Topic: Tag <LYRIC> to *.lrc (Read 3633 times) previous topic - next topic
is there a plugin or a way to save my Lyrics in both the tag and a file?
At  the moment i have them in the field <LYRIC> but i also want to save them in the directory with the tracks filename....
i need that because my mp3-player only supports *lrcs
with lyric show panel i only can save the new lyrics in a file but not the old and many lyrics aren't on the internet.
Thx
PS: is there a good site to dl lyrics with stamps?!
Thx
is there somesing in the masstagger?
There's not really a good way to keep things "synced", so you'd have to make sure that your lyrics are as you want them before you export them to a .lrc file.  There is nothing in masstagger that will allow for an export to a file.
If all you want to do is save what is contained in the LYRICS tag to a .lrc file, I would consider using mp3tag's export tags option....never set it up explicitly to save just one filed, but I imagine it could be done.  To do it wholly within foobar2000 you would want foo_run and a decent batch file.
What file types / tagging schemes / portable hardware are you using?
maxfield g-flash ng 2GB
all files are mp3 in %artist%\%album% [%year%]\%tracknumber% %title%.mp3
and the lyrics should be like this %artist%\%album% [%year%]\%tracknumber% %title%.lrc
It would be enough if the Lyrics with time stamps would be exported into these files...
EDIT:
I have another problem!
What configuration must i use to read out the lyrics from these directories...
the lyrics show panel shows the taginformation. I disable the field tag because at the moment i have only some lyrics as *.Lrc
all are associated...
why is this so difficult?!
can i force the downloader to save the *.txt as *.lrc?
