h
Symbol: "foobar2000_get_interface" (+0000ABC4h)
Address: 02BB9220h, location: "foo_uie_quicksearch", loaded at 02B90000h - 02BD6000h
Symbol: "foobar2000_get_interface" (+000268B0h)
Address: 02BB4808h, location: "foo_uie_quicksearch", loaded at 02B90000h - 02BD6000h
Symbol: "foobar2000_get_interface" (+00021E98h)
Address: 02BA2A4Bh, location: "foo_uie_quicksearch", loaded at 02B90000h - 02BD6000h
Symbol: "foobar2000_get_interface" (+000100DBh)
Address: 100049D0h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "stricmp_utf8" (+00000000h)
Address: 0363A70Eh, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 02BB4FBFh, location: "foo_uie_quicksearch", loaded at 02B90000h - 02BD6000h
Symbol: "foobar2000_get_interface" (+0002264Fh)
Address: 02B9BFDBh, location: "foo_uie_quicksearch", loaded at 02B90000h - 02BD6000h
Symbol: "foobar2000_get_interface" (+0000966Bh)
Address: 03672464h, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 02BC5478h, location: "foo_uie_quicksearch", loaded at 02B90000h - 02BD6000h
Symbol: "foobar2000_get_interface" (+00032B08h)
Address: 036C803Ch, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 036BD860h, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Symbol: "Scintilla_DirectFunction" (+00038227h)
Address: 036726B6h, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 036C80D8h, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Symbol: "Scintilla_DirectFunction" (+00042A9Fh)
Address: 036BE759h, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Symbol: "Scintilla_DirectFunction" (+00039120h)
Address: 03646B6Bh, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 77CF9801h, location: "ntdll", loaded at 77CF0000h - 77E17000h
Symbol: "RtlUpdateTimer" (+000005D2h)
Address: 036A25F9h, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Symbol: "Scintilla_DirectFunction" (+0001CFC0h)
Address: 036A2618h, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Symbol: "Scintilla_DirectFunction" (+0001CFDFh)
Address: 0363C27Dh, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 036AB070h, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Symbol: "Scintilla_DirectFunction" (+00025A37h)
Address: 0367335Bh, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 76D56D70h, location: "GDI32", loaded at 76D50000h - 76D9B000h
Symbol: "BitBlt" (+00000089h)
Address: 76D56D58h, location: "GDI32", loaded at 76D50000h - 76D9B000h
Symbol: "BitBlt" (+00000071h)
Address: 03643CF3h, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 76589CFAh, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "GetSystemMetrics" (+000000CCh)
Address: 7658A0C3h, location: "USER32", loaded at 76570000h - 7660D000h
Symbol: "GetFocus" (+00000007h)
Address: 03643D1Bh, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 03646DDFh, location: "foo_ui_panels", loaded at 03630000h - 036F6000h
Address: 77D59D8Ch, location: "ntdll", loaded at 77CF0000h - 77E17000h
Symbol: "RtlInitUnicodeStringEx" (+000001EDh)
Version info:
foobar2000 v0.9.4.5
UNICODE
Windows 6.0
Additional info:
always when switching playlist, but not with album-list panel this time ...
  • buktore
Reply #37
New version is out..
Big thanks for ENTER hotkey. After asking for it and 3-4 hours later, I got it.. THAT was fast
Some glitches (not sure the author already knew it or not) : Play a track in playlist that have scrollbar then switch to playlist that don't have scrollbar, graphical glitches appear at where scrollbar should be.
  • Falstaff
Reply #38
+1, most generally, when i change a playlist, playlist display is not refreshed
but good news, no more crash with last version, and big thanx for alpha-channel support for $imageabs(), works fine (don't forget to update the readme.txt for new parameters added )
i'll report any new bug ...
  • buktore
Reply #39
You mean.. changing playlist by some way (like using the context menu in playlist) but playlist content not refresh?
If that the case.. No, not happen here.
I will keep my request for later time (I do have some), right now I would like to have stable component first.
EDIT:
Bugs for 0.2.6.1a : Using "Activate Now Playing" command provide by Column playlist or double click at status bar does not move playlist view to show current playing track, the cursor does go to current playing track but the view is not. Try it out by play some track, scroll the playlist so that you can't see current playing track and then double click at status bar or use activate now playing command to see what I mean.
Not happen with 0.2.6a
  • Last Edit: 28 March, 2008, 01:26:42 PM by buktore
  • Falstaff
Reply #40
New bugg found (sorry ...)
Cover displayed blur sometimes, 90% always when i 'hide all' détails and after i expand a group, see picture below :
not very eyed-candy isn't it ?
all covers are ok when i set playlist to 'Show All items' and exit/run foobar, it's only blur for some (a lots of covers but not all) after 'Hide all items' activated and expand a group ...
  • Last Edit: 28 March, 2008, 01:08:02 PM by Falstaff
  • Falstaff
Reply #41
not a bugg this time (or maybe ...?)
if the playlist does'nt fill the whole height, the lines left with no tracks info are not transparent
here is what it give (so ugly) :
  • Last Edit: 28 March, 2008, 05:14:18 PM by Falstaff
  • Kiteroa
Reply #42
Thanks for a great new component - I'm moving some of my SCPLs over to this.
ELPlaylist can do many things SCPL can't (some of which were wish-list items)
hide headers,
minimum no. of item rows,
but 1) has anyone found anything SCPL can do that ELPlaylist can't?
2) has anyone found any functions SCPL has that ELPlaylist doesn't?
SCPL                                    EL
$info_sum(field)---------------->only length provided for:
$meta_sum(field)--------------->%el_sum_length%/%el_sum_length_seconds%
%focused%    -------------->%el_focused%
%selected%  -------------->%el_selected%
%group_index%------------>%el_item_index%/%el_item_index2%
%group_count%------------>%el_item_count%/%el_item_count2%
3) Has anyone found any general Panels_UI functions that ELPlaylist doesn't have?
  • Yotsuya
Reply #43
SCPL standalone (Not the PUI version) will run well in wine, ELPlaylist will load but crashes foobar as soon as it is activated.
  • buktore
Reply #44
Bug about "Activate Now Playing" is fixed now. THX
Also, No glitches so far at scrollbar thing AND now you can have complete transparent background with playlist that have few track in them provide that this condition is met..
** pseudo trasnparaent mode currently requires that the height of ELPlaylist is integer multiples of %el_row_height%**
Now it's look & work nice! bye bye SCPL.. It was fun.
My REQUEST (It's not really important so it's OK if you don't implement it) : Toggle command for show/hide all items for use with custom button.
  • Last Edit: 29 March, 2008, 02:20:38 PM by buktore
  • Falstaff
Reply #45
thanx for new release and no matter for the pb of the pseudo transparent mode that doesn't fill the whole playlist with little playlists (album), i have found the solution
se below, now, it's always nice (with big and very small playlists !!) :
Question : could someone explain me how to use Per Second with the header/group section, i would to display a play overlay pic over the cover depending on the seconds elapsed (to flip-flop it) ...
thanx
  • TomBarlow
Reply #46
I think the per second area is for track display for the currently playing track only.
I love this playlist, it's awesome. I'm still having the groups collapse randomly though, which is very annoying. I wonder if it's a conflict with another component. I don't know really...
I think the one thing to make this the best component ever is multiple collapsible group levels, say artist, album, then track. No rush to the dev though, it's great as it is.
Oh another thing, I like how you have lots of TAGZ functions and fields to play around with, %_item_count%, %_sum_length% and $gettextwidth() are really useful.
  • Last Edit: 29 March, 2008, 07:58:10 AM by TomBarlow
  • Falstaff
Reply #47
bugg with the sort option in settings :
if checked in the settings, it means that the playslist will be auto-sorted when it will be activate... no ?
so it doesn't work when changing playlist ... i have to sort the playlist manually (right click --> Sort)
could you check this point please ?
  • Last Edit: 29 March, 2008, 08:43:05 AM by Falstaff
  • buktore
Reply #48
I saw in the Readme mentioned that sort option is still not recommended so it may not yet work I guess.
Then, It will become "media library" instead of a playlist... And maybe it's not an easy (or maybe impossible) to made it do that since that not how playlist work but I don't know for sure.
I do wish that this component remain as simple as possible, there's an example of some plugin that do "too much" to the point that just install it and it slow foobar down.. which I hope it doesn't happen with this component.
It's happen when TAG is update. Do you sure that there's nothing happen at all when the groups collapse? like audio scrobbler working..? just a guess though cause most of the time I just show all items.
ANOTHER REQUEST: Single click at header to select all item in group, or an option to choose what action to perform would be nice. But I get the feeling that if the developer can do that he might done it already so if it not possible then it's OK.
  • Falstaff
Reply #49
the author say that on his site :
"+ fixed Per second not working with group header show/hide operations"
but i don't know how to apply Per Second on group header for my needs ... ?
