Topic: Columns/PanelsUI Tab like feature (Read 5758 times) previous topic - next topic
Firstly sorry if the title wasn't descriptive enough.
Secondly I've mocked up the following config in photoshop that I intend to make. http://i25.tinypic.com/m94ydc.jpg
I can create probably about 75% of it but I'm not sure how to create the bit with the album art, info and album list all in one. I could do it using tabs but I don't want the tabs to appear and this is apparently impossible in ColumnsUI. I'm guessing that it could be done by coding it using the PanelsUI trackinfo plugin, if so does anyone have any simple code that they are willing to share. I could grab it from other people's configs but as I'm a beginner I don't really feel comfortable routing around all the code.
Cheers.
  • Smirra
I checked it out, my problem is that I'm using ColumnsUI with Track Display. I'm not even sure this is possible.
Also the article doesn't explain what version of PanelsUI is needed, there are also comments stating it doesn't work.
EDIT: does anyone know how to run two instances of Foobar, I'd really like to try this without screwing up the one I already have.
  • Last Edit: 18 March, 2008, 10:17:09 AM by digital006
Just copy the foobar folder to where you want. Then run foobar2000 and you can make those changes.
I already have 2 folders, "foobar2000" and "foobar2001" but when I double click the exe file in the second directory it just focuses on the one already open (I even renamed it foobar2001.exe). I'm using WinXP SP2
  • antar3s
not having problems with running multiple instances here...maybe there is an option to allow multiple instances in foobar, though i couldnt find it...
the thing that is described in the foobar2000 blog should work with all available panelsui versions. but u also have the option to use the tabs component, i believe the tabs can be hidden too, so one cannot tell that there are tabs. however, you would need to create some buttons to switch between tabs then i guess
edit: typos
  • Last Edit: 19 March, 2008, 04:32:47 PM by antar3s
What about foo_uie_tabs v.0.2.6? You can hide the tabs display with this component and still move between them via menu (=> buttons, etc.)
  • foosion
  • Moderator
There is no option in foobar2000 to use multiple instances. If you want multiple instances, you have to make sure that you have multiple installations and that at most one installation uses the shared configuration that is stored in your Windows user profile. The General page in the preferences has a setting to control the location of your configuration files.
Thanks, I'll give it a shot now.
Edit: after playing around with the settings I finally got it to work. Thanks foosion
  • Last Edit: 20 March, 2008, 09:25:52 PM by digital006
